Old 06-29-2011, 06:35 PM   #26
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Will a spray-on bedliner de-value my truck?
I had mine sprayed with Vortex. Do I consider it to be devalued? Nope. Would I discount it? Nope.
Rubber mats retain moisture beneath them, if it rains, or if you wash it...you get the drift. That moisture can become rust, if conditions are met. Drop-in liners are not an option.
Spray-in materials can also be used for sound deadening, inside the cab. Same material....does that decrease the value? If you look inside a cab and see that material, are you thinking that it is there to hide something? Or, are you thinking, "Yeah, that's a smart thing to do!"
We're a fickle bunch, when it comes to our trucks....
Member Nr. 2770
Old 06-29-2011, 06:42 PM   #27
mbgmike
I'll through in my 2 cents. I have seen some awfully nice high dollar trucks that have them and it would not stop me from buying one or try to lower the price because of it. They were 30,000 to 40,000 dollar trucks. None were stock so I think they looked great. If a 100% correct restoration or a super clean original is what someone wants it makes sense to not do it. I agree its up to the owner. there are a lot more things done to trucks that de-value it then a bed liner.
mbgmike is offline   Reply With Quote
Old 06-29-2011, 06:45 PM   #28
lil hoodlum
lil hoodlum's Avatar
I don't really have an opinion either way.
What would you think if only the bed floor had the spray-on bedliner. In other words, the tailgate, bedsides, wheel wells, and front bed panel were painted as normal?
Keith
lil hoodlum is offline   Reply With Quote
Old 06-29-2011, 07:02 PM   #29
crm318
Alright Alright Alright
crm318's Avatar
Is there a way to remove the bedliner later on?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 06-29-2011, 07:36 PM   #30
VWBeamer
I'm not sure the bedliner can be removed chemically, I don't know of any paint stripper that will dissolve it.
A torch and a putty knife will get it off, but the smell is not good and it's not much fun.
On another forum a couple of people suggested liquid Nitrogen to freeze it and then chip it out.
VWBeamer is offline   Reply With Quote
Old 06-29-2011, 07:49 PM   #31
rpmgroup
value change, i don't think so on a DD, i wouldn't on a correct restoration. i am planning to use a sprayed on bedliner when i assemble my truck. i use the truck for haulin stuff, but maybe down the line i will craft a wood and stainless panel to down in over the bed floor for nites at the burger stand.( i have a stack of black walnut boards to use) crm318 i used a heat gun and putty knife to remove a Line X brand liner to do some welding on a bed before. iwould not want to do the whole bed that way.
rpmgroup is offline   Reply With Quote
Old 06-29-2011, 08:05 PM   #32
Zoomin
Man of Mini-Talents
Zoomin's Avatar
On a beater, no problem. But on anything else, I don't want bedliner or rust-proofing, but that's just me. It may not devalue your truck, but it may reduce the number of people that would consider buying it. Others would not care or even prefer it.
Zoomin is offline   Reply With Quote
Old 06-29-2011, 08:24 PM   #33
wwotr
wwotr's Avatar
I say SPRAY IT.
My Truck is lowered and nothing but a couple Lawn Chairs, EVER gets put into the Bed, but as far as Spraying it, that is on my "To Do" list!
I mean if your worried about Devaluing the Truck, then that means to me, that you plan on selling it, as opposed to keeping it.
As far as a Truck with a Bed Liner in it, is "Beat", I don't see the argument in that.
I'd be more worried, about buying a Truck with one of those ABS Bedliners, before I'd be concerned about a Spray on Bed Liner.
My .02 cents worth.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 06-29-2011, 08:48 PM   #34
capev86
Although people consider my truck show quality, I still use it for fun and light hauling. It is a truck afterall.
AMEN!!!
spray on liner is the way to go for bed and underside/chassis coatings if you want to make the truck last. it doesn't peel, chip or let moisture get under it like you get with paint and traditional rustproofing. a concours type car show (duesenburgs, packards, etc) is not really the place for our trucks, so even on a restored truck i would see a liner as only adding value if done properly. i'd like to see more move towards restoring good old trucks that can still take a lickin' as they were intended instead of turning them into glorified cars. heck, i refuse to put an antique plate on my 72 burb c20. it's not a model T and does a heck of a lot more than drive 2 miles back and forth to car shows. it serves as a back up daily driver (except when it snows), principal tow vehicle, family hauler, equipment hauler, as well as weekend "fun" vehicle.
