Old 08-28-2011, 12:38 PM   #26
protrash64
Resistance is Futile
protrash64's Avatar
Re: Farmers big block
Nice work Farmer! What plans do you have for brakes? Going 5-lug in the rear with the '78 parts?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-28-2011, 07:37 PM   #27
66farmer
66farmer's Avatar
Lost
I bought the tank off ebay it,s list for 1949-1952 chevy car. The tank was a easy install I did have to trim a little off the lower frame rail and flip the rear coss member over. I wish it heald more than 17 gallons that big block will eat that up and ask more.
66farmer is offline   Reply With Quote
Old 08-28-2011, 07:45 PM   #28
66farmer
66farmer's Avatar
Mr Trash
I,m using the stock 66 12 bolt housing. The rear brakes are off the 78 the brake backing plates bolt wright up which gives me 2.5 brake shoes as for the axles I bought a new set 5 on 5 to match the front.
Old 09-05-2011, 10:07 AM   #29
66farmer
66farmer's Avatar
9/5/11 update
I finely finished welding on the bed. The bed mods are LED bed curl lights, stake pockets capped, front bed curl capped, front head board panel welded, plated the sides where the tailgate bolt goes through. Now I'm onto the cab. Back in the 70's, my sister inlaw had a guy install speakers in the cab corners. I finshed one yesterday boy what a PITA. I did a butt weld on the replacement, and I will have to do something different on the other one.
Now the story of the missing body man. He worked with me for 30 hrs. and did really good. Then, he started finding excuses not to come. I believe there are issues, so I found a replacement body man and plan on taking the body panels to his shop. He assures me that the truck will be painted by the end of November. Lets keep our fingers crossed.
Old 09-05-2011, 10:09 AM   #30
66farmer
66farmer's Avatar
more pictures
Old 09-05-2011, 03:52 PM   #31
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by 66farmer View Post
more pictures
Loving it!
66 C20 Service Truck:
Old 09-06-2011, 11:09 AM   #32
66farmersdaughter
Looks good old man! The kids and I miss you!
66farmersdaughter is offline   Reply With Quote
Old 09-10-2011, 09:37 AM   #33
66farmer
66farmer's Avatar
update 9/10/11
I got the speaker holes repaired and sent the cab to the sand blaster. I picked up the cab yesterday and found that I have rust repair to do. At the start of my build I made the bold statement that this is a rust free Eastern Oregon truck. Now I need to eat those words and fix the rust. I will post pictures of the rust repair. Today the wife and I are going to End Of The World Rod Run on the WA coast hoping to see some 60ish trucks. Will post pictures later.
Old 09-10-2011, 10:25 AM   #34
no moa
no moa's Avatar
what does your blaster use for sand? Plastic bead, walnut? I know black beauty is to ruff for soft sheet metal, don't ask me how i know either. lol
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 09-11-2011, 09:20 AM   #35
66farmer
66farmer's Avatar
Moa
The only thing I know about the sand blasting sand is it,s green
Old 09-11-2011, 11:16 AM   #36
LostMy65
LostMy65's Avatar
Now that is too cool!
Welcome to the forums.
Old 09-11-2011, 11:25 AM   #37
Chevy Fleetside
Chevy Fleetside's Avatar
Did they change the blocks in the later years on BBC's? I notice some fit right in but to get mine back I had to cut the firewall and make it a bit bigger. Mine is an 89 year model. Yes I used short valve covers. Acually the same ones he has..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-12-2011, 01:06 AM   #38
Captainfab
60-66 Nut
Gen IV, V nad VI BBC's are all the same physical size. The only difference that I can think of is if you have a tall deck truck block. Those are .400" taller than the passenger car, light truck blocks.
Old 09-12-2011, 01:11 AM   #39
Captainfab
60-66 Nut
Are you saying the surface finish is rough, or did the blaster warp your sheet metal? I prefer a slightly rough surface finish. That is known as a mechanical etch. It gives the primer a very good surface to grip to.
