#26 |
![]() Join Date: Aug 2010
Re: Diversification is good!!
#27 | |
It's hard to tell exactly how they were originally fit into place because most all have suffered the effects of gravity over forty five years. What appears now as a soft rolled corner, may just be sagging cardboard.?? Were they crisply formed with straight hard corners, or just loosely bent to tuck into the sides of the cab? Can you tell? The reproductions are lacking creases and give no directions or even suggestions on how to install them properly. |
#28 |
you doubled your money and the next guy still got a killer deal..nice!
#29 | |
![]() Join Date: Mar 2011
#30 |
Is that a new floor mat you put in, or is it just cleaned up? If it's new,
what vendor did you use. It looks good. ![]()
Members i've met: LiLRed66 |
#31 |
That was the original mat. I washed it with all purpose cleaner, used sheathing grade tuck tape on the back to hold together a few rips. There was only two of them. Then I liberally coated it with meguiars vinyl cleaner. It turned out wicked.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
