Old 08-24-2011, 07:08 AM   #26
rsavage
rsavage's Avatar
Re: 307 tbi
My 70 Burb was sold and in and came from California. It came with a factory 307.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 08-24-2011, 07:16 PM   #27
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: 307 tbi
The 305 is a smog motor, while the 307 was just a "base" V8. 305's un-smog pretty easy though, with higher compression pistons and a stock pre-smog cam.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-24-2011, 09:47 PM   #28
capev86
Re: 307 tbi
a 307 is same crank and cam as a 327 so yes a nice start.
a 327 makes sense in a lightweight drag car. but it's little brother, the short stroke 307 is tuned to act like a low rpm engine in this application. better than the 265 and 283, but still not well suited to a heavy truck. the engine is fighting itself.
would rather have a 305 (same crank as the 350) in my 72 burb c20 instead of the 307. but the motor is original, runs great now that the 2bbl is bye bye and a q-jet is in it's place. when the day comes that the motor needs a freshening, it is getting a 400sbc stroker kit and full roller RV grind valve train for REAL towing power.
certainly an interesting, unique project, but it would have been much easier to swap a 350tbi engine in and gain performance as well as efficiency. plus, the old engine doesn't have all the sensor ports needed for fuel injection and then there is the tuning issue as there never was a 307tbi calibration from GM. good luck!
capev86 is offline   Reply With Quote
Old 08-24-2011, 10:27 PM   #29
Kidd-7
Kidd-7's Avatar
Re: 307 tbi
Great info here. I have a 307 myself and want to freshen up some. Like the different stuff.
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
