Old 01-30-2012, 06:36 PM   #26
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Some progress pics.
shot some high heat primer followed by some black, starting to make some progress on this one again
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 01-30-2012, 08:50 PM   #27
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I can't edit previuos post to add pics. I am gonna get some different valve covers. It has been a while since I have reinstalled heads. What type of thread selants do I need and does I still need that copper spray of do the new gaskets eliminate the need?
Old 02-06-2012, 12:31 PM   #28
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Hunting a head bolt and then everthing gets buttoned up. What can I use to clean the old fluid out of the inside of the pump?
Last edited by BB72CHEVKT; 02-06-2012 at 12:38 PM. Reason: spelling, add pic and info
Old 02-06-2012, 08:51 PM   #29
jbclassix
Junk Yartist
jbclassix's Avatar
Take it apart by removing the fitting and the 2 studs... the re-seal kit is 7 bucks and WORTH IT'S WEIGHT IN GOLD over and over again! You can then wipe out the sump and clean off the pump.
Once it is installed, use Dextron, not power steering fluid.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 02-07-2012, 01:30 PM   #30
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Is a puller of any type needed or does it just come apart? Thanks KT
Old 02-07-2012, 08:43 PM   #31
jbclassix
Junk Yartist
jbclassix's Avatar
not to remove the tank
-Jeremy
Rebuilding an NP205
Old 03-21-2012, 05:41 PM   #32
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I am getting a little closer. I had to go ahead and buy a new gas tank and it arrived yesterday. Here we are as of right now.
Old 03-24-2012, 08:03 AM   #33
rsavage
rsavage's Avatar
Looking good!
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-25-2012, 12:55 AM   #34
jbclassix
Junk Yartist
jbclassix's Avatar
did you end up re-sealing the power steering pump?
-Jeremy
Rebuilding an NP205
Old 11-19-2012, 08:05 PM   #35
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
The next time I see the burb it should be a running driving truck with a 4.5/6" drop. Very excited.
Old 11-19-2012, 11:07 PM   #36
gringoloco
A guy with a truck
gringoloco's Avatar
That is exciting! What components are you using? C-notch? Motor looks good, too. Based on the wet pics, this one needs the CLR treatment and a good wax/buff
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-20-2012, 11:49 AM   #37
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
It do believe the CLR treatment is in its future. I robbed some parts that were intened for the SWB so it is a little mix and match.
Suspension:
ECE spindles
ECE super track bar
CPP Drop trailing arm cross member
CPP Billett carrier bearing
KYB shocks
Brothers 2" front & 4" rear spings (2" drop blocks from Boris)
ECE lowered front sway bar
ECE shock relocators
CPP C-notch
Brakes:
All new lines and all new stock componets for brakes.
new rotors
new calipers
all new hoses
new bearings
new drums and wheel cylinders
pads and shoes
new CPP master cyl,prop valve, booster set up
Rebuilt entire front suspension and new trailing arm bushings.
I am adding a rebuilt tilt with Camaro comfort grip wheel. We are also replacing the TH350 with a 700 R-4 using CPP tranny mount and bushing with new cooler and lines. I am also going to run the same Maradyne electric fan set up Mike is running on Cloud 9 and installing new gas tank and lines. I am keeping my fingers crossed that there are no motor probs but the motor is clean on the inside. If it does have some kind of major engine problem I will replace it with a 260 hp GM crate.
Old 11-20-2012, 03:13 PM   #38
CLTBurban
CLTBurban's Avatar
Can't wait to see it! Which gas tank are you going with?
'72 GMC Suburban 1/2 Ton (Red)
'68 C10 Short Fleet (OG 503 Light Green and Patina)
'70 C30 Dually (OG City of Charlotte Welding Truck)
Past 67-72's Chevy Trucks
'68 C10 Short Fleet on 20" Coy's, '72 C20 Suburban (Ochre Big Block), '69 C20 Suburban (Silver), '69 C10 Suburban (Red/White on Boyd's), '72 C10 Short Fleet (Ochre on Torq's), '70 C10 Short Fleet (POS)
CLTBurban is offline   Reply With Quote
Old 11-21-2012, 04:07 PM   #39
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I can't remember where I got the tank from but it is an OEM replacement.
Old 11-21-2012, 07:28 PM   #40
gringoloco
A guy with a truck
gringoloco's Avatar
Sounds like a good mix of parts- keep the updates comin'
-Chris
Old 11-27-2012, 04:19 PM   #41
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Shop called and said they feel unsafe hooking the battery up due to the wiring. Could be as much as 20-25 hours to replace wiring in entire truck plus the harness which aint cheap. Hope the motor is ok after all this is done.
Old 11-27-2012, 09:47 PM   #42
Tinkermc
lookin goood
Tinkermc is offline   Reply With Quote
Old 01-10-2013, 09:24 PM   #43
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
She is home. I need to take it to get the exhaust done and then it is ready for a test drive. I am pleased with everything I have seen so far. I had a short amount of time before it got dark and did not get pics. The stance turned out to have less of a rake which is good. I will have to see if I want to go a little lower in the back.
Old 01-14-2013, 11:55 AM   #44
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Well I got the exhaust done and now I am having a problem getting fuel from the new tank and lines. I thought it might be the pump so I replaced that and no luck. I have run it up to 15 minutes with a fuel line dropped in a gas can but when I hook it up to the tank it will run for a while and then die from lack of fuel. I can then drop a line back in the can and it will fire right up. After that I can hook the line to the tanks back up and it will run for a while and then die again. I have blown air from the line at the pump back to the tank and you can hear the air bubbling in the tank. It is like it can not keep suction from the tank. It is running well when it gets gas. The shop ran a rubber line from the tank to new hard lines on the frame and I can not see where it connects at the top of the tank so I hope there is not a kink that requires the tank to be dropped.
Old 01-14-2013, 12:06 PM   #45
rsavage
rsavage's Avatar
Is the cap on the tank when running and it dies? Just wondering if it is forming a vacuum in the tank with a non vented cap that the fuel pump eventually can't overcome.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-14-2013, 12:10 PM   #46
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I forgot to mention I have run it with the cap off the tank and experienced the same problem. I am open to suggestions.
