#26 |
Re: Which swap is cheaper and worth doing
Yea Im only 18, but i couldnt make my mind up about a gas motor to build, but it just doesnt seem as fun building up a sbc, it may be easier but i know people who love their cummins and theyd help me swap it if i ran into problems! I dont think i want to get any donor truck after a 97, seems to get more complicated. How hard is it to mod a crossmember from the dodge to fit the chev chassis?
#27 | |
Conversion Truck Addicted
remember the body lift, to make it fit
go and watch http://www.youtube.com/user/TheDieselStop he is doing it http://www.youtube.com/user/CumminsChevy85 if your looking for a staight plugNplay swap a cummins is not the way to go
Thomas Quote:
#28 |
Dont' need a body lift to make it fit, it's just easier. Neither are gonna be easy to go. If you have a gas, you still need to address the fuel system when switching to diesel.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#29 |
Thanks for the link! Im definatley going to try and email him and get his dimensions for the crossmembers he made
#30 |
Yea, but it sounds like alot of work when switching a 6.5 too, but the end result just isnt what a cummins is. Yes maybe in the short period of time i could get a 6.5 and get it running in there easily, but just not the same. Id love to see someone get 450 horse out of a 6.5 for the money you could with a 12 valve.
#31 | ||
donor engine and transmission and controler if its a new type a screw on type fuel filter setup Diesel Radiator misc hoses for fuel line Solid fuel lines need 2 one feed and one return Diesel Sending unit 2 batteries a few feet of battery cable 4 battery terminals misc small gauge wire 1 toggle switch for high idle 1 push botton for glow plugs Exhurst system 1 battery tray for right or left depends one what your missing no mods needs to be done to the truck as you can use the power for the igition coil for the fuel pump shut of solonid theres alot more work involved with a cummins swap and they are a tight fit in these trucks. but it sounds like you allready wanted a cummins 500HP in a 6.5 has been done ![]()
Thomas Quote:
#32 |
Yea but how much money was put into the 6.5? I really am not sure yet but the cummins is what i was leaning towards. But if i can find a 6.5 deal i cant pass up then sure ill take it. But there has to be next to nothing for miles
