07-08-2011, 10:24 PM | #26 |
Re: 454tbi
Whatever works for ya is great. So, do the research, pick something and if it works, life is good!
07-14-2011, 12:34 PM | #27 | |
Re: 454tbi
You could do a relay in the circuit, triggered by a temp switch to turn off the heating element when the motor reaches xxx degrees. BTW there's supposed to be an "upgrade" cam for the 454SS motor that is said to work really well with the TBi. I don't have the PN in front of me but the guys at 454ss.com should be all about it. |
07-14-2011, 01:17 PM | #28 | |
Re: 454tbi
07-15-2011, 09:29 AM | #29 |
Re: 454tbi
For a lot of good TBI info, you should check out http://tbichips.com/
Follow the link on the left to Good TBI Mods and then to 454SS on the bottom. He mentions some specific cam grinds in there. It's the basics as stated before: Air In and Air Out along with enough fuel and spark. Start with the low hanging fruit like open air cleaner, stronger coil and dual exhaust (even without headers). Oh yeah, make sure the fuel filter is fresh, an old filter is death to the tbi engines. Then step up to a good cam (matched to your intended driving purpose), manifold and a better fuel pump. Are the valve springs as bad on the tbi BBC as they are on the SBC? Another good upgrade when you switch cams. Now is also the time for a modified chip (again matched to your intended driving purpose). Finally I would go to a bored throttle body. If you come across a good deal on some heads the yes, jump on them. |
