Old 04-01-2003, 03:29 AM   #26
MSL
MSL's Avatar
Ya mines stock to not much to brag about im not sure if you can see it very well.
MSL is offline   Reply With Quote
Old 04-01-2003, 03:41 AM   #27
Mike76251
MSL,
That is a good looking interior indeed.
It is hard to beat GM on interior designs though some try hard.
Mike76251 is offline   Reply With Quote
Old 04-01-2003, 03:51 AM   #28
MSL
MSL's Avatar
Thanks.
The interior in my truck is in really good condition. im suprised the dash is only cracked by the speaker section . other than that everything is minor.
Old 04-01-2003, 08:43 AM   #29
bigblock73
yeller
bigblock73's Avatar
here is mine currently...
bigblock73 is offline   Reply With Quote
Old 04-01-2003, 09:48 AM   #30
Low87
been here longer than Liz
Low87's Avatar
Not much going on.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-01-2003, 09:49 AM   #31
Low87
Low87's Avatar
door
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-01-2003, 09:50 AM   #32
Low87
Low87's Avatar
seats
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-01-2003, 09:53 AM   #33
BigRed
Hey, I have one that looks like that! But it's not painted yet.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 04-01-2003, 01:11 PM   #34
PHOENIX
Keg Keg Keg ! ! !
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 04-01-2003, 01:53 PM   #35
bigblock73
yeller
bigblock73's Avatar
Mine really isn't painted yet either, that is a pic after I took it all apart. I hope to get it painted in the next month or so and back on the frame.
...hopefully I will remember where all the stuff goes and how it bolts together!
-Jeff
Old 04-01-2003, 05:56 PM   #36
bagged81
Signals in the bumper.
bagged81's Avatar
Thanks everybody. I see some things that I like.
For those of you with floor shifters, what did you do about your column shifter. Did you get another column of just remove it?
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 04-01-2003, 06:04 PM   #37
TIMSPEED
TIMSPEED's Avatar
Most of the time when you go from Column shift to floor, you just get a column from a manual tranny car/truck.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 04-01-2003, 06:20 PM   #38
PHOENIX
Mike (Swervin) mounted a shift light on the column so that it would cover the hole from the column shift. Damn good idea Mike!
Mikes Install
Old 04-01-2003, 09:50 PM   #39
low 84
low 84's Avatar
i just removed the pin that holds the shift lever in and took the shift lever out, so i have a hole in my column, same place mike put his shift light.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-01-2003, 10:13 PM   #40
Mike76251
You might could take the column out and grind off the excess, and then braze that hole shut. Finish with a little bondo and some gloss black paint.
Just a thought and it would save you from having to find another column.
