05-20-2011, 05:18 PM | #26 |
Grandpa in the rustmobile...
Re: 5" Rear drop springs from Ebay
I think 5" drop requires a super trac bar
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-20-2011, 05:47 PM | #27 |
Moderator
i have 5" drop springs and 1.5" blocks. i have the adjustable bar listed in the link. it works perfect. you do not need the super trac bar.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-20-2011, 05:49 PM | #28 |
I drove mine with the stock track bar and these springs for a half tank of gas so far with no problems.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB 1967 Custom Short Fleet - 327/4spd |
05-24-2011, 08:20 AM | #29 |
Here's how mine sits. The 305 BFG's are coming off. The track bar sits slightly higher on the passenger side but goes down the highway just fine.
05-24-2011, 11:26 AM | #30 |
I've also got a 4"drop spring in the back with 1.5" blocks on the stock bar, the rearend is still centered on the truck too, drives great!!
05-24-2011, 03:14 PM | #31 |
So now I'm in the mix, Thinking to myself " do I need to buy a trackbar " Let meget some feedback. I guess it wont hurt to get one, but do i need one?
05-24-2011, 03:15 PM | #32 |
Moderator
If the rear end is not centered after lowering it, you need an adjustable trak bar.
05-24-2011, 04:36 PM | #33 |
So before I make my decision on this i need to put the bed, tailgate, etc. back on to check it and see....
05-24-2011, 07:29 PM | #34 |
Just a car guy
I just got mine sitting on the ground with the 3"front 5" rear combo.
Front almost seems higher, probably going to cut a 1/4-1/2 coil. I left the stock track bar unhooked till I sat it on the ground and it lined up easily as well. I do have the adj 35" bar set up to install though. Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
05-24-2011, 07:33 PM | #35 |
Just a car guy
I am running the same size tire all around as well. I think if I had a little taller tire on the rear, the stance would be dead on.
05-24-2011, 07:48 PM | #36 |
Drive it around for a bit before you cut the springs. they will probably settle a little.
68 Chevy C-10. swb fleetside. 6.0 4L80E swap. http://67-72chevytrucks.com/vboard/s...d.php?t=460877 Last edited by 68chevyLQ4; 05-24-2011 at 07:48 PM. |
05-24-2011, 08:30 PM | #37 |
Yea I wouldn't go cutting on the springs just yet!
05-25-2011, 07:10 AM | #38 |
Just a car guy
It's been sitting on the front springs for about 6 months.
I've never seen spring 'settle' much lower after a short time anyway. Posted via Mobile Device
05-25-2011, 07:15 AM | #39 |
Just a car guy
Not to mention, I have not yet installed the blazer tank which will put more weight at ghe rear,
