#26 |
Re: Parting 72/67/81 SWB 4X4
Thanks Frank! It would be nice to see you again.
#27 |
How bad are the dings? Can you get a picture? Thanks
#28 |
I'm away from the truck right now. I will get pics soon.
Thanks, Ray |
#29 |
Kelly- shipping is $101 to Canada, its 28" long
special-K- here's some pics...lots of dings Frank- The exhaust is yours Thanks, Ray |
#30 |
Thanks,I'll pass. I didn't need it anyway.
#31 |
Its beat up pretty good after looking closely at the outside frame. Looks like I will get
$.60 per pound for this thing. |
#32 |
im not crazy on the shipping of the front shaft i am measuring tomorrow and would you consider zipping around a high hump trans tunnel and sending me the bolt reinforcement on the cab portion . what i need are the bolt reinforcements that are on the surround of the trans tunel for high hump . kind of like the reinforcements on an oil pan corner . i need the perimeter of the hle and i will separate if need be . asking
#33 |
Do you need the perimeter in one piece or is that something that I can cut up in pieces and put in a small flat rate box?
#34 |
no need for one piece - the support all around the perimeter is required and it is where the nut cages if you want to call it that - i do nee the perimeter 2" all around is what im after and then i will separate the support of the nut which i suspect is just spot welded on . and yes it can be in strips or sections just as long as i can drill out and reinstal on my floor and look stock . thanks
#35 |
ray i need the "bullet" peice or the backing of te spot light, i need the chrome ring in front of the light and the bullet shaped peice and the clips that hold the light bulb in place, how much do you want for this? thanks rick
#36 |
![]() Join Date: Feb 2010
Thanks Ray. I'll paypal you for the exhaust in a few minutes. Let me know what your schedule is like for pickup. I am off this week, but the weekend isn't much good for me. I might even be interested in the slider since nobody wants to buy my 67. Frank
#37 |
Is the rear end posi like the label says? Is it for a 72 or the later frame mentioned. Do you know the gears? Thanks
67 C20/ 68 C10 stepside/inline 250--current project 71 GMC 4x4 70 Blazer project-Zombie assault vehicle 67 4x4 Burb ![]() |
#38 |
I'm guessing its a posi, but when I looked, the spring pads are spaced for the square body frame. The front diff looks to have an air locker. I will have to do the math on the gears.
#39 |
Still the same price if the front has an air locker?
#40 |
Frank, I will honor the price. $350 for the pair local pick up.
Thanks, Ray |
#41 |
That is an incredible deal if it is in there. I better stick with just the exhaust though.
#42 |
I'm interested pending confirmation on the posi, locker and gear ratio. Thanks
#43 |
I will confirm everything today.
#44 |
any interest in cutting the trans tunnel Ray?
#45 |
I will cut the tunnel, but do you need it in one piece to weld onto a 2wd tunnel?
#46 |
Aaron in Colorado, Looking for the passenger inner fender. Any good? How much?
thanks |
#47 |
Aaron, I have some good ones. $50 plus shipping. I will have to check if it is feasable to ship these.
Thanks, Ray |
#48 |
#49 |
okay. can you sell them to me for cheaper Ray? I don't want to sound like a low baller but i got my driver side inner fender at the junk yard in better than FAIR condition. for about ($9). Just let me know what you can do Ray?
By the way any rust on the inner fender? |
#50 |
![]() Join Date: Feb 2011
hey doughs it have front disk brakes
