Old 01-30-2012, 06:19 PM   #26
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Proportioning valve
I just noticed that SCOTI has the Front Right and Left opposite of the pic I posted.
Originally Posted by SCOTI View Post
1) Front pass side
2) Front driver side
3) Supply from master cyl to fronts
4) Supply from master cyl to rear
5) Rear common
Originally Posted by LostMy65 View Post
This Pic helped me:
66 C20 Service Truck:
Old 01-30-2012, 10:42 PM   #27
SCOTI
SCOTI's Avatar
How my prop valve is tagged is how they were plumbed in the truck. The proportioning is equal between L & R; just F & R is different so the fronts are actually interchangeable.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-27-2012, 12:29 AM   #28
LostMy65
LostMy65's Avatar
Looking at Parts Stores, it looks like combination valves aren't necessarily vehicle specific?
http://www.summitracing.com/parts/CLP-PV-2/
Old 11-02-2018, 02:18 PM   #29
ironman3452
ironman3452's Avatar
I thought that you only need a propportioning valve, if you are useing disk brakes, my 64 C 30 panel has standerd brakes, please advise if i am wrong, Iwant to change to a duel master cylinder.
thanks
ironman3452 is offline   Reply With Quote
Old 11-02-2018, 02:57 PM   #30
Keith Seymore
Keith Seymore's Avatar
You are correct.
If you have four drums then you only need a "distribution block" and to tie into the rear system. The proportioning will take place via the wheel cylinder sizes.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-22-2019, 01:08 PM   #31
rodstored-72
chevy truck fan
rodstored-72's Avatar
This is nice information guys. I am in the process of "re-doing" a 1986 2wd (in the build section) and I am wondering as to why the proportioning valve is located on the brace in front of the motor? I would like to know if the valve can be relocated somewhere else?? I was thinking of replacing my booster and master with a later (mid '90's version) and placing the prop. valve next to the master with the lines relocated correctly. what do you guys think??
thanks!!
rodstored-72 is offline   Reply With Quote
Old 10-22-2019, 02:54 PM   #32
Keith Seymore
Yes - the prop valve can be placed anywhere (provided it is still plumbed correctly) and in any orientation.
Seemed like a good idea at the time...
(lol)
K
1979-1986
1986 - 2019
Old 10-22-2019, 03:53 PM   #33
rodstored-72
chevy truck fan
Keith,
i was hoping that you might return a chime in... !! I figured that it could be relocated, I had done the same on my '72. When I saw the location of it I was like.... ?? it seems like that is a weird spot? especially if it needs to be serviced or replaced. Now I just need to see how I will run my lines to the new location... Hmmmmm?
thanks for the reply... I feel honored to have a response from you... very similar to getting a response from ken (N2TRUX)... !!
Old 11-26-2022, 09:32 PM   #34
Dleslie212
Reviving this thread and hoping to find an answer.
I just converted my 77 to hydro boost, with a new master cylinder and adjustable proportioning valve, which is mounted just beside the master cylinder.
My question is - can I just remove the old proportioning valve and tee the front lines together, and coupling the rears together since I'm using a new proportioning valve now? Or am I supposed to leave the old valve in place anyway?
Dleslie212 is offline   Reply With Quote
Old 11-30-2022, 09:36 PM   #35
1957 Chief
Yes, you can get rid of it. I got rid of mine when I put my adjustable prop valve in.
Bubba
1957 Chief is offline   Reply With Quote
Old 11-30-2022, 09:46 PM   #36
Dleslie212
Bubba
How did you connect the lines back together where the old prop valve was?
Old 12-01-2022, 10:21 AM   #37
1957 Chief
I don't remember exactly, but I pulled the original prop valve and marked which lines were for the front and rear brakes and which ones were from the master cylinder. Then had to tee the lines together. Pretty sure I had to cut some of the flares off and put on diff size flare nuts to make it work. Wasn't that hard, its just a bear cause of where the valve is located.
Bubba
