Old 06-25-2011, 06:23 AM   #26
Re: New Slippers
I think there's more to trucks than just lowered ones. I like to see both and this is one that looks great as is. It also is special enough that it deserves preservation. Sure,lowering can be reversed. But,it sure is a good bit of work. Those 70 series eliminate the purpose of lowering for the sake of filling in the wheel wells. There's a certain tradition to these trucks in owners giving them their loving personal touches. There were different looks through the decades and some that are timeless. This truck has that look and shows it proudly. I saw my first lowered 67-72s (Stepsides) in Northern CA in the '70s and caught that bug. But,I also was proud to own stock stance trucks,even C/20s with big/littles which gave them a good bit of rake.
A 4/6 drop is actually 3.5/6. When going to 6 in the rear you are limiting the truck's use due to having a mere inch or so of frame clearance. Not everyone wants to chop a frame for that extra inch. 5" gives a slight rake,which looks cool,allows you to haul a bit,tow,and is also where ECE draws the line for the Super Track bar to be required.
Old 06-25-2011, 07:11 AM   #27
Boog
laying low
Boog's Avatar
Re: New Slippers
Good words for sure.
The best part about lowered springs, spindles and shocks is you can always put it back to stock easy enough as there are no frame mods.
As a kid I bought a lot of 3n1 model car kits. I like the AMT's the best. You had the stock style, hotrod or drag race style and custom style all in one kit. I'd build it one way and sometime down the road change some parts out from the custom or hotrod. Mix n match. That's how I see these trucks. Just bigger sized model kits and easy to change em up. I'm giving thought to adding a fleetside bed too. I already have a stepside. Just to change the look of it when I choose.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-25-2011, 08:52 AM   #28
CG
BlahBlahBlah
Re: New Slippers
Looks great just the way it is. No luck in finding a burb yet?
Old 06-25-2011, 05:33 PM   #29
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: New Slippers
Found lots, but still looking, just haven't found the right one at the right price.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-25-2011, 05:35 PM   #30
Already Gone
Re: New Slippers
Yes I can't believe how much the look of my truck changed ( and I really like it ) by putting the 15 x 8's with the 255/70 tires on it.
Old 06-25-2011, 11:30 PM   #31
crazy longhorn
Fabricate till you "puke"
Re: New Slippers
I am a NUT for dropped trucks,& chopped tops,as well as any other mods you do.....but that one looks sweet "as is" crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
