#26 |
Re: Project Polar Bear
Here is the pic of my GM crate vortec I put in my 96 z71. Notice the metal lower intake that contains a injector spyder with 8 individual injectors, Then a plastic upper intake that just holds a throttle body. NOT a TBI, just a throttle body with no injectors.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
#27 |
Resident of Here
Well then please tell me how/why tons of people have done this. Everything I have read says that I can bolt on 96-00 350(vortec) heads and intake manifold and my TB will bolt right on.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#28 |
I feel like your being short. I'm just trying to help and save you waisted money.. I dont care what everyone says.... you cant bolt your TBI to a factory vortec truck intake. even if you fabbed up a plate to go across ontop of where the plastic intake is... what are you going to do about the holes left by the injectors in the lower intake? Like I said, that pic you showed is an aftermarket edelbrock carb intake with a TBI adapter.... its not stock. anyways good luck and have fun.
#29 |
Resident of Here
I wasn't being short, just trying to figure out why out of the blue someone says something completely different. So, would it be cheapest for me to get a carb intake that fits Vortec heads and get a TBI to carb adapter?
#30 | |
GM makes an intake, part number 12496821. GM parts direct sells this intake for 358.02 plus shipping. you can get an edelbrock vortec carb intake for about 100 less. then you have to buy adapter etc. I would go with the GM intake if I were to do the swap.
#31 |
Resident of Here
Yeah, but damn thats a lot of money for an intake. Seriously.
#32 |
I agree it is high. But its a narrow market they are selling to so they are gonna be a little more.. you can find used vortec carb intake for about 125-150.
#33 |
some more info from here
http://67-72chevytrucks.com/vboard/s...light=12496821 http://67-72chevytrucks.com/vboard/s...ght=vortec+tbi http://67-72chevytrucks.com/vboard/s...ght=vortec+tbi
#34 | |
"Oh well, it's a driver."
Not that you don't know it by now, but spudz is 100% right. If it were me (and I've thought about this swap a lot), I would try to find that GMPP TBI-to-Vortec intake used, but you'll probably be hunting for a while. At one point, there was a used one for sale on FSC, but that's been months ago. Even used, they're usually $200 at the very least.
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
#35 |
Resident of Here
So, the head gasket is still bad.
It had a shimmy in the front end I thought was a bad tierod. Dad drove it and thought it was a tire out of balance. So I ghost rode it to look at the tire. Front pass tires cords separated and it had a huge bubble in it. SO I threw on the 20+ year old spare. Darn thing is only 1" small and has no dry rot, and it wasn't totally flat, which was surprising. Also, when I had the old one off, it had a shiny present for me. A bolt, just like the rear pass tire HAS. I need tires bad.
#36 |
Man.. No more Coffee please. I feel under pressure just reading this post. You jump from one thing to another and now you still have a bad head gasket and bad tires. Park it and count to 10 s l o w l y. Then figure out what direction to go.
Did you buy your Cop uniform yet? |
#37 | |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
I have to call B.S. There is no way you "Ghost Rode" it on the passenger side to look at the front tire.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#38 |
Resident of Here
I did. I put it in drive and ran to the other side. Hard as hell. I dont lie, all truth. I realize I should have just jacked it up and spun the tire. Hindsight is 20/20.
#39 |
The more you run it with the blown head gasket you are ruining your engine.....
#40 |
Resident of Here
I know, if you want to pay for it be my guest.
#41 |
Great name for this project. My friend had a 1985 C20 Suburban that was white, called it the Fridgaire and even had that painted on the back of it (the F was in Fender Guitar style). It was large white metal box that had plenty of utility (the A/C even was cold....hmmm)......just like a frig!
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#42 |
Resident of Here
Ok, I got a job at Walmart as a cart pusher, they are offering me the job tomorrow, they are very weird the way they do their process.
Also, I changed my oil today, Valvoline Full Synthetic with a Mobil1 filter. Bought a 15qt drain pan so I could do the oil change. Also forgot to put the fill cap back on and it got ran over by someone, so I had to buy another, all they had was chrome, lol. I now have a 2" circle of chrome under my hood... ![]() Bought a spark plug gapper, gotta gap them to make sure they are all correct. I'll gap them at .35, which is best for TBI 350's. I also finally figured out what I will do for an engine eventually. Vortec 383 with 46mm modded throttle body, should gain me 2-3mpg and go from 180hp to 315ish and 250tq to 405ish. All for less that $2500. I cant wait. ![]() Also hope to be getting new tires this week or next. ![]()
#43 |
Resident of Here
I also will be ordering the flat stock to fix the from of my frame. I need 22"x2.25" .177" thick flat stock. Nobody has 2.25" .177 flat stock, so I'll just cut a little away from this: http://www.speedymetals.com/pc-4021-...ity-steel.aspx
It's only a hair thinner than the frame.
#44 |
Its fairly common to use a carb intake on the earlier 87-94 heads. The earlier engines, refered to as G-blocks, are often confused with the Vortec engines, because they use the same style valve covers. The main difference is the number of bolts holding the intake down. 12 for the G-block heads, 8 for the Vortec.
1998 Chevy Z71 1989 Chevy S-10 1978 Chevy K-10 1983 GMC K3500 1974 Chevy Cheyenne Super 20 4x4 |
#45 |
Resident of Here
New tires.
http://67-72chevytrucks.com/vboard/s...d.php?t=485069 I have a Monroe Steering Stabilizer needs to be installed. Sway Bar Bushings shipped out today.
#46 |
Resident of Here
Steering stabilizer in. I drove to my friends(Sam) shop and he put it in for free. Great guy! Next Thursday when I get paid I'll get Sam to put in my swaybar bushings($30-$60 labor). Then on November 10th(payday) I'll order a muffler and Sam will put it on too($20-$40 labor).
#47 |
Resident of Here
Also, I think I'm going to do this eventually for my exhaust system.
http://www.ourdealsrock.net/64-815937.aspx Cheapest I could find the 3" SS U-FIT.
#48 |
Resident of Here
Ordered a Summit Street & Strip Muffler on thursday. $40 shipped. Should be here by Wednesday.
#49 |
Resident of Here
Muffler got here on 10/29/11. I will put it on next Thursday/Friday(11/10). I replaced my spark plugs today. All 7.
![]() ![]() Sway Bar Bushings still havent arrived.
#50 |
Try "PB blaster" and let it sit for a night should come out!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