capev86 is offline   Reply With Quote
Old 07-03-2011, 09:38 AM   #35
69oldog
69oldog's Avatar
Spray-on bedliner and Bruce Horkeys Show Deck
69oldog is offline   Reply With Quote
Old 07-03-2011, 10:02 AM   #36
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I sprayed down some hippo liner before I applied the fat mat and id do i again...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-03-2011, 02:18 PM   #37
redmonster
redmonster's Avatar
how about using a roll on liner i hear theses are pretty good too and will not set you back much also you can color match with rustoleum
WITNESS
Dont be like me be better than me
redmonster is offline   Reply With Quote
Old 07-03-2011, 02:19 PM   #38
redmonster
redmonster's Avatar
WITNESS
Old 07-03-2011, 02:25 PM   #39
redmonster
redmonster's Avatar
this is what i plan on doing to mine
ive had my fair share of trailer queens and mini mile show cars and trucks
thats not what i bought this one for this is a DD, beater, trash hauler, kids bikes and dog to the park truck, football team mover ETC
WITNESS
Old 07-03-2011, 02:55 PM   #40
70cst
70cst's Avatar
Nothing wrong with that...that's why these trucks were built for in the first place
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-03-2011, 10:19 PM   #41
Hubscrub
Cruzin
Hubscrub's Avatar
thats sharp, the best looking bed is wood as far as "nice" my op, or a carpet liner with a cover, my wife has a bed rug in her truck with a hard cover like a big trunk i love it. But as far a spray in vs. paint i don't see any difference in price i really don't care what my truck is worth to others i'm not into this for a profit. I like the spray in myself i have one and use it no problems like said earlier, after all there still trucks.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-06-2011, 10:08 AM   #42
FrankieD
FrankieD's Avatar
Here is another way to take it off go to 4:48 min on the vid if you don't want to watch the whole thing http://www.theinductor.com/index.php?m=28 . But no mater what it would be basicly imposable to remove if you ever wanted to you would be better off getting a different bed so make sure you can live with it like a lot are saying it is a matter of choice and what you are going to do with it. I have had the rubber floor liner and it is great and as far as holding water not a problem with the ribs in the bed or what I have been doing for ever put a sheet of 3/4 ply wood in the bed it does a wonderful job on a work truck.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 09-09-2012, 07:50 PM   #43
dropanddrag71
dropanddrag71's Avatar
Any Idea what it would cost to do a spray on bed liner and have it match the color of the truck? do most people just get the floor done or should i do the whole thing, tailgate and sides as well? Just had my truck painted but i still want to put things in the back without the worry of scratching the bed.
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying"
dropanddrag71 is offline   Reply With Quote
Old 09-09-2012, 08:48 PM   #44
72peace
72peace's Avatar
Talk to your local line-x folks they do bedliners then paint over to match your paint.
Cheers,
72peace is offline   Reply With Quote
Old 09-09-2012, 09:24 PM   #45
dropanddrag71
they will first spray the bed liner in black then prime and paint over that?
Old 09-09-2012, 09:47 PM   #46
dropanddrag71
painting over it seams like its defeting the purpose for getting it? The paint will just scratch, chip ect leaving the black bedliner underneath. Just dont sound right.
Old 09-09-2012, 10:06 PM   #47
jstrits
if your bed is not that beat up i would paint it. I almost feel covering it up with liner is like when someone does alot of body work only to put it in primer or suede and then leave it. if you went all this way why not finish it. To me it looks like a cover up.
jstrits is offline   Reply With Quote
Old 09-09-2012, 10:38 PM   #48
69GWC
That was one of the things I looked for when truck shopping, i wanted a truck that had a liner sprayed in it allready so I did not have to spend the money on it.
I think it makes the bed look cleaner and if you use the truck its all most a must to me.
69GWC is offline   Reply With Quote
Old 09-10-2012, 12:01 AM   #49
1972crewcab
1972crewcab's Avatar
You just want to clean under the rubber mat it can cause rust and mildew !
1972 gmc k2500 ochra & white (best colors ever)i like them
1971 gmc crew cab (in progress)
1985 toyota ext pickup trail rig (cat yellow)
2009 rzr
1972crewcab is offline   Reply With Quote
Old 09-10-2012, 12:03 PM   #50
Coley
Coley's Avatar
Smile Re: Will a spray-on bedliner de-value my truck?
If your truck is a very original truck....it will generally devalue the truck to a lot of potential buyers...not all.
Decide what you are trying to accomplish with the box area. Ie: hauling wood? occasional groceries? some minor auto parts and stuff?
Consider getting a rubber (removeable) bed mat....or even a small end mat for inside. If you are really on a budget get a piece of plywood and simply paint it the truck color.
Your truck, your call.
Good Luck
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
