06-17-2011, 02:17 PM | #26 |
and a few others
Re: Need some stance pics with jeep springs and coil cut
Handled fine. I actually sold that truck a little over a year ago, it's in Norway now. I don't know about the Burbs and I never tried hauling any weight with it, but I doubt they'll handle the extra Burb weight well.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
06-17-2011, 04:02 PM | #27 |
I reallly like the look of the white truck man there is just something about it
06-17-2011, 05:43 PM | #28 |
06-18-2011, 03:54 PM | #29 |
so how many coils out of the rear coils did you cut. I'm getting ready to cut mine now.
06-18-2011, 08:06 PM | #30 |
Not sure but the back is really easy to do incrementally. Start with a little and do more until you like it. Hardest part is the first cut because of the lower bolt...
06-18-2011, 09:47 PM | #31 |
I was thinking of leaving the bottom coil and bolt to use as a lateral stay for the coils.
06-19-2011, 10:29 AM | #32 |
06-19-2011, 10:59 AM | #33 |
Why not just buy drop springs? They are a hundred bucks a pair?
Posted via Mobile Device |
06-19-2011, 12:12 PM | #34 |
Grandpa in the rustmobile...
TJ springs wont work. You can put 50lbs in the bed and its on the bumpstops.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-19-2011, 12:12 PM | #35 | |
This thread was not started to debate the merits of one vs. the other. If you would like to have that discussion please feel free to start a thread on it. |
06-29-2011, 01:29 PM | #36 |
I posted this in another thread but I'll repost it here. I had a thought that maybe a set of Moog cargo coils from a Chevelle wagon or 1977 to 1996 Caprice wagon may work. They have a progressive rate spring wrap. I included the 1977 and up Caprices because they are roughly the same wheelbase as Chevelle wagons (116") although my guess is the Caprices are a little heavier than Chevelles. This would give you some variables to play with and adjust ride height. A spring company online may post the dimensions and weight capacities of these springs for comparison purposes.
As a side note, I had an old set of pickup springs I installed in the back of my Chevelle once to try to lower it. It was a disaster! The truck springs are shorter than the Chevelle springs and it gave very little suspension travel and rode like a truck, |
06-29-2011, 02:58 PM | #37 |
so for the jeep springs do you use (4) rear spring for all around the truck or just (2) for the rear?
06-29-2011, 09:27 PM | #38 |
you just use rear tj springs
06-29-2011, 10:10 PM | #39 |
There are four different versions of the springs that were used from 1997 through 2006. These are the ones that can be used on the C10. Similar rear springs could be found on the Jeep Grand Cherokee ZJ. All four versions are the same length wise but vary in rate.
The only way to tell them apart is by the color coded tags that are on the springs from the factory, they read as follows: 103AA (or 3AA) 130lb. 104AA (or 4AA) 140lb. 105AA (or 5AA) 150lb. 106AA (or 6AA) 160lb. The colors on the tags can vary and the rates are "ball park" hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
06-30-2011, 01:52 PM | #40 |
yeah that helps, but i guess i didnt word my question well, i was asking if you use the rear tj springs for the front and rear of the c10 truck or just the rear
06-30-2011, 07:28 PM | #41 |
Will the springs work on a c20?
07-01-2011, 12:10 AM | #42 | |
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348 2001 Suburban daily driver 2008 HHR (wife's ride) |
07-02-2011, 05:59 AM | #43 |
Redneck Hillbilly
From my experiences in cutting coils, every full coil you cut from a non stacked spring nets between 1.5 and 2 inches of drop. Stacked coils only yeild the difference of the thickness of the coil material.
12-05-2011, 07:06 AM | #44 |
Seeing as there are different spring rates on the jeeps are y'all using the srings out of the 4cyl or 6cyl jeeps? I assume the 6 but would like to know before I try to locate a set at the local 4x4 shops.
01-03-2012, 11:28 PM | #45 |
hey rannos, i honestly dont think there is a difference between them, i may be wrong but i had talked with a couple guys about it and it was never mentioned. im picking up my next truck, a '70 swb and i have already picked up a set of jeep springs, mine are actually off a jk. im gonna cut a full coil or 1 1/4 off the front and see how it goes.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
01-04-2012, 12:00 AM | #46 |
Dont bother with the jeep springs-save for drop blocks or dropped springs.
They lower the truck but're wayyy to soft. I went with a 2" drop block, only complaint was that the U bolts hang WAY low.
01-04-2012, 01:07 AM | #47 | |
01-04-2012, 12:03 PM | #48 |
okay.
Lmk, I have some jeep springs and some u bolts for a 1.5" drop block u bolts are new
