05-19-2011, 06:09 PM | #26 |
Re: just finished my front crossmember section
Looks like its the way to go,
05-19-2011, 06:38 PM | #27 |
It'd be alot cooler if you did
Some guys run a rack and pinion, may be worth looking into and its a nice upgrade.
Posted via Mobile Device |
05-19-2011, 07:23 PM | #28 |
Yep. The possible steering related issues are mentioned in most (if not all) of the notched/pancaked/sectioned x-member threads. Hard to miss....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-19-2011 at 07:23 PM. |
05-20-2011, 01:54 AM | #29 | |
Oh well, tape measure out again, my options are, move my steering up the same 1.5" or go rack and pinion, Thanks for the replys. |
05-28-2011, 03:57 AM | #30 |
K, I've been considering doing this to my 65 for awhile. is there any reason why you couldn't raise the xmember up into the frame instead of pancaking the xmemeber? I know alot of guys don't like the idea of cutting into the frame but I'd rather raise the xmember up into the frame like 5"s, welded it in and use a rack and pinion system and have better camber angles etc. I've never liked the idea of z'ing the frame. Any thoughts???
05-28-2011, 07:35 AM | #31 | |
05-28-2011, 11:06 AM | #32 |
I am now going to take a 1.25" section from the chassis & then raise the steering so its in the same location for the steering issues, it should work out to be a very cost affective way of lowering the front end of the c10,
05-28-2011, 05:50 PM | #33 |
Outstanding. Keep us updated!
05-28-2011, 11:34 PM | #34 |
SCOTI, who was it?
05-29-2011, 01:37 AM | #35 |
09-08-2011, 04:22 AM | #36 | |
Just thinking out loud here: could the steering issues be solved by moving the steering box and related components one inch forward, then adding one inch to the steering shaft?
51 Chevy 3100 Deluxe Cab(SOLD) 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD |
09-08-2011, 09:49 PM | #37 |
ok see if you can follow me here. I have a 1.5 sec xmember that I am thinking of using. What if you take the upper and lower control arms and move the ball joint forward an inch? This would fix this and also move the wheels up and inch. You might have to grind a little on the xmember to clear but I dont think it would be that much.
What do you guys think? As far as mounting the rack I wonder if there is a front steer unit that works like the rear steer on the Pontiac sunfire. It can be mounted closer to the driver side of the frame. This makes routing shaft and clearance issues down to a minimum. Any feed back?
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
09-09-2011, 12:35 PM | #38 |
My question is can you section a crossmember more than 1.5, if you use a rack and pinion without any major issues?
09-09-2011, 12:57 PM | #39 |
Define 'major'? Custom installation of a R&P set-up & sectioned x-member would be considered 'major' by most (all?) on this site....
09-09-2011, 01:14 PM | #40 | |
I know the frame will need to be notched for the rack, the spindles reemed out for the tie rods and the motor mount shorten or dropped.. That's the route I was looking at. Also I was think of moving the whole crossmember forward 1" to center the wheels in the wheel wells.. Not sure if this is an option.. |
09-09-2011, 02:53 PM | #41 | |
Porterbuilts Dropmember get's you there much easier....
09-09-2011, 03:08 PM | #42 | |
Thanks for the advice, Scoti and sorry to Hijack the thread. |
09-09-2011, 03:40 PM | #43 |
09-09-2011, 03:43 PM | #44 |
LOL, take a scroll through my build thread for what I experienced with a 2" section.
09-09-2011, 03:56 PM | #45 | |||
Here's a good shot showing the stock motormounts in place: Quote:
09-09-2011, 04:05 PM | #46 |
Re-read what I said.....
I'm saying to watch the oil pan clearance w/mother earth; not the x-member. If you section the x-member too much, the oil pan sump WILL be hanging below the x-member & could be the 1st thing that will come in contact w/the ground depending on the depth of the sump.
09-09-2011, 04:38 PM | #47 |
Well, I might take the measuring tape out and do some thinking..
09-09-2011, 05:42 PM | #48 | |
09-09-2011, 06:11 PM | #49 |
Good for you.
For everyone else but you, I would recommend to verify this concern before going through the effort of raising the x-member more than 1.5".
09-09-2011, 07:16 PM | #50 |
Har dee har har
