05-16-2011, 10:42 PM | #26 |
Re: glove box spec sheet gone, can new one be ordered up somewhere?
05-17-2011, 07:49 AM | #27 | |
but you need to know the first portion of that numerical sequence. Is it 100068? 200068? 400068? Also - with respect to the build sequence number - the codes on the firewall, radiator support, hood, etc are usually just the last two, three or four digits of the daily (aka "manifest") build sequence, which is independent from the VIN. For example, my truck was "number 87" - but it could have been #87, #187, #1087, or #1,000,087. You wouldn't know without additional information. By way of reference, my VIN sequence is F317388 (notice how it does not match the daily build sequence number), and my truck was built in late September/early October of 1986 (during the '87 model year). That's relatively early in the model year but look how high the VIN sequence is already. Lastly, trucks are built "roughly" in VIN order, but not precisely. They are shuffled coming out of the body shop before paint, and then again coming out of the paint shop before trim, based on option content, material availability and assembly line work load balance. Additionally, for some model years the GMC VINs start with 500001 and Chevy started with 100001, so there can be more than one VIN sequence working it's way through the plant and process. FWIW - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-17-2011 at 08:02 AM. |
05-17-2011, 10:24 AM | #28 | |
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
05-17-2011, 10:24 AM | #29 |
My last part of my vin is Z205068
05-17-2011, 11:20 AM | #30 | |
See my post above - Flint had already built 217,387 Chevy's (not counting GMCs) by the end of September (the first full month of production) for the '87 model year. It would vary based on assembly plant; Where was your truck built? My point is that the operator would normally write the last two digits (or three or four - depending on how lazy they were feeling). In your case, it was easier for them to write "69" (and there may have been some assembly line humor going on there ) than it was for them to write the actual full manifest sequence number of "332,169" (for example)- or "2169" or "169". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-17-2011 at 12:18 PM. |
05-17-2011, 11:23 AM | #31 |
Yep - you're a long ways from number 68.
VINs would have started at 100001, so about 105,000 Chevy trucks later. Just as a reference the Flint final line rate was 60 jobs per hour - so that's roughly one completed truck every minute. Based on your numbers I'd say Fremont was a bit slower than that (or only ran one shift of production, rather than two or three). Additionally, the latest info I have on Fremont is for 1974, but at that point in addition to building Chevy and GMC trucks they were also building Chevelle, Monte Carlo, Buick Century and Pontiac Lemans models (which would dilute the truck VINs - spreading them out timewise). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-17-2011 at 11:41 AM. |
05-17-2011, 12:15 PM | #32 |
Ok, good to know. Just trying to work out how to decipher the vin! Thanks all.
05-17-2011, 12:18 PM | #33 | |
weird...
05-17-2011, 02:54 PM | #34 | |
Not weird - just random. As I mentioned above, there is no correlation between the VIN and the (daily) manifest build sequence number. Your VIN is F366535 and the sequence number would have been some number greater than that ending in "69". What we have here is two separate number series incrementing up sequentially but which are not tied to each other. For example, that particular day might have looked something like this*: Manifest sequence.........................................VIN................................................ ....Model 387469......................................................F366535................................. .........Chevy Pickup (your truck) 387470......................................................F366536................................. .........Chevy Pickup (266,535th Chevy built) 387471......................................................F521987................................. .........GMC pickup (521,987 - 500001 = only the 21,986th GMC built) 387472......................................................F366534................................. .........Chevy pickup 387473......................................................F366537................................. .........Chevy pickup 387474......................................................F521988................................. .........GMC pickup 387475......................................................F366538................................. .........Chevy pickup ...etc... K *fictitious numbers used for demonstration purposes, other than your VIN which is real
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-17-2011 at 03:40 PM. |
05-17-2011, 05:21 PM | #35 | |
That's some cool information to know! Michael
05-17-2011, 06:32 PM | #36 | |
I got to the plant on the designated day as the truck was coming down out of paint into trim (about 4 pm). I followed it all the way through the process and drove it off the end of the line myself. I left the plant at 1 am and by 5pm that same day it was at the dealership, 9 miles away.... Obviously, there is a lot more to it than that (as far as ordering and what happened prior to it getting built). You can read about that in my build/introduction thread, linked below (post #4) - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-17-2011 at 06:38 PM. |
05-18-2011, 09:52 PM | #37 |
I am tight on time, so I just skimmed this post, but check this out.
www.vintagevehicleservices.com I ordered the package for my truck and it came me everything to rebuild my spec sheet. I can't remember what I paid, but it broke down all the codes in my glove box
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE Last edited by chrismoore701; 05-18-2011 at 09:53 PM. |
