Old 01-24-2012, 10:09 PM   #26
Redleg
Redleg's Avatar
Re: 72 RAT Build.
Well its been a while since i have updated the "build thread", but i have started progress of actually restoring some items and make some actual changes.
First off, white walls are gone, replaced with raised white letters. (as shown in pictures.....
Then the second is a pic of a new 307 block i am picking up saturday. I am going to copy and post what i posted in the engine forum so i can get as much feedback as possible....
Please beat this to death for me and help me get the most bang (HP) for my buck.
-307 Block with .020 bore
-Flat head O/S .020 Pistons
-Small cam possibly a Hydraulic Flat Tappet Duration 242/252, Lift .368/.398 Possibly smaller duration because of the heads i will be using? Maybe a 230/230 duration with a .480/480 lift? or a XE262 as another member has recommended....(feedback especially wanted here)
-Elderbrock intake (on current 307)
-Elderbrock 600 Carb (on current 307)
-HEI distributor (on current 307)
-MSD Ignition
-305 heads with 1.84 intake. they are 416 casting 305 heads (on current 307)
-headers
-dual flowmaster 60 series mufflers (on current 307)
-Has current 3OTT, but hope to change to T-5, or T-56 depending on availability
-3.73 rear end.....
So what are some thoughts on what this will get me? Am i way off base? Decent build or will it need some work? About to start the build in a couple of weeks so i am doing research and going to start ordering soon!
Joel
Originally Posted by prostreetC-10 View Post
Some trucks in the air, some layin' frame.
some are super cool, and some kinda lame.
Some kinda slow, and some really fast.
some run on 110,and some on pump gas!
Redleg is offline   Reply With Quote
Old 01-28-2012, 10:08 PM   #27
Redleg
Redleg's Avatar
Re: 72 RAT Build.
well the new block, pistons and cam are home. dont know if i will use the cam, but will try the pistons out.....aftermarket flat tops....
Joel
Old 02-06-2012, 09:02 AM   #28
Redleg
Redleg's Avatar
Re: 72 RAT Build.
Worked on a little bit of everything this weekend.
Installed my blower lever on the heater control panel, still have to order a Defrost lever...
Did some small body filling and smoothing. Really working on trying to get better and more patient at it. I might not keep this bed, but its a good way to learn the trade anyway!!!
And finally, took a 307 block, pistons and cam to the machine shop and picked up a free 307...Its seen its better days but i hope to use the crank and covers etc......Its a little messy and wet...been outside for a long time!!!!
Joel
Old 02-06-2012, 09:09 AM   #29
Redleg
Redleg's Avatar
Re: 72 RAT Build.
Also decided to take a look at the heads on my truck. I was under the impression that they were 416 series with the 1.84 valves.....Nope!
Turns out they are 376450/378450 whichever one is the right number. They are 1.72s....So i will be looking for a good set of heads.........
I plan on using my Elderbrock Performer 2101 manifold and Elderbrock 1400 carb on the new motor. Was plan on using the heads till now......
Joel
Old 02-06-2012, 09:56 PM   #30
litew8
litew8's Avatar
Re: 72 RAT Build.
I'll try and get a rendition posted.
1) O.D./Olive Green (like the star's background) paint - What is O.D.? And, to be a white cab top?
2) Black bumpers and grill
3) Big U.S. Army stenciled on the tailgate
4) Black star trimmed in white on the door
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-07-2012, 09:02 AM   #31
Redleg
Redleg's Avatar
Re: 72 RAT Build.
The thought is to go with something similar to the attached.
However the bumpers will be black.. and the wheel centercaps. may change from current ones. will see when that time comes...
Star will be black with white trim....
I think i will leave it a solid Army green color.... I thought about the white cab, but for my first paint job, im going to stick with a solid color..
The plan was getting a smooth tailgate or tailgate cover and in place of where it would usually say Chevy, it would be the U.S. ARMY.
Then somewhere on the front bumper and rear bumper i would put a "truck number"
O.D. Green is olive drab green. But the actual paint i am looking at now is Army Matte Green.
Joel
Old 02-08-2012, 11:52 AM   #32
67cheby
67cheby
67cheby's Avatar
Re: 72 RAT Build.
i like it !
67cheby is offline   Reply With Quote
Old 02-08-2012, 01:19 PM   #33
Low down and dirty
Low down and dirty's Avatar
Re: 72 RAT Build.
you might have already stated this in your thread, but have you put any thought into lowering the truck? It would look pretty good with a 3''/5'' drop kit.
68-Chevy c-10 Short Step
66-Plymouth Sport Fury
00-Chevy silverado 1500
Low down and dirty is offline   Reply With Quote
Old 02-08-2012, 02:25 PM   #34
Redleg
Redleg's Avatar
Re: 72 RAT Build.
Haha, i had just posted in the suspension forum that i am looking to add 1" or 2" drop springs to my 2.5 drop spindles in the front and see the best way to lower my rear 4" since it has leaf springs....
Joel
Old 02-08-2012, 05:34 PM   #35
Low down and dirty
Re: 72 RAT Build.
