Old 07-04-2011, 07:44 PM   #26
pat 70/71
pat 70/71's Avatar
Re: how about some pics of inline 6 engines
I've got two! one original and one with only 60k on the clock and I love them period! great motors, have 2 v8s 2 six sillys the silly that has 60k on it I got it just for time it took to pull it! I love em because their so simple! cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 07-04-2011, 10:06 PM   #27
68 IRON
68 IRON's Avatar
Nice build Shaky! It will still be running 40+ years from now!!!! Don't they look great all dolled up....for show or go?!?
68 IRON is offline   Reply With Quote
Old 07-05-2011, 02:57 PM   #28
Shaky
Six in a row makes it go...
Shaky's Avatar
That's the idea - to have it purr and run it for a long time. It's going in my '66 C10 with a Richmond 5-speed and 3.07 rear. Lots of cruising.
Just to finish off what the shop did: Comp Cams cam (1 level up from stock but still torquey), one-piece hardened push rods, Comp Cams (thicker) rocker arms, metal timing gear set, Sealed Power pistons, positive valve seals, and new everything else. They also cut the all the sealing surfaces between the head and the manifolds.
I just started putting the manifolds on, the fuel pump, water pump, etc. this past weekend. I'll get a pic soon, In the meantime, here it is after paint:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-19-2011, 06:19 PM   #29
Shaky
Shaky's Avatar
Got it built-up some more. There's always some little thing that holds you up. I need to get a speedi-sleeve for the balancer before I go further.
(The water neck is on backward so I remember to put some coolant in the block before starting it)
Old 07-19-2011, 07:24 PM   #30
redmonster
redmonster's Avatar
this is what mine looks like currently
WITNESS
Dont be like me be better than me
redmonster is offline   Reply With Quote
Old 07-19-2011, 07:25 PM   #31
redmonster
redmonster's Avatar
now that we on the topic can someone tell me how to fix the scream which my belt produces
WITNESS
Old 07-19-2011, 09:28 PM   #32
68 IRON
68 IRON's Avatar
Shaky, what did you use to paint the manifolds? And is that a script chevrolet I see on the valve cover? I need one of those!
Redmonster....lose some weight. Just kiddin' could be 3 things 1) loose- not tensioned properly 2) worn out or 3) routing - not touching at high enough angle to really grab the belt (not as common). Give us a pic of the belt and pulleys. And when it screams at you...start up, only whens its cold, turning hard...? Others will chime in and give their advice.
Old 07-20-2011, 03:34 PM   #33
Shaky
Shaky's Avatar
I used the Eastwood high temp stuff. My buddy had good luck with it on his (yuck) Jaguar manifold, and the guys at the machine shop said to use it. We'll see.
I don't know what years the script came on those valve covers, but I scored one off my buddy years ago and like the way it looks.
Old 02-18-2012, 11:11 AM   #34
VWNate1
VWNate1's Avatar
Thumbs up Re : Pix Of InLine 6 Bangers
GREAT THREAD ! . a buddy just hipped me to this as my poor old survivor '69 C/10 was FU-BAR under the hood thanx to some bubba idiots in TEXAS , I've been chasing down the little bits 'n bobs that make it run ' Just So ' and also make the old die hard 6 Banger guys like me , smile .
I'll see about getting some pix up here soon .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 02-18-2012, 01:02 PM   #35
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Does this count? 1968 250 out of a truck. Haven't decided what to put it in yet. Would like it to go in a 49 Chevy Fleetline, but may go in a truck.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-18-2012, 01:04 PM   #36
Jimbabwe
Jimbabwe's Avatar
Here's mine.
Jimbabwe is offline   Reply With Quote
Old 02-18-2012, 03:56 PM   #37
54blackhornet
54blackhornet's Avatar
Have any of you guy's installed a clutch fan on a 292 ? if so what brand, someone told me it would cut down on the noise the standard fan makes when you are running down the road at speed. Also looking to install a fan shroud for a 292 but have never been able to locate on....thanks for any help...
54blackhornet is offline   Reply With Quote
Old 02-18-2012, 05:04 PM   #38
Achevytruck
Great looking pictures ever one and how hard would it to be to find the power brake sep up and the inline six air cleaner
Achevytruck is offline   Reply With Quote
Old 02-18-2012, 08:05 PM   #39
Jimbabwe
Jimbabwe's Avatar
Does anyone have any info regarding the (I'm guessing) air pump thing in my picture in post #36 ?(two back) I never see this on any other straight sixes.
I was wondering where I could put a power steering pump, having this pump up top and the alternator below. A friend says I should leave it on because it's cool because you never see them, and the motor runs well with it on there, so...
