#26 |
Re: Straight Six Engine Gurus, I Need Your Help!
It's a brand new head gasket n I have no smoke that comes out. N I tightened it according to what I saw on the specs. Do u think maybe I didn't do it right n that's why it leaks?
#27 |
Post Whore
![]() Join Date: Mar 2013
You get more torque with stroking and less high end RPM is the problem. lol With the 230 and 250's short strokes 6000-8000 rpm for them is WAY easier than it is for the 292 with its Long stroke. I find it funny though that I could pull 3rd gear up to 5000 RPM no problem with my Stock 292. haha!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#28 | |
Post Whore
#29 |
Yo tj it's not leaking at the gasket n yes I did about 95 foot lbs n started in the center. What do u mean in 3 steps? Doesn't leak at the freeze plugs. If I can get a picture I'll post it up. Maybe I do have a cracked head. If I did, wouldn't it leak oil though?
#30 | |
Post Whore
#31 |
Ah yes, I kinda figured that's what it meant. N I didn't do it like that. Water does escape our of those ports or so it seems. It doesn't smoke when it runs
#32 |
Tj, so if I took the exhaust manifold n intake manifold n gasket but didn't change the water seals on the head. Do u think that's probably where my issue is? It seems like that's where the water may b seeping
#33 |
Post Whore
Best thing to do would be to run it and then pull the manifolds back off and see if you can locate where the leak is. Or if you can give me some close up pictures that would be cool..
#34 |
Tj, so I went ahead n took off the manifolds after I poured some water down the radiator n sure enough. Rusty freeze plugs leaking. Popped then out n shot to autozone n O'Reillys n neither had a 9/16 freeze plug
#35 |
Post Whore
Try Summit Racing. They should have something.
