Old 09-08-2011, 10:47 PM   #26
Ryan5O
Re: Power Steering Pump Mount
Hmm, looks like Ive got four choices...
1. Leave it like it is
2. Spend the money on the appropriate power steering pump
3. Spend the money on a long water pump and new alternator bracket
4. Spend the money on a aftermarket pump bracket
I think at this point in time, Im sticking with choice 1 since the setup is more of an inconvenience than a problem. When its time to rebuild, I resolve it at that point. Its nice to get some insight on whats actually going on though.
Here's some more pics for those more curious.
USCG "Support Search & Rescue, Get Lost"
Ryan5O is offline   Reply With Quote
Old 09-08-2011, 10:58 PM   #27
treveiger
treveiger's Avatar
Go to a junk yard you pull it an get the set up if you want, its pretty cheap.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 09-08-2011, 11:22 PM   #28
Ryan5O
Which setup are you referring to?
Old 09-09-2011, 12:05 AM   #29
treveiger
treveiger's Avatar
The one like mine(power steering) the u pull it around me you pay 15 dollars for it. Just make sure youy hose is correct for the pump. I think you can use any pump up to late 70s but I'm not sure what year they switched to the o ring fitting from the flared.
Old 09-09-2011, 07:18 AM   #30
MacGyver72
MacGyver72's Avatar
Hey, just a thought. it appears you might actually benefit from a SHORTER belt. The pump will then tilt toward the motor and since the alternator bracket tapers up, that could give you the clearance you're looking for.
MacGyver72 is offline   Reply With Quote
Old 09-09-2011, 06:34 PM   #31
sstone69
sstone69's Avatar
My 1969 - 396 has the remote reservoir next to the windshield wiper fluid. Makes it real easy to fill it.
"You gonna pull them pistols or whistle dixie ?"
sstone69 is offline   Reply With Quote
Old 09-09-2011, 08:02 PM   #32
srvivor71
srvivor71's Avatar
Does that have a dipstick? How do you know when you're low on fluid?
srvivor71 is offline   Reply With Quote
Old 09-10-2011, 03:21 PM   #33
sstone69
sstone69's Avatar
Just open it up and look.