Old 02-18-2012, 10:11 PM   #40
blkcorvair
blkcorvair's Avatar
Heres mine before I started putting the body on.
blkcorvair is offline   Reply With Quote
Old 02-19-2012, 12:38 AM   #41
VWNate1
VWNate1's Avatar
Post Re : Power Brakes
Easy to find used in junkyards , I bought a new one complete from Rock Auto for less than $200 delivered to my door , power brake can with bracket , master cylinder and proprtioning valve , the whole enchilada .
The air filter can is out there , there are several different ones , I have a few spares when my truck is finished I'll sell them .
-Nate
Geezer
Old 02-19-2012, 12:43 AM   #42
VWNate1
VWNate1's Avatar
Post Re : Air Injection Pump
It is the "Air Injection Reactor " system that pumps fresh air into the exhaust ports where any unburned fuel *instantly* burns , reducing exhaust emissions.
It's a simple basic system that works BUT , the cold air blowing against the back of the red hot exhaust valves , sometimes causes them to warp .
You are correct , it's getting hard to find the entire system anymore and it's fairly simple to disable the air blowing so it just looks neat , I'm searching for all the various parts now as I'd like to replace it in my '69 C/10's 250.....
-Nate
Geezer
Old 02-19-2012, 07:39 AM   #43
'68OrangeSunshine
'68OrangeSunshine's Avatar
As far as I know, "there ain't no such animule" as a fan shroud for the L6 engines. They all had "Finger Guards" which is a piece of bent sheet metal that bolts onto the radiator support and extends down about 6" over the fan to keep all but the most dedicated idiot from losing his fingers.
This is not to say a fibreglas/plastic fan shroud from an SBC set up wouldn't fit in that spot.
As far as the clutch fan idea, it might work out OK. I've been using a FlexFan on my 292 since 1977 and have not had a problem yet. [And I live in Ariz.]
Old 02-19-2012, 11:41 AM   #44
VWNate1
VWNate1's Avatar
Post Re : Topic Drift : Fan Efficiency
You needn't run any fan clutch , just be sure to shim the fan so it's 1" from the radiator core to ensure it's drawing air through the radiator at low speeds or when idling in traffic .
Lucky for us , the fan spacers are standard bolt spacing so they're available cheaply new or nearly free in junkyards .
These thin wall L6 engines really don't ever have overheating problems unless something is seriously amiss , ignition timing far off or rust & scale clogging the radiator tubes or silt in the water jacket from long disuse ~ cleaning is dead simple : use Citric Acid powder mixed one pound per gallon of distilled water and drive it to work and back for a day , the amount of crud that comes out when you flush this will amaze you . far better than any flushing stuff in a can from your FLAPS and cheaper too .
Flex fans are very nice as they not only give back a tiny bit of power but they're also very quiet .
For hard working Desert rigs , delete the fan and replace it with an electric fan , use a relay and temp switch in the thermostat housing , wire it live so it can switch on and prevent heat soak .
-Nate
Geezer
Old 02-19-2012, 02:22 PM   #45
Jimbabwe
Jimbabwe's Avatar
Re: Re : Air Injection Pump
Thanks! Good to know about the warpage issue. Maybe I'll go ahead and disable it. Good luck with your search. I'll keep my eyes open for you.
Old 02-19-2012, 03:22 PM   #46
VWNate1
VWNate1's Avatar
Post Re : AIR System
All you have to do to disable it , is remove the drive belt , as it drives nothing else , no harm no foul .
If I re install it to my '69 , I'll want the belt in place and so will block the air flow .
-Nate
Geezer
Old 02-19-2012, 04:03 PM   #47
Achevytruck
Ever one really good info and i did find a chevy inline six eng fan shroud for a good deal and far as the power brake set up and air cleaner for it i keep looking i guest
Old 02-19-2012, 04:35 PM   #48
54blackhornet
Thanks for the Fan info, have seen 6cyl shrouds ! If you install an electric fan do you mount it in front or back of rad for best air flow ?
Old 02-19-2012, 07:06 PM   #49
VWNate1
VWNate1's Avatar
Post Re : E fans
O.K. , get ready , here's comes the firestorm from folks who failed 7th Grade Physics .
It makes NO DIFFERENCE pusher or puller ! .
As long as it's moving air through the core , it works .
There's a lot of mumbo-jumbo out there pushed by folks who either want to sell you something expen$ive or want to feel good about having paid WAAYYYY too much $ .
Look at it this way : if it made any difference , would manufacturers ever use one over the other ? of course not , that's why million dollar Ferraris , Lambos and so on , all use pusher fans , your (yawn) belly-button SBC will love the E-Fan better than any mechanical fan , mount it wherever you please .
I don't like looking at them so I tend to mount them pusher style .
Flame Suit on , have at it guys .
-Nate
Geezer
Old 02-20-2012, 10:17 PM   #50
'68OrangeSunshine
Hey! It occurred to me that I never did post any pix of my L6 292, So here goes:
