03-11-2020, 05:17 AM | #26 | |
You had me at “pie”. Yum Posted via Mobile Device |
03-11-2020, 05:22 AM | #27 | |
I’m assuming the one threaded end sticking out with a nut on it is the fill hole...it’s definitely not a bolt that keeps the cover on so my brilliant deductive reasoning, since it’s on the top, tells me it’s a fill hole. I just need the 3/8 square to get it off...it’s around here somewhere lol. Posted via Mobile Device |
03-11-2020, 08:56 AM | #28 | |
Re: 72 differential oil/fill line?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
03-11-2020, 10:07 AM | #29 | |
03-11-2020, 12:19 PM | #30 |
03-11-2020, 12:19 PM | #31 |
<insert thumbs up emoji here> Lol
03-11-2020, 12:57 PM | #32 | |
Just a safe way to ensure it does not leak. I always use a gasket and and smear a light coat of RTV on both sides of it. |
03-12-2020, 04:40 PM | #33 |
So the ujoints is making a horrible clacking noise. I’ve been reading up some on this forum and some are “serviceable”. If it’s making the clacking noise can I recover from it by adding grease? Or is it too late when you hear the noise?
03-12-2020, 04:46 PM | #34 |
03-12-2020, 09:10 PM | #35 |
There are a couple sealants made for gear oil . I use the Permatex right stuff it's more expensive but it's better than plain RTV . Permatex also makes one just for gear oil use
03-12-2020, 09:37 PM | #36 |
Who Changed This?
If it is a u-joint making the noise, replacement is the only solution. Serviceable means that they can be lubed with a grease gun. Too late for that, sad to say, but they are certainly cheap enough. If you have a two-piece drive shaft, replace all the u-joints and the center carrier bearing assembly all at once, to avoid crawling under your truck over and over.
03-13-2020, 12:16 AM | #37 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I have read through this thread and nearly got dazed and confused myself..."Siedl" there is a fill plug located on the front right side of the differential housing. (Passenger side)about half way up. You fill the differential there with 80w-90 MP Gear Lube until the lube reaches the fill hole, install and tighten the plug. All you guys claiming that you don't need a gasket are shade tree wannabes living on borrowed time! The Felpro RDS-13391 is the gasket for the Truck-12 bolt differential. Use it with a thin film of your favorite oil resistant silicon applied to both sides and your golden. Take a look at the bolt flange of the cover and flatten out any dimples or high spots with a small ball peen hammer. 5/16 bolt only gets 12 ft lbs of torque,
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
