Old 08-11-2011, 08:43 PM   #26
70cst
70cst's Avatar
Re: The Circuit Rider ... Has an Engine Miss and Water Leak???
Originally Posted by OhioDan View Post
I think Wes sent ya some bad Ju-Ju in that hot dog?LOL Ya never did tell the story behind it last weekend. Do ya just notice the water on the floor, or can ya look up under your dash and see some? Might be leak in windshield washer hose? Just throwing that out there for something to check. Have ya had a vaccumn line to the dist crack or come loose. Are the weights in top of dist. rusty and hanging up? Condensation in dist cap?
Send me yer email, and I'll send ya that pic of that tag I was showing you.
Hope yer problem isn't to hard to fix. Some can be so obvious you overlook them. Dan
The Hot Dog...I could never attend one of WES's events out in Washington so I said he could at least send me a hot dog via UPS. He did and its the rubber Hot Dog.
I have an HEI set up. I have been on the road this week so I haven't had an opportunity to check anything out.
Water...only during the rain storm. I will not let a little water and engine miss get this kid down.
I hope to post some info about the winners of the meet tonite. I will pm you my email address. Again it was great meeting up with you.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-12-2011, 12:28 AM   #27
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Bad ju-ju..... Well I will let you know my hotdogs are tested ju-ju free!!
DeWayne, try running a bead of windshield sealant under the gasket where it meets the windshield frame. I have a ju-ju free feeling that the water is getting past the gasket where your door pillars meet the upper and lower windshield frame. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-12-2011, 12:50 AM   #28
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
I have run into the miss issue with the coil severay times, brand new coil not performing correctly, the spring and rubber underneath were installed incorrectly, the same miss with a vaccum line cracked, worn cam lobe, fuel filters as the previous owner didn't realize the factory q jet has the little filter on the carb so they had installed a second inline on the frame and both were marginal, and a faulty electric choke that was stuck open, all worth checking easiest to hardest, as for the water, I have run into this with a poor window seal, good luck with the truck
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 08-12-2011, 01:34 AM   #29
PHAT TONY
PHAT TONY's Avatar
Windshield leak is no big deal; there's factory drainage engineered into these trucks-drain holes at the base of the w/shield pillars meant to track down and out the rockers. I'd bet the waters coming in at the top corners; the joint of the w/shield pillars and upper cab header-a good gooping will fix 'er up! If your miss is under load, I'd look for a weak spark plug/burnt plug wire; weak spark will fire until cylinder pressure increases=load.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
