Old 09-24-2011, 07:25 PM   #26
becarp@up.net
Re: 72 C-10 new crate motor installed, have questions on the late model serpintine be
Originally Posted by Allen Holloway View Post
Hey guys looking for some help, I have a 72 sw c-10 i've recently installed a 330hp 350 HO Delux Crate motor from Chevy dealer. rigged it up at the time with old brakets and vee belts to get me running. i have recently purchased the SB Serpintine belt drive system deluxe W/air to install on the front of this motor to help with belt slipage. this system comes complete with all brackets, PS pump, 105 amp Altinater, Air compressor, reverse water pump, and pullies and belt needed. i'm ok with all that, but what i'm interested in knowing is: 1. is there any difference in the late model and early(stock) power steering pump? will the hoses connect and pumps serve the same purpose? 2: will the late model altinater connect to existing wiring? any help would be appreciated.. thanks guys..
Allen,
Did you consider the ZZ4? If so why did you go with the 350HO? I can't make the call.
becarp@up.net is offline   Reply With Quote
Old 09-24-2011, 07:53 PM   #27
wwotr
wwotr's Avatar
Originally Posted by becarp@up.net View Post
Allen,
Went with the GM Crate ZZ383/425 in my 67 C-10.
IT WAS A FU**ING BEAST!
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 09-24-2011, 09:00 PM   #28
cparman
sharp as a marble
should be a no brainer. Did the same motor, and serp belt swap to my Blazer. You will need to get some help with the connector to the alternator to wire it to make it charge. I also removed the fitting from the existing power steering pump and installed it into the new pump for it to accept the existing P/S pressure hose. Pics, coming if i can
cparman is offline   Reply With Quote
Old 09-24-2011, 10:23 PM   #29
dfwright
dfwright's Avatar
This may be a stupid question, but I assume the "SB Serpentine belt drive system deluxe W/air" is a kit from the Dealer as well?
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-26-2011, 08:42 PM   #30
becarp@up.net
You did a great job. May be too much motor for me, but it looks really, really great. I was worried the ZZ4 would be too much, but after seeing yours, it should be no issue.
Any thoughts on the 350 HO vs. ZZ4, being but in a 1972 Chev 4WD, short box, Turbo 350, 4.10 gears?
