Old 08-07-2011, 08:52 PM   #26
Rogue_Alphonse
Rogue_Alphonse's Avatar
Re: Factory ac keep you cool?
I do! I self-converted mine to R-134A by making sure the system had no refrigerant left in it, then dropped in some 134, an oil charge, more 134, then a leak/seal charge. It gets so cold that some condensation leaks inside of my truck Now to replace the heater core...
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 08-07-2011, 08:58 PM   #27
Mikewb
to make sure it was empty did you just run a flush through it? and how many cans of 134 does it take to fill an empty system? and how many 12 ounce cans of r12?
Mikewb is offline   Reply With Quote
Old 08-07-2011, 09:00 PM   #28
youwish2bme
youwish2bme's Avatar
My 87 on MAX AC will freeze you out in about 10 miles. The 86 I'm working on now it takes about 15 miles. R12 is the best! It is still available you just have to have a license.
Dave
youwish2bme is offline   Reply With Quote
Old 08-07-2011, 09:05 PM   #29
Mikewb
also how big of bottle of oil did you use? thanks for info guys
Old 08-07-2011, 09:05 PM   #30
Rogue_Alphonse
Talking Re: Factory ac keep you cool?
I did it the worst way anyone could really... I pushed down the schrader valve on the high side and there was nothing, no pressure at all. I had to jump the compressor to get it to draw in the 134, which was out of a 30 pound container using an old R-22 line mated to one of those AutoZone low-side filler kit lines. Just filled it until it started sweating at the compressor.
Today it was 87 and I kept having to turn the switch between Vent and Bi-Lev because it was freezing my foot off with the fan speed all the way down. I can't wait to get the windows tinted now!
It also doesn't affect my highway mileage, but it does affect the city mileage. It helps that it's a diesel I guess.
Old 08-07-2011, 09:07 PM   #31
Mikewb
so you just held it down till nothing came out?
also what do you mean when u say jumped the compressor? and how much of that 30lbs would you guess that it used?
Old 08-07-2011, 09:56 PM   #32
Rogue_Alphonse
Yeah, but it only hissed for about a second. If there had been a lot of pressure behind it I would have evacuated the system.
I had to run a wire from the hot side of the connector right to the battery to make the compressor clutch engage so it was running when the engine was running. Just don't do it like that unless you absolutely have to and get freon in it ASAP.
I put a little over 3 pounds in it all together [no gauge, so not sure] and that's including the oil and leak/seal charges. It was about 102 the day I charged it to it's better to give it a teeny bit more than recommended. The sticker says it had 3 pounds of R-12 in it.
Old 08-07-2011, 10:36 PM   #33
Mikewb
thanks man. Now to figure out how many cans that equalls out to be lol so i dont have to buy 30 lbs
Old 08-07-2011, 10:38 PM   #34
Rogue_Alphonse
Yeah I am lucky enough to get it for free from work thanks to the F-250's losing charge LOL
Old 08-07-2011, 10:42 PM   #35
SSC's76
No No
SSC's76's Avatar
There alot going on here in this thread..... Granted I dont have ac in my truck would be nice on those 105+ days but it doesent bug me.
I can still buy and service R12 but i have not even seen a car on the road that uses R12 in a while. Well not true my father in laws bronco which hasent been touched since new in 92 still blows cold air.
Its always good to replace components when converting to 134 its not needed but but at least replace the orifice, replace the dryer if the system has been open. If there are any spots on the system around the connections that are collecting dirt this means leakage. Replace the o-rings with r134a set. Cheap insurance.
PAG and Ester will mix usually its fine most of the oil is probably gone out of your sytem but hey if your going to do it right replace the dryer and orifice pull the lines on the condenser and flush it. Ester isnt great oil it likes to absorb moisture. Pulling a vacuum on the system boils any moisture out of the system.
R134 runs at higher pressures and creates more heat at the condenser. 134 systems run larger condensers with more surface area to help exchange heat. Replacing the condenser usually isnt an option but a small electric fan in front of the condenser makes a huge improvement especially on retrofitted systems. This is why retrofitted systems do not cool as well in town but seem to freeze you out on the highway.
Anyone seen the price of a bottle of 134 as of late holy crap!
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 08-07-2011, 10:56 PM   #36
Mikewb
after pullin vaccum and evaccuating the system. should i add oil before adding freon?
Old 08-08-2011, 07:40 AM   #37
odee
have any of you guys swapped the orfice tube out for a different one? I have heard of folks using a blue one from a ford?? What about the evap and condenser any changes to them for a better cooling from the ac?
odee is offline   Reply With Quote
Old 08-08-2011, 10:46 AM   #38
Hevy
Hevy's Avatar
Personally I would use the compressor and orifice tube that GM recommends. They put alot of money into R&D to figure out what works best together and they're usually right. If you want to switch to 134 that would be a good idea because R12 is very expensive and getting harder to find.
Hevy is offline   Reply With Quote
Old 08-08-2011, 10:37 PM   #39
SSC's76
No No
SSC's76's Avatar
Yep best way is to get a can of oil and put it in the system first before you put in your charge.
Old 08-09-2011, 12:31 AM   #40
asalazar1910
hows it goin fellas,
just thought while this thread was running i could get some answers to some questions i have regarding the ac.
i have a rebuilt system about 2 years old now, and it blows real cold. but latly ive noticed that when im driving and i have it on max, with the high speed, the air starts to get a little warmer, like i have some small airflow from the vent. just was wondering if it could be that,or that i am a little low on freeon. havnt had the chance to hook up the ac gauges to it to see, just thought i could see what yall had to say about it.
also does anybody know of blower motor from a later year that would have a higher output of airflow that would fit right in on the truck. almost forgot, its a 84 silverado longbed.
first time actually asking questions on this site, have used it alot for trouble shooting, and getting ideas for my truck. ill try and post pics of mine later on the appropriate thread
thanks
asalazar1910 is offline   Reply With Quote
Old 08-09-2011, 11:05 PM   #41
odee
checking back in on this subject, any upgrade to the blower fan out there? Changes to the evap or condenser to upgrade to?
Old 08-10-2011, 06:36 AM   #42
motornut
78K & 79C Jimmys
motornut's Avatar
Just like you said
A friend with a new 2010 dodge caravan lowered for his chair
freezes you on the highway,but you do feel heat when stuck in traffic
thinking it's the extra 40 square feet of space making it harder to cool
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-14-2011, 11:44 AM   #43
BrooKLyn
BrooKLyn's Avatar
Has anyone found a blower motor that blows harder then the factory one ..
BrooKLyn is offline   Reply With Quote
Old 08-14-2011, 06:29 PM   #44
Goldfinger
Goldfinger's Avatar
I ran my truck in "drive" for the first time in a year with a/c on max. I was frozen all day. the higher rpm make all the difference.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
