07-01-2011, 11:50 AM | #26 |
Senior Car Nut
Re: lowering 62 with torsion bars
also, a word of caution: if the bolt breaks while you're trying to turn it, you can get hurt. there's a thread on the forum somewhere where someone cites his personal experience with this.
I plan on unloading the bars (moderately) on my '61 along with drop spindles after my '66 truck and '48 coupe are "finished"--possibly in the next century.
Larry |
07-03-2011, 05:38 PM | #27 |
Looks like mine was lowered using the bars by the previous owner, also noticed my bolt is serverly bent, has anyone replaced a bolt on these? or know what size it is, or have any suggestions? I dont even know if I can get it out unless maybe I cut it...may be dangerous though
07-03-2011, 07:04 PM | #28 |
When I took my torsion bars out I just raised the front off the ground so the wheels were hanging and all the torsion was released from the bars so it was not dangerous at all. I would also suggest using drop spindles at the same time as lowering using the torsion bars. It worked grate for me and you don't have to worry as much about the bump stops but then you have to switch over to disks.
07-03-2011, 08:00 PM | #29 |
forest, thanks for the info, sounds like I will be raising it off the ground then, I plan on using drop spindles and discs, the thing is I wanted to raise to torsions back us some as the previous owner drop it as far as he could. but with that bent bolt it seems I will need to replace it. Where can I get a good grade bolt and what size will I need, anybody know?
07-03-2011, 09:47 PM | #30 | |
07-04-2011, 11:57 PM | #31 |
Grumpy?????
Posted via Mobile Device |
07-05-2011, 12:08 PM | #32 |
Sorry dude...
Been thrashing on current 66 short fleet to make Goodguys this weekend. The red truck had the torsion bolts backed out until the last thread was even with upper blocks. That make sense? Once you feel up under the truck, you'll understand. The bumpstops were completely removed. And I bought a pr of mini-truck Toxic Shocks from Summit that worked well. The bolts drug on the ground much more often than the front bottomed out.
Tim Road Hounds |
07-07-2011, 03:09 AM | #33 |
No problem. Thanks for the reply. What length spring was on the rear? Got the front done, although not as low as that truck, it has a nice "rake".
07-07-2011, 09:51 AM | #34 |
"Where were you in '62?"
Cut her off and use a Mustang II IFS Clip with Heidts Coil-Over Shock and Springs! Teehee
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
07-07-2011, 07:10 PM | #35 |
07-07-2011, 09:56 PM | #36 | |
It's kinda labor intensive. But not to bad. But I had to get rid of that front end! I don't like torsion bars and self adjusting brakes! She lost some weight during the transplant. Now she is hunkered down low with a nice stance, soft smooth ride and the correct geometry. One of the most common of all modifications to an early truck, car, street or hot rod is the installation of a Mustang II independent front suspension. http://www.customclassictrucks.com/t...#ixzz1RTRrHJCT http://www.hotrodssuperstore.com/quesanabifsk.html
07-07-2011, 10:05 PM | #37 |
1960-62 Front Suspension Upgrade
http://67-72chevytrucks.com/vboard/s...d.php?t=366828
07-10-2011, 12:39 PM | #38 |
That is definitely in the near future with bags. For now I just wanted a lower stance until I get to California.
08-13-2011, 11:25 PM | #39 |
does anybody have pics of where the bolts are?... i can't seem to find them... the PO lowered the truck already, but i want to go lower...
08-14-2011, 06:32 AM | #40 | |
I'd suggest soaking the assembly with PB Blaster 1st..if you're doing it in your driveway,put something on the ground underneath, PB eats pavement. |
08-14-2011, 01:41 PM | #41 |
Senior Enthusiast
08-14-2011, 04:39 PM | #42 |
^Excellent^
I need to pickup a factory manual. |
08-15-2011, 03:06 PM | #43 | |
Thanks for posting!
08-15-2011, 05:18 PM | #44 |
Who Me?
Subscribed again. Thanks for the info..
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
09-02-2011, 02:01 PM | #45 |
this is how we ended up lowering it
09-02-2011, 02:45 PM | #46 |
Who Me?
So are you still gonna use tortion bars or put bags in there?
09-02-2011, 02:51 PM | #47 |
I lowered mine with just the adjusters .. Still rides nice , but was looking at the lowered spindles also ... But I've noticed around here my is low enough as it is , the drives at alot of the local business'es and man hole covers sometimes worry me if I go much lower .. It doesn't even look like my truck is that low ... Good Luck with the build , Keep the pictures coming !!!
09-02-2011, 03:39 PM | #48 |
09-02-2011, 03:45 PM | #49 | |
11-03-2011, 03:01 PM | #50 |
Stirrer of the Pot
who sells drop spindles for the 60-62's?
