Old 07-02-2011, 02:13 AM   #26
JCampbell
Re: 5.7 TBI runs rich, hesitates...
Dirty injectors?
JCampbell is offline   Reply With Quote
Old 07-02-2011, 05:16 PM   #27
JCampbell
Well...now I did it.
Picked up a TBI rebuild kit from Napa. Basically tore down the throttle body, cleaned it up with carb cleaner, replaced all the gaskets and reassembled. Fired her up and she went straight to high idle. Won't kick down. Any ideas?
Solvent left in the throttle body from cleaning?
Old 07-02-2011, 08:26 PM   #28
JCampbell
Ran through the procedure to reset the IAC (jumped A & B on diagnostic port, waited approx 30 sec, disconnected IAC, pulled diagnostic jumper, started engine), no avail.
Thought maybe a vacuum leak: checked all vac fittings...good and tight. TB gasket seems to be correctly in place.
Note of interest...when I reset the IAC, the plunger did move into position...I can see the cone when looking down into the TB.
Old 07-02-2011, 09:34 PM   #29
rfmaster
rfmaster's Avatar
Did you set timing with EST connector open to 0 deg??
Did re connect TPS??
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 07-03-2011, 01:46 PM   #30
JCampbell
Yes.
Yes.
This is really starting to frustrate me.
Went through all the hullabaloo for re-setting the IAC several times and have had no significant changes in the high idle situation. Got the idea to physically check the position of the IAC when the truck was running...went out and looked down the TB before I started her up and I noticed the IAC was in a fully retracted position. I have not verified the position of the IAC with the truck running yet because I think it's pretty obvious that it is fully retracted when running.
So it would appear that even though I have reset the IAC several times, it still wants to default into a fully retracted position as soon as the truck is started.
I'm not really into buying and replacing parts as a method of troubleshooting, but I'm wondering if I have a bad IAC. I read somewhere (of course, this was after the fact ) that you are not supposed to use any kind of solvent while cleaning the IAC. So naturally, I used about half a can of carb cleaner on the damn thing when I was cleaning it.
Old 07-03-2011, 02:10 PM   #31
JCampbell
...and, yes, I did check for vacuum leaks by spraying ether around the base of the TB with no noticeable change in idle speed.
It would appear to me that that vacuum leaks are not the issue here.
Old 07-03-2011, 02:22 PM   #32
JCampbell
'Bout ready to haul this thing off the the #$% @#$% scrap yard!
Reset IAC. Verified IAC plunder was in "closed" position in the TB (meaning I could see the IAC plunder cone by looking down into the throttle body). Unplugged IAC to ensure plunger would not move. Fired engine. Engine went to (what seemed like) full throttle. While the engine was running, I verified the IAC plunger was still in the "closed" position...it was.
I am absolutely out of ideas.
Old 07-03-2011, 03:12 PM   #33
JCampbell
HA!
I feel like such an idiot. The linkage from the cruise control diaphragm to the throttle body was bound up at the diaphragm causing the throttle blades to be held open partially. Freed up the linkage and BAM!...went to a perfect idle. Took her for a ride around the block and she ran like a raped ape!
May need to bump the minimum idle setting up a hair...it kinda seems a little low. Need to pick up a tach to get it just right.
Old 07-03-2011, 09:22 PM   #34
rfmaster
rfmaster's Avatar
Man - I feel it for you!!!
Now you know how tough it is troubleshoot without being there - that truck still has many miles left in it.
IAC will compensate idle over time - ECM has re learn after IAC reset.
Happy Fourth of July (and be safe)
//RF
"The Beast"
Old 07-04-2011, 12:04 AM   #35
JCampbell
Yeah, it's already idling a lot better.
Old 07-17-2011, 04:23 PM   #36
JCampbell
Finally got around to adjusting the timing. Was set at 4*BTC and about 10* advanced. Disconnected EST, brought it back down to 0*BTC/0* advanced. Idled fine, got in it and ran around the block, SES lights up, truck starts running like s____, no power, missing, etc.
WTF?
Old 07-17-2011, 11:50 PM   #37
rfmaster
rfmaster's Avatar
WTF?
After you set base timing (EST connector open ~ 0 to 2 deg BTDC) shut off engine and disconnect battery. This will clear code 42 which is set when ECM detects EST connector open. If you forget to clear this DTC (after reconnecting EST) - SES will be lit on re-start. You can always pull DTC codes by shorting pins A & B of ALDL connector. Without re-starting engine move key into run position you should get 3x DTC 12 followed by 3x other codes (if any).
If EST connector is not fully plugged in ( or you have a broken wire in set EST circuit) your timing will be fixed to about 0 to 10 deg (depending on ICM) - absence of SA advance explains lack luster engine power.
//RF
"The Beast"
Old 07-18-2011, 11:36 AM   #38
JCampbell
Yeah, I plugged the EST back in and disconnected the ground from the battery after I set the timing. Though one thing that’s been gnawing at me is that the weather tight connector I assume to be the EST isn’t tan/blk, but looks more like an orange/blk. Could be a non-issue, except that I noticed when I unplug it, it doesn’t cause the SES to light up. Makes me wonder if I’m unplugging the wrong thing - although it seems unlikely as it is the only weather-tight single-wire connector near the booster, save for a purple/blk single wire connector that is more of a “press-fit” than a weather-tight connector like you posted.
Feeling a bit frustrated, but I have a plan:
Jump ALDL to see if there are any DTC – report/investigate findings
If no DTC:
-Pull plugs – inspect – replace if necessary
-Bump timing to 2* - see if that helps.
Old 07-18-2011, 12:32 PM   #39
Jonboy
Slots go on anything!
I think ppl/blk is O2 sensor, on the left side of the engine. The EST may be on the passenger side also, near the A/C box.
edit- when you unplug it, it will DEFINITELY turn on the SES light.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-18-2011, 12:54 PM   #40
JCampbell
Hmmm...okay.
Old 08-05-2011, 11:16 PM   #41
JCampbell
Victory!
...I think.
Finally got around to fooling with my rig again and just as I was beginning to suspect, I was unplugging the wrong connector. Found the actual EST, unplugged it, SES lit up, set timing to 0 degrees, reset DTC's & took her for a spin around the hood. It appears all is right in my little TBI world.
No hesitation or lean pops, just a smooth running smallblock. I won't feel like I'm totally out of the woods until I put some more miles on her, but for now it looks like my TBI and I are making up.
