Old 05-28-2011, 01:31 PM   #26
68gmsee
Active Member
68gmsee's Avatar
Re: bleeding brakes!?!?!
As I mentioned in my original post.... I had to take mine back twice and got my money back on the third failure. Went to another store and got a different brand, bench bled it exactly to directions and never had another problem.
Don't know if anyone mentioned, but when you have a booster getting a solid pedal without the engine running is normal. I always adjust my power brakes with the engine running.
Hope that solves your issues.
68gmsee is offline   Reply With Quote
Old 05-28-2011, 02:19 PM   #27
LONGHAIR
Originally Posted by Rochlow View Post
Would a bad proportioning valve create this problem. It's the only thing I haven't changed. Plus, the pin the front of it I can't seem to push in
That is at least part of your problem. The "pin" is an indicator that the proportioning valve has "shut off" half of your brakes. The pressure is not equalized between front and rear, which cuts off the lower pressured side. This is to give you some braking power if you have a failure of some kind. (broken/leaking lines, wheel cylinder, etc)
You can't be getting fluid from one end or the other, so you need to equalize the pressure to get the pin re-centered. As bad as is sounds, the simplest way is to release the pressure from the "good" end. Nothing is going to work until you get the pin re-centered.
I am a fan of gravity bleeding. It costs nothing, is completely reliable, and solves the "pin popping" problem.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-28-2011, 05:18 PM   #28
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
im wondering if the right push rod is used on the new booster > just sayin"
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 03-29-2012, 08:21 AM   #29
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Was this ever resolved?
Did you ever figure out the issue?
66 C20 Service Truck:
