Old 07-20-2011, 07:10 PM   #26
Burb
Coordinator of Synchronicity
Burb's Avatar
Re: Bagged My 71 Suburban
Great job Scott ... heading to bags on my Burban too, adding the 3/4 ton challange to the mix.
What wheel and tire size combo are you using, cause they were made for that stance?
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 07-20-2011, 09:03 PM   #27
salvo
salvo's Avatar
Thanks Rick, they are 20X8.5 Boss 338 rims.
Rear: Good Year Eagle GTII 285/50 R20
Front: Good Year Eagle GTII 275/45 R20
HighlanderBrad gave me the #'s he used on his Suburban. I needed to use 5/16" spacers up front due to the rim hub being a bit small for 71 disc brake rotors. According to HighlanderBrad 88 and up rotors swap out and will work without spacers. I think Boss 338 have a rim that will fit the older rotors now.
I also pushed the rear rims out 1/2" with spacers and new 1/2" longer lugs. I was getting a little rub around corners before I had an adjustable track bar and lowered it, but I do like the way they center in the rear wheel well with the spacers, so I'll keep the spacers in the rear and get newer discs the next brake job.
Scott S
54 Chevy Pick-Up
71 Chevy Suburban
76 FJ40 LandCruiser - 454, TH350, NP205, Ford 9"
98 Dodge Ram 2500 4X4 Cummins
salvo is offline   Reply With Quote
