08-02-2011, 12:57 PM | #26 | |
Re: My $.02 worth....
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 |
08-02-2011, 09:24 PM | #27 |
A320 Pilot/USAF Retired
Re: Show Us Your In-Bed Fuel Doors!
This is the look I'm looking for. I have the parts just haven't installed them yet. Got it from Tanks.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-02-2011, 09:37 PM | #28 |
08-04-2011, 10:30 AM | #29 |
BIG CHEVY 3600 LONGBOX
The two pics below show the cap as set in and the configuration of hoses to connect the cap to the tank.
The pipe on the end of the cap is 1.5" OD and the pipe at the opening of the tank is 1.75" OD. I had to use a hose that was 1.5" ID to connect to the cap and a hose that was 2" and 1.75" ID to connect to the tank. Then I used clamps to hold it all together. It would have been so much easier had I bought the cap and had the tank spout made the correct size. http://s729.photobucket.com/albums/w...LINLETHOSE.jpg http://s729.photobucket.com/albums/w...nt=FUELCAP.jpg
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
08-04-2011, 05:01 PM | #30 |
I wanted to use a locking door and found this on ebay. It opens up to a 16 gl Tanks Inc. universal tank.
08-04-2011, 09:40 PM | #31 | |
08-04-2011, 09:44 PM | #32 | |
BTW, I have found a 2" bung that is the same size as the Mustang tank filler tube. It's on my '68 GTO, which should mean that any GM "A" body of that vintage can be a donor. just cut to length, clamp it on, then get a GM cap. |
08-08-2011, 12:53 PM | #33 | |
Byron |
08-08-2011, 02:08 PM | #34 |
[QUOTE=DransportGarage;4828459 ...<snip> BTW, I have found a 2" bung that is the same size as the Mustang tank filler tube... <snip>[/QUOTE]
THIS IS AN ERROR! The Mustang filler tube is 2-1/4". (It's hell to get old.) |
08-08-2011, 02:09 PM | #35 |
08-08-2011, 10:53 PM | #36 |
Home Built '87
Hi guys;
I bought these gas cap and filler necks on e-bay, of course no instructions came with them & I'm having trouble trying to figure out how to mount them through my stake hole in the bed. Would you recommend cutting a hole in a piece of sheet metal, fitting the bung in the hole and then tach welding it in from the bottom to keep the seam clean around the top? Then I could weld the sheet metal into the stake hole (would probably have to cut the stake hole bigger to fit it). I'm wondering if there may be a different way that I'm not seeing because the bung has grooves cut into it that makes me think that it somehow just might push into a hole and then get clamped from underneath to allow it to be removed later on down the line for servicing. Help! :-)
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
08-09-2011, 11:14 AM | #37 |
Home Built '87
Got my answer...
08-09-2011, 02:23 PM | #38 |
08-09-2011, 06:14 PM | #39 |
Home Built '87
What if you cut a hole in a piece of sheet metal to fit the first little lip on the bung and tack welded from under, then cut out your stake pocket to fit your sheet metal and weld in. This i think might give you a flush mount look.
http://67-72chevytrucks.com/vboard/s...29#post4836129
05-06-2017, 10:37 PM | #40 |
The major problem with this type of fuel tank filler is that it allows some gas to get onto the bed wood. I am going to remove this and put in a billet rectangle door with a regular gas cap under the door. That way if I over fill the tank it will spill onto the tank itself instead of the bed wood. Plus the fact that I will also not have a problem with gas droplets popping out onto the bed wood. I wrap a towel around the area but it still happens. At least that has been my experience.
1953 Chevy 3 Window Truck 3100 Series |
05-06-2017, 11:18 PM | #41 |
Post Whore
Saw this the other day on powerblock..push a button and board flips up
05-06-2017, 11:35 PM | #42 |
Neat idea.
05-07-2017, 04:22 PM | #43 |
05-08-2017, 07:24 PM | #44 |
That looks like chit
56' 3100 shortbed |
05-08-2017, 09:45 PM | #45 |
On mine, I'm going to combine one of these with JJ's idea above except the sink drain flange thing will be polished.
Here's the website: https://crafty-b.com/collections/all-gas-caps They have a bunch of other more complex/bigger/EXPENSIVE options of course.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
05-08-2017, 09:53 PM | #46 | |
Why doesnt anyone who uses the marine flange like yours route the wood the 1/8" (or whatever it is) so the face of the flange sits down flush with the wood? There must be a reason. I can't be the only one who's ever thought of it and I've literally never seen anyone do it even though a lot of guys use those flanges.
05-08-2017, 10:44 PM | #47 |
I mocked up my pop up gas filler tonight. This is going in my 53 Suburban. Eventually I will replace the rotted wood with new wood so I'm figuring out where everything will go. I have had this idea for a filler for over a year so it's nice to see it come together.
I will weld a 2" piece of pipe on the bottom of the cap housing, then I will use some 2" gas hose and some clamps to join the cap to the thank filler. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
05-09-2017, 12:06 AM | #48 | |
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
05-09-2017, 12:44 AM | #49 |
I'm not suggesting this is any better than what is being discussed, but since I had bought my truck with the gas filler cap in the fender, I reused the area. My choice of gas cap was from the local Harley dealership. Its a flush mount, push in and unscrew. Nice choice youngrodder!!!
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
05-09-2017, 01:37 AM | #50 |
Post Whore
Got any pics of yours my56?
