#26 | |
![]() Join Date: Jun 2011
Re: my 1965 C10
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
#27 |
Re: my 1965 C10
Looks sweet, I also have a 65 very similar. What is that bar on the floor with the small handle on it?
Posted via Mobile Device |
#28 |
Re: my 1965 C10
i think you are talking about the jack hold down
#29 |
Re: my 1965 C10
Yeah that would make sense, I have the hook on the floor but no jack or handle, thanks
#30 |
Re: my 1965 C10
i painted my sun visors to better match the interior. i used the same colors as i did on the door panels
#31 |
Re: my 1965 C10
here is a couple of pics of the trucks current state. i just did the big back window and had all the body holes welded in.
#32 |
Re: my 1965 C10
#33 |
Re: my 1965 C10
just had the background plate and outer bezel powder coated in satin black with a new lens also.
#34 |
Re: my 1965 C10
#35 |
Re: my 1965 C10
what did the vacuum come out of? a c30?
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#36 |
Re: my 1965 C10
i bought the cluster on Ebay but im sure it was standered on the c30 and up. the vacuum gauge in this cluster is new old stock and i paid for it. took me ten months to find.
#37 |
Re: my 1965 C10
finally installed the new cluster last night.
![]() ![]() i put the old one on ebay since i dont need it anymore.
#38 |
Re: my 1965 C10
#39 |
Re: my 1965 C10
I like everything about your truck and nice BBW conversion, looks good!
#40 |
Re: my 1965 C10
#41 |
Re: my 1965 C10
#42 |
Re: my 1965 C10
#43 |
Re: my 1965 C10
i got this idea from Jocko. as most of you know seat belts were not standard until 1966. but before then they were an option. i really wanted retractable seat belts but still keep the factory look. so this is what i did today.
note: where i drilled the anchor holes there was a small circular divot on each side of the cab. I'm assuming it is a drill point mark for the installer back in the day for the customer that paid for the optional seat belts. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#44 |
Re: my 1965 C10
#45 |
Re: my 1965 C10
thanks for the compliments i really do appreciate them. im on a pretty tight budget and this is my daily driver so i can only do a little at a time.
#46 | |
Re: my 1965 C10
When I restored my instrument cluster, I lined the cardboard tube with silver foil tape. This increases the brightness. It will work for factory bulbs or LED too. You can see the same photos in the Tips and Tricks section of my website. ![]() ![]() ![]()
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#47 |
Re: my 1965 C10
i bought the L.E.D.`s off eBay and they are a direct replacment. it was easy. they are slightly brighter when installed and much whiter than incandescent bulbs.
#48 |
Re: my 1965 C10
Jim,
Is that stock patterned material on your seat? It looks very similar to my 2011 F-150 at work. Thanks, Brian Posted via Mobile Device
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
#49 |
Re: my 1965 C10
i modeled it of the original deluxe seat but with different material. i got the idea from Dino mine is just like one of his.
#50 |
Re: my 1965 C10
found a polished aluminum grille. i took this opportunity to paint behind the grille the correct looking satin black pattern. first cleaned it up some then taped it off. i used semi gloss as a base coat then satin black as a top coat. really has the right sheen when i do it this way. right after paint pull the tape. you don't want to wait until its dry or it could pull some of the new color off. i sanded off the paint in the six bolt locations for the grille so the headlights would have a good ground.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 05-25-2013 at 07:56 PM. Reason: add |
