#26 |
Re: New look Glove Box Lid
What clear coat did you use? I've heard some people say that clearing bare metal can discolor and leave a yellowish brown color.
#27 | |
454 MAKES IT ROAR
I've now done the ash tray and had already tackled the door panels at the same time as the glove box but wasn't going to post em as i'm not to happy with the end result....they had rusted and were damaged on the outer edges and corners, even with a massive amount of grinding and sanding the pitting was too deep. Anyway here they are for what they're worth.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#28 |
needs more $$$
Love it! Can you post what you're using to remove the paint? Is it something you're putting on an angle grinder?
My lid is chrome, but it's horribly scratched...do you think the disk will remove it? I'm going to the yard tomorrow, so if not, I'll just pick up another one while I'm there.
1970 2wd Blazer |
#29 |
wow nice job man, you sure dont waste any time... what would it take to get you to send me a cockgrease sticker.. i gotta have one...
The two most important lessons to wrenchin'-1.The only time you have too much fuel is when you're on fire-2. If something hasn't broken, it's about to-- |
#30 | ||
454 MAKES IT ROAR
Here's a link, it's a U.K site you can see what they're like....but they are available in the states. http://www.frost.co.uk/automotive-cl...e-grinder.html Quote:
#31 |
needs more $$$
Thanks eight!...I have to find one for my angle grinder...I've used one on my cordless drill, but the batter doesn't last long enough. I just wanted to make sure it was the same thing. I can't wait now!
1970 2wd Blazer |
#32 |
Cruzin
where did you get the chevy script from? lovein the look, thanks
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#33 |
great idea that will look awesome with the dark gun metal gray i am planning.
#34 |
Posted deleted... already answered my question
------------------------------------------------------ 1968 Chevrolet C10 - Needs lots of love 1996 Chevrolet S10 Born and raised on the east coast ![]() Last edited by Papa-J; 06-11-2011 at 09:37 PM. |
#35 | |
454 MAKES IT ROAR
Holts Dupli Color rattle can, only a couple of heavy coats as it's all inside.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by gcburdic; 06-12-2011 at 01:41 PM. Reason: fixed the ebay link:) |
#36 | |
Still plays with trucks
The rings could be made to accept the stock size of common aftermarket gauges. The rings could be clamped in place from the back side or even welded to the back of the panel for a seamless look on the front face. The stepped flange on the machined rings would hide the cut line on the lid so it would not be visible or need to be perfect. You could even weld mounting studs to the back of the lid so aftermarket gauges could be mounted from behind. With a fabricated support & reflector housing any other factory gauge could be made to fit as well. Third gen F-body gauges are very plentiful and inexpensive too. This is the route I am looking at going. If you cut the glove box door to match the stock configuration of a third gen factory cluster then the hard fabrication of the reflector & support housing is eliminated. All you need are the machined gauge panel rings in the right sizes to match the cluster of choice. Here is an 82-89 Camaro cluster set in the dash of my 67. You can see it fits & lines up pretty well and could be made to work. You can find speedos from 85, 115 to 140 mph and even get 4, 6 & 8 cylinder tachs. The 4 cylinder are hard to get but would work for an LSx swap. If I had access to a mill & lathe I would have this done already.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