I really have no experience with leaf spring trucks. I know you can use lowering blocks, but not sure how low you can go with just blocks. Maybe someone else can chime in with some advice. The only problem with lowering your truck is it seems like its never low enough....lol
Old 02-10-2012, 09:47 AM   #36
Redleg
Redleg's Avatar
Re: 72 RAT Build.
Here is a question, if i replace the 3 OTT with a 350 tranny and use a floor shift is there any reason i will have to change out the steering column?
Joel
Old 02-11-2012, 05:34 AM   #37
whitelightnin92
Re: 72 RAT Build.
just take the pin out of the shifter on the column and it comes off
06 ECSB 4X4 L33 HO 3.73s 15.56@89.9 STOCK
92 K1500 TBI350vortec(too much to list)
69 C10 short fleetside(under construction)
72 C10 short stepside(almost driveable)
whitelightnin92 is offline   Reply With Quote
Old 02-11-2012, 12:07 PM   #38
502ms
502ms's Avatar
Re: 72 RAT Build.
Bag it. You will never be happy enough with the drop on springs..
Besides, you will be paying close to the same on parts....
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-11-2012, 04:49 PM   #39
Low down and dirty
Re: 72 RAT Build.
Hey Redleg, No need to change the steering column. I still use my 3 ott column with a T350 and B&M shifter. Just remove the column shifter and linkage and keep on rollin....
Old 02-16-2012, 06:34 PM   #40
Redleg
Redleg's Avatar
Re: 72 RAT Build.
Quick question. Best headers to use for these trucks.
Been seeing some threads about clearance issues etc......
Joel
Old 02-17-2012, 05:31 AM   #41
Low down and dirty
Re: 72 RAT Build.
I'm running Hedman full length headers with no problems. A little tight on the drivers side, but got them in without any problems..
Old 02-17-2012, 09:10 AM   #42
Cameron 1137
Cameron 1137's Avatar
Re: 72 RAT Build.
i run the cheapest pair that Advance Auto had, a 99 dollar black coated pair, fit nice, and like Low down said, a little tight on the driver side, but i think they all are
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 02-17-2012, 09:13 AM   #43
Redleg
Redleg's Avatar
Re: 72 RAT Build.
Good to know! Saw quite a few cheap sets on ebay i was curious about...
Joel
Old 02-17-2012, 05:15 PM   #44
Boogie_Man
Boogie_Man's Avatar
Re: 72 RAT Build.
+1 on the Hedmans. Summit's truck headers aren't too bad either and run around $130 painted.
As far as lowering with rear leafs, a set of lowering blocks would do you just fine, or if you want a little better ride quality, a set of drop leafs. Bagging the truck would cost WAY more. A good set of blocks are around $60 while just a compressor for an air ride setup is at least $160 for a Viair. You could get springs and blocks for that much.
Nice truck, I'm really diggin' the flat black shop rat feel. The matte army green is pretty sick as well. Good work on that interior paint!
Boogie_Man is offline   Reply With Quote
Old 02-18-2012, 12:27 AM   #45
chevy88
chevy88's Avatar
Re: 72 RAT Build.
I love your truck, you have alot of cool idea's.... but I still like the black version a little better.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 02-18-2012, 12:22 PM   #46
fastcam1
Young gun
fastcam1's Avatar
Re: 72 RAT Build.
As far as I know all the leaf spring equipped c10s the rearend is under the springs not on top so he will need to use a flip kit, blocks wouldn't work. Not a 100% positive but this is how mine was originally set up before I converted to trailing arms
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 02-21-2012, 09:46 AM   #47
Redleg
Redleg's Avatar
Re: 72 RAT Build.
The plan in time is to do flip kit. However the PO removed some leafs in the rear. I dont plan on flipping it until i can get a full set of leafs.. Its soft enough as it is!!!!
All i have to do to lower it another 4" is have a midget stand in the back and it drops it plenty!
Joel
Old 03-02-2012, 03:43 AM   #48
litew8
litew8's Avatar
Re: 72 RAT Build.
Not much better, couldn't spend too much time on it.
And there was no way I was going to attempt the U.S. Army lettering on the tailgate
Anyway, something like this is what I understood (sorry didn't mess with tires).
Lots of bondo to fix the door
Old 03-07-2012, 08:53 AM   #49
Redleg
Redleg's Avatar
Re: 72 RAT Build.
Well, i figured i might update this, even though it will probably change again like it has a few times,
BUT.....
I am actually thinking of making a Flatbed for it. I have a close friend who has an aweseome shop, with any kind of hoist, lift, welder, cutter etc.... He mainly builds bikes for him his wife and kids, but he used to do Rock Crawlers. Talked to him about it and we put together a nice little blueprint of a sweet looking flatbed for it.....It will have looks, but also functionality....
Unfortunately he lives in Texas so I wont get to start that part until i can move back there, which Lord help us, will be sooner than later this year....
Joel
Old 03-07-2012, 08:55 AM   #50
502ms
502ms's Avatar
Re: 72 RAT Build.
If you do, what will happen with your fleet bed?
Best Regards,
Leon M.
