07-08-2011, 12:14 AM | #26 | |
Re: 6.0/4L60E swap finally done
So I had to rebend the front brake lines and move them forward in the frame about 10 inches, then buy longer braided steel lines for a 6 inch lifted truck to reach the new locations in the frame. Yes my transfer case is in the stock location. I didn't want to move that and open a can of worms with driveshaft lengths, shifter location etc.... So I moved the transmission and engine forward approximately 2 inches. Not sure why you ended up notching your tranny pan. I read that about your swap and just automatically figured I'd have to do the same. Then I bought this 4L60E out of a truck, which had the deeper pan and thought I would really run into a big problem. You can see the deep pan in one of those pics. I figured I would have been cutting the entire side of the pan out and rewelding after the horror stories I've read about standard depth passenger car pans. Then I dropped it all in and it cleared with room to spare. Not sure why but it works great. That front driveshaft also has that large coupler on it back there too with a pair of U-joints in it. I assume it's the same thing you have? I'll get some more pics up tomorrow, and try to snap a couple while resting on the ground. Not sure how that will turn out but I'll try. |
07-08-2011, 08:48 PM | #27 |
Thanks,
I did the same thing with leaving my transfer case in the stock location and also have the double cardon joint (double U joint like you). I used the same advance adapters 4 to 6 bolt adapter and even used their new aluminum transfer case mount like you? I'm scratching my head? I had looked at Pacific fabs crossmember and they said it wouldn't work without a lift? Thanks again. Looks great.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-09-2011, 12:48 AM | #28 | |
Sounds like our setups are identical. The Pacific Fab crossmember has since been redesigned in the last couple of months. It's not mentioned on their website anywhere, but talking to them on the phone, it's now made to clear the differential better without using a suspension lift. They really tucked it up tight to the oil pan. I'm like you, I didn't want to raise the truck at all (getting to old to climb in and out ) |
07-09-2011, 01:05 AM | #29 |
Second Chance Program
Looks great! Good job!
07-09-2011, 04:16 PM | #30 |
Nice work!
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
07-10-2011, 10:06 PM | #31 |
Here ya go Thealien, I held the camera under the truck and aimed as best I could. Snapped a couple of pics. It's still not the best pics but hopefully you get an idea.
07-10-2011, 10:11 PM | #32 |
Been driving it quite a bit the last few days. No issues so far. Still tinkering with the tune. Boy GM really puts a soft tune in these truck engines with single digit timing curves, and the commanded 11.7 AFR at WOT isn't helping performance either It's coming around though. It's starting to wake up and get with the program.
07-10-2011, 11:06 PM | #33 |
How long did this project take ya, from start to now? Looks great. Would like to see more pics of entire truck, too, though.
07-11-2011, 12:02 PM | #34 |
I've been collecting all the parts for several months, researching and buying more parts During that time it was a running and driving truck that I drive daily.
But from the time I actually turned a wrench on it and removed the original drivetrain tothe finished product......It took about 3 weeks. I was held up a day here and a day there during the process though, as I had to order other parts that I didn't plan. I spent time fabbing things like the exhaust, cutting the battery tray apart and rewelding so I could mount it on the other side. To do that I had to move one of the horns, no big deal. The engine was in and out 3 times for trial fitting the exhaust manifolds, of which I had to slightly notch the frame. And I had to mark the holes for the new crossmember, remove and drill. This crossmember also required that I move the front brake lines which passed through the frame exactly where the crossmember wanted to sit. That was an unforseen obstacle. So I moved the lines forward in the frame about 10 inches which required new flex hose that was longer (for a lifted truck) to reach the new location in the frame, then rebend all the hard lines that cross under the radiator. That all took a little time. Everything else was pretty straight forward and simple. I'll pull it out today and take some shots of the truck if you like. It still looks like the same ole truck on the outside though |
07-11-2011, 01:41 PM | #35 |
Very nice work. One question though, are you running a stand alone computer for the 4L60E or did you do something else to have it lock up?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
07-11-2011, 03:13 PM | #36 |
Post Whore
That is a really impressive job you've done with this swap. Very impressive!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-11-2011, 06:57 PM | #37 | |
Already had the software from tuning our 4th gen camaro's so it made even more sense to do this conversion for me. What also makes it slick is that it controls the dual electric fans that I pulled from a 4th gen camaro, as well as now the blazer has cruise control, also ran from the computer since I used a drive by wire throttle body. Last edited by Firebirdjones; 07-11-2011 at 07:13 PM. |
07-11-2011, 07:07 PM | #38 |
Someone asked, here is a quick shot of the blazer, although a poor one. The weather wasn't cooperating today and I didn't want to stand out in the rain.
07-11-2011, 07:14 PM | #39 |
I just ordered the high mount AC bracket system from Kwik performance and a brand new Sanden compressor. Once that's on I'll have some hoses made, do a 134 conversion and the AC should be back up and running soon.
07-11-2011, 07:15 PM | #40 |
Let's hear it run !!
