#26 |
Re: fuel sending unit????
it wasnt the rubber it was a rust hole in the metal line
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
#27 |
GM Addicted
Well i mounted the tank back on the frame rail and still nothing. So i again checked the fuel pump rod and it is jammed up some how. It will come out about .5 inch or less and that is it. i know that is engough for the fuel pump maybe or maybe not but i reconnected everything and still nothing would happen. So my grandpa called and sayed that he has a electric A/C delco pump from the mid eighties that he bought and never used. The pump is bad i like i just because it is old and you can tell its around the same era of the truck. So put the electric pump in and the truck is back on the road. But why would the rodded get jammed in the block and not come out?
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#28 |
This I absolutely do not know.
Only way to find out I guess is tear it open when you do switch the engines. |
#29 |
GM Addicted
yea i will tare it open and i might be stroking the engine out to a 335 and drop it in my dads 68
#30 |
78K & 79C Jimmys
did you try pumping the pump by hand while out?
that may tell you if it's go or no
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#31 |
GM Addicted
Yes the pump has plenty pressure. Its weird that the rod will not come out of the block though
