05-04-2011, 04:47 PM | #26 |
Re: Any big block 60-66 trucks?
My wielder looks nothing like that! I was wondering about the frame rails because I had to notch mine also. I didn't go the extra step and box them in. I hope i don't discover this short cut hard way. When I get mine together ( If ever!) maybe we might cross paths in Florida sometime.
05-04-2011, 05:37 PM | #27 |
I used these mounts and I think I had to grind about 1/16 of an inch just for safety on the headers. Just the right side the left side had no issues at all. I only grinded the right side because it was real clost to the header. I did have to knotch the frame for the mounts though.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-04-2011, 07:15 PM | #28 | |
Thanks |
05-04-2011, 07:32 PM | #29 |
My engine is in stock location......Use the same perches Chevy Fleetside used.
Here's a link for the mounts. http://www.summitracing.com/parts/AX...n/?prefilter=1
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl Last edited by 198plus; 05-04-2011 at 07:35 PM. |
05-04-2011, 11:01 PM | #30 |
mine's mounted using triangle universal motor mounts, had to cut out small chips from the frame to clear the headers
65 Chevy C-20 Chopped 3", Doors Suicided, completely shaved, 650 hp BBC |
05-05-2011, 01:01 AM | #31 |
60-66 Nut
What I do with the frame, is just trim the top flange back to give clearance for the headers and motor mounts. I use the '68-'87 frames as a template. The big blocks were available in the trucks beginning in '68. For motor mounts I used the '73 and up clamshell style mounts with custom built frame brackets.
05-05-2011, 02:27 AM | #32 |
Chevy Fleetside i got the same mounts as you.. i mounted mine in the forward holes and i got all kinds of clearance for the firewall and im gonna clearance one part of the frame because there is only about a 1/2 inch gap on 1 tube of the header on the passenger side.. btw the headers are doug thorley tri Y headers..
here is the motor mount kit i got http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT here are some pics of a test fit.. i got it pulled back out for a rebuild
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
05-05-2011, 09:12 AM | #33 |
The perches came with Car Style motor mounts. The only reason I used the tubular ones besides the later model clamshell ones, is just the way they look. I didn't want that later model mount as I thought it would not look good. Just my opiniion.