07-11-2011, 07:25 PM | #41 |
Here are a couple of shots of the brake lines I mentioned.
Looking at this shot close, you can see the 4 bolts coming through the frame. That's where the new crossmember mounts. In the middle of those bolts you can see a large hole in the frame. That's where the original brake hose passes through. That clearly won't work. As you can see I moved the brake hose forward (on both sides) which required a longer hose (for a 6" lift) Since I moved the hoses, it also required making new hard lines, bending and flaring. Not a big deal, you can see them here running in their original locations under the radiator.... |
07-11-2011, 07:30 PM | #42 |
Haha, I could probably do a short video, would take some help from my wife though, I'm lucky I can post pics
I still have a ways to go to dial it in. I may or may not do a gear swap on it. So far I'm impressed with the way it runs with measly 3.07's in it and tall 33" tires I'll probably baseline it at the local dragstrip and see where it's at, but I'm really leaning towards a set of 3.73's, then throw a magnuson on it |
07-11-2011, 07:31 PM | #43 |
nice. im doing the same exact thing with my 72 but only with the 5.3. just about to get the wiring finished up.
07-11-2011, 07:59 PM | #44 |
Still Learning
Awesome swap! You really had your ducks in a row when you started this swap. Just curious what you did with the fuel system? In tank or inline pump? More pics please! subscribed.
ps, that is a badd a shop you have there along with some sweet rides! I'm envious of that lift. I bet it makes changing oil a breeze |
07-11-2011, 08:30 PM | #45 |
Ah the fuel system. Forgot to mention that. I decided to go with an inline system for the time being. I've used them before on other swaps with "okay" success. I really prefer to have the pump submerged in the tank for longevity and durability. But for me to be completely happy that would require a custom made aluminum tank, and I'd probably go "large x huge" on it for more fuel capacity.
That's more fab work and more money. So for now the inline pump got me up and running. For the inline system, I decided to make a completely new dedicated main feed line and a return line so I didn't use any of the original fuel lines. Here's a shot of the pump. I mounted it on the outside of the frame behind the back tire for a couple reasons. One: For more airflow to keep the pump as cool as possible. There is a nice place inside the frame but I didn't want to deal with exhaust and differential heat that may shorten the life of the pump. Two: I wanted easy access to the pump for a potential road side repair. With it mounted on the outside of the frame it's easily accessable if you remove the tire. Further up the frame I mounted the filter and the regulator, again on the outside to stay away from heat and for easy maintanance. The filter is for a 98-02 LS1 camaro so I can go to any parts store and pick one up. The regulator is a slick little unit that maintains 58 psi using a check ball and spring. This came from Howell, the same company that supplied the custom made wire harness and computer. The braided lines are Russell with AN fittings to make it all work. Then I just bent up steel 3/8 line for the return fuel from the regulator to the tank. Here is a shot of that stuff.... |
07-11-2011, 09:33 PM | #46 |
I really apreciate the pictures, thanks. When you get a chance could you take a few of the front driveshaft from a couple of different angle near the trans pan and trans crossmember? Still trying to figure out whats different.
Just for information I used trailblaser SS manifolds and had to do no frame trimming, perfect fit, like they were made for our trucks.
07-11-2011, 11:02 PM | #47 |
Still Learning
Thanks for the pics. I am thinking about going with an external pump too. I know of several members that have used them with great success. Very clean install on the fuel system and really I like filter setup too.
07-11-2011, 11:20 PM | #48 | |
I can stick it on the lift and get all the shots you want, but the suspension droops. Even so, the driveshaft really doesn't move that much back by the pan though. That's good info on the manifolds. I used the 6.0 truck manifolds because they came with the engine, so I used what I had. |
07-11-2011, 11:28 PM | #49 | |
I would rather use a submerged pump in the tank, and I probably will at some point since I plan to keep the truck and I drive it daily. The fuel keeps them cooler, and they tend to last longer, plus they run quieter. Both of my 4th gens that are now 10 and 12 years old still sport their original pumps in the tank and still kicking. I'll never get that much life out of an inline pump. The issue right now though, is a custom made tank, with a good quality Aeromotive pump, and more plumbing, will set me back at least $1,000. This swap has already been a very pricey adventure as it is |
07-12-2011, 05:37 PM | #50 |
Check out my thread for an in tank fuel pump solution. I got the pump from the truck I pulled the drive train out of and it was easy to make work in the stock blazer tank.
I never hear a whine or rattle during key on primeing, start up, or running. I know I didn't spend a lot of time making everything pretty. It's not a show truck it's a daily driver and wheeler. I take it on the trails, down narrow fire lanes, in the mud, etc. so I was not concerned with bling, just raw functionality and cost.
1970 Datsun 240Z 1972 K5 Blazer Highlander 1972 Chevelle 1959 Apache 3100 SWB Fleetside 2006 VTX 1800f Build thread: http://67-72chevytrucks.com/vboard/s...ght=highlander |
