Old 07-04-2011, 11:51 PM   #26
1972RedNeck
1972RedNeck's Avatar
Re: How Anal Retentive are you about your truck?
Originally Posted by RagingAsian View Post
I am pretty AR, but not to the point where id pull an engine out for a leak.
Originally Posted by lil hoodlum View Post
LOL However, I have never pulled an engine to fix a leak.
I didn't pull the motor because of the power steering leak.
Oil was leaking from my pump casing. When I was removing the pump, I grabbed the fan to test the water pump bearings. They were loose. With the water pump off I decided to seal up my timing chain cover. To take the cover off you have to remove the pan (as we all know) so I decided to check a rod bearing. They were almost to the copper. So I decided to remove the 'ole Tall Deck 427.
I decided to list it on Craig's list (I don't really Know why) It sold for a good sum of money so I decided to build a 383. Since I put a SBC in, I needed new flowmasters. With the motor out I decided to install a 700R4. With the transmission out, I decided to rebuild the transfer case. With the drive lines out I noticed the front one was loose. New drive lines. With the truck down I decided to do a brake job. With the axles out, my truck got 4 inches higher.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-05-2011, 12:07 AM   #27
19seventeeCustom
I am, I have the disease.
I go to bed thinking about my next "to do" item for whatever project I'm currently working on.
I clean the S&^% outta that old truck/full interior details are a regular occurrence. Things that are worn beyond repair get replaced, creaks/rattles are found and stopped. Minor pieces are painted/refurbished but never over the top, all changes are very subtle and very detailed.
I believe these are the necessary steps to set your vehicle apart.
19seventeeCustom is offline   Reply With Quote
Old 07-05-2011, 11:23 AM   #28
jhwkns
Registered Cruiser
jhwkns's Avatar
I can live with a couple drops of oil under my truck, but exhaust leaks drive me nuts!
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