That could be nickel slag, it is a green color.
Moa
Old 09-12-2011, 01:14 AM   #40
Captainfab
60-66 Nut
Yep, I have seen that very same thing happen many times to assumed 'rust free' car and truck bodies. Media blasting definitely uncovers all the hidden little problem areas. But IMO that's a good thing. That way there are not any hidden problems that will show up in your nice paint job later on.
update 9/10/11
Old 09-24-2011, 11:03 AM   #41
66farmer
66farmer's Avatar
Smile Re: Farmers big block
Update 9/24/11
A lot of welding. I have most of the firewall holes welded up, the speaker grill blanked off, the drivers side rusty panels repaired. I cut the LH cab corner out and tried to fit the counterpart corner but this corner doesn't even come close to fitting. So, I ordered a Triplus...I hope it fits better. I still have the RH rust to repair, radio cut out to fix and a whole bunch of under dash screw holes to weld up. I think every family member that drove the truck in the last 47 years mounted a CB or something. Well I better go, today's job is to fix the radio hole.
Old 10-29-2011, 09:29 AM   #42
66farmer
66farmer's Avatar
Up date 10/29/11
I haven't up dated in a month because it's takein me that long to fit the crapy replacement panels. I'm done welding on this thing. Yeserday I changed my mind on what hood I'm going to use. Last spring at the Portland swap meet I bought a very nice 4" fiberglass cowel hood. The hood would change the look of the truck to more of a pro sreet and that's not what I wanted. So I welded the seams on the stock hood and delivered cab and hood to the painter. So by the first of Dec I will post painted pictures. To keep myself moving foward I'm sanding heater, vent and other parts for powder coating.
Old 10-29-2011, 09:31 AM   #43
66farmer
66farmer's Avatar
hood pictures
Old 11-14-2011, 08:34 PM   #44
66farmer
66farmer's Avatar
Update 11/14/11
The body guy is moving right along on the body work steal looking at the first of Dec to bring her home. I'm waiting on powder coated to start assembling heater. So I deside to strip sand and polish the dash assembly, fender emblems, turn signal bezels and custom cab trim alot of work.
Old 11-14-2011, 08:37 PM   #45
66farmer
66farmer's Avatar
Old 11-14-2011, 08:53 PM   #46
pdxhall
pdxhall's Avatar
Looking good farmer. I'll bet your getting pumped to get the painted cab back. Good luck.
pdxhall is offline   Reply With Quote
Old 11-14-2011, 11:28 PM   #47
allaboutchevelles
allaboutchevelles's Avatar
Those turn signal bezels look like new. How did you strip that clear coating off of them that the factory put on them?? I was told that if you strip that off and polish the aluminum that it will turn white and faded within a few weeks of outdoor exsposure. I know eastwood sells a kit for restoring aluminum emblems.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 11-15-2011, 01:25 AM   #48
66farmer
66farmer's Avatar
PDX I'm counting the day's
As for the turn signal bezels, I used Eazy Off oven cleaner, the yellow can... the blue one doesn't work. You have to apply it a few times and than I used a scotch bright pad on it, then washed it off. Then, I sanded using 500, 1200, and 1500 grit paper. Then, I started polishing. The thing that works great is a power ball chucked in the drill press and mothers mag polish. It polished up pretty quick, then a coat of wax. As for them turning white after being in the weather, if they do, since the coating is removed, I will polish them again. My truck is not going to be a daily driver. So, the exposure to weather is going to be at a minimum. I did the same process on the custom cab trim and emblems.
Old 11-15-2011, 03:22 PM   #49
McMurphy
McMurphy's Avatar
Awesome build so far!
I am going to buy the oven cleaner today, but couldn't you respray rattle can clear coat on these parts afterwards to keep them from oxidizing?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 11-15-2011, 04:53 PM   #50
allaboutchevelles
I know my uncle clear coated some polished peices and the next day the clear was peeling off, I guess it being polished the paint has no grip to stick to.
