Old 06-04-2011, 09:09 PM   #26
lil hoodlum
lil hoodlum's Avatar
Re: Very frustrated
The newer wire harness from your dad truck must have been for one with a neutral safety switch (NSS) on the steering column. Those two plugs-ins, purple wires and light green wires, originally went to the NSS.
Those two purple wires must be conected together in order for the truck to start. It is the same purple wire that goes down to the starter.
The two green wires, I believe are for the back up lights.
Hook the two purple wires together from the plug-in from the last picture and let us know what happens next.
Good luck!
Keith
lil hoodlum is offline   Reply With Quote
Old 06-05-2011, 01:36 PM   #27
bosco200
bosco200's Avatar
Re: Very frustrated
Ok I hooked the 2 purple wires together and the engine started to crank!....But it will only crank, it wont start.
bosco200 is offline   Reply With Quote
Old 06-05-2011, 05:09 PM   #28
lil hoodlum
Re: Very frustrated
Check battery and cable conections. Maybe even try to jump start it with another vehicle.
Good luck!
Keith
Old 06-05-2011, 05:11 PM   #29
lil hoodlum
Re: Very frustrated
Sorry, should have asked, does it crank over slowly or does it just crank like normal only nothing happens?
Do you have an HEI distributor? If so, check ignition module under the rotor.
Keith
Old 06-05-2011, 05:41 PM   #30
dmack91
dmack91's Avatar
Re: Very frustrated
Regarding the distributor, if the harness isn't compatible (hei vs. non-hei) with the dizzy, you will have problems. Different voltages to the dizzy for hei vs . non.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 06-05-2011, 10:02 PM   #31
bosco200
bosco200's Avatar
Re: Very frustrated
Yea I was jumping it with another car and it cranks normal...and the distibutor is an HEI im pretty sure
Old 06-05-2011, 10:50 PM   #32
dmack91
dmack91's Avatar
Re: Very frustrated
Maybe a dumb question, but have you checked to make sure you are actually getting spark from your distributor when it is cranking? If something in the electrics is messed up, it may not spark.
Old 06-06-2011, 12:05 AM   #33
BlackTopMotors
Re: Very frustrated
Agree: Hope you get it worked out. Spark confirmation if your are not even getting a bit of a rumble...
BlackTopMotors is offline   Reply With Quote
Old 06-06-2011, 07:13 PM   #34
bosco200
bosco200's Avatar
Re: Very frustrated
FINALLY!!!!! We figured it out.......well I started to take apart my distributer......Ooooo well look what I found here........the last pic was the main culprit, cuz I first just changed the coil and the distributer cap....but then that didn't work so we changed out that module in the 3rd pic......SHES BACK!!!!!
Old 06-07-2011, 03:29 AM   #35
dmack91
dmack91's Avatar
Re: Very frustrated
Great, glad you found it ( and it didn't cost an arm and a leg)!
Good job sticking with it. Now, back to driving it.
BTW, your truck was my screensaver for a while.
Old 06-07-2011, 04:09 PM   #36
bosco200
bosco200's Avatar
Re: Very frustrated
Yeah it only cost me around 60 Bucks....and Thanks I appreciate it.
Old 06-08-2011, 01:14 PM   #37
dmack91
dmack91's Avatar
Re: Very frustrated
OK, I am drawing a blank. What are the first 2 pics from above?
Old 06-08-2011, 04:01 PM   #38
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Very frustrated
Yea just read the whole thing was going to guess it was the NSS. Glad you got it all done and it wasn't nothing spendy good job sticking with it!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-08-2011, 04:06 PM   #39
dougminton
dougminton's Avatar
Re: Very frustrated
I was wondering the same thing.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 06-08-2011, 04:26 PM   #40
bosco200
bosco200's Avatar
Re: Very frustrated
The first pic is the coil and the second is the distributor cap.
Old 06-09-2011, 05:55 AM   #41
dmack91
dmack91's Avatar
Re: Very frustrated
Not used to HEI, so I didn't recognize it. Thanks for the info.
Glad you got your truck back running again.
