Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-05-2012, 04:40 PM   #26
hyatt
Re: Dynamat the Cab......
I have built streetrods for 25 years and I go to lowes and get the rolls of silver insulation and 3m spray glue and cut and cover the entire floor,cowl,roof etc Easy to work with and not too expensive
hyatt is offline   Reply With Quote
Old 12-06-2012, 02:26 PM   #27
Roman_Soldier1989
And that works at quieting the cars
Roman_Soldier1989 is offline   Reply With Quote
Old 12-06-2012, 04:03 PM   #28
hyatt
quiets and keeps out engine heat
Old 12-21-2012, 09:26 AM   #29
WadmalawJoe
WadmalawJoe's Avatar
Hey Hyatt, are talking about the silver insulation with air bubbles in it? It's two layers of silver/foil with like thin bubble wrap in between. I used it inside my doors but I was wondering about under the carpet, how it would hold up especially in the foot traffic area. Maybe the carpet would disperse the pressure enough to keep the air pockets from getting crushed?
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 12-21-2012, 09:45 AM   #30
hyatt
works great under carpet
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
Old 12-21-2012, 10:53 AM   #31
mygmctruck
Thought I would pass this along , I buy rolls of this same type product from a company called insulation 4 less. It's a 1/8" foam product sandwiched between foil , it's has much better insulating qualities and easier to work with.
It's also much cheaper per square ft . I took a sheetmetal box and lined it with this stuff , put it in direct sun lite for 2 hrs. The out side air temp was 90 that day , the surface temp of the metal box was about 120 and the inside temp stayed at 70 . So this stuff does great at what it's made for.
mygmctruck is offline   Reply With Quote
Old 12-23-2012, 05:12 AM   #32
oldspowered67C10
I used dynamat on my cab and it does help but dont expect miracles, biggest problem with these truck is the side glass isnt flush to the body like most modern cars and wind buffeting will always be a issue. Also, dynamat is a damper and while it quits panels down it DOES NOT block or absorb sound so it needs to be used with a barrier and a absorber for best effects. Also, although it cant hurt, there is no reason to completely cover a panel w/ dynamat, you only need enough to weigh the panel down.
oldspowered67C10 is offline   Reply With Quote
Old 12-28-2012, 10:42 AM   #33
king-918
king-918's Avatar
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 01-11-2013, 01:04 PM   #34
djrickygaz
Originally Posted by 66GTO66C10 View Post
Good luck!
Mike......
Hey Mike how quiet is it inside the cab with that Fat Mat installed?
djrickygaz is offline   Reply With Quote
Old 01-30-2013, 11:43 AM   #35
Tshort1
Tshort1's Avatar
I am currently doing my cab with the above picture of Peel and seal. So far I am really happy with it. Goes on easy and deadens the ping when you tap on metal to more of a thug. Good stuff and it's 14 bucks for a 6" by 25 foot roll. I figure 6 rolls will be able to all of my cab and doors.
Tshort1 is offline   Reply With Quote
Old 01-30-2013, 11:56 AM   #36
jimmydean
jimmydean's Avatar
The sound in the doors alone was so worth it. When the door shuts, it sounds like a new truck. Solid, no rattle, and the cab is so quiet. At least until the stereo goes in.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-30-2013, 12:26 PM   #37
tubbedII
needs more $$$
tubbedII's Avatar
So I picked up a new ride (63 Nova)...and I'm going to try out the Peel & Seal with this one. This will be my DD once road worthy, so I'm trying to cut corners everywhere I can. Just curious on the barrier part...I'm pretty sure I'm not going to get as lucky as you JimmyDean with getting some industrial rubber mat for free, but what's the recommendation for some cheap but decent alternatives? There's a kit for it that's only like $50 which seems to be like jute matting or rubber...you think that's a fair price? It covers pretty much all the floor.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 02-05-2013, 04:18 PM   #38
mrhino
Just letting you know That I Have Soundener kits available. It is very very similar to Dynamat. click the link in the signature or you can pm me if interested.
85 supersierra's truck
my truck
mrhino is offline   Reply With Quote
Old 05-30-2014, 10:51 PM   #39
infinite-foamies
How about for thermal resistance? Up at school we had three weeks of -30f and a long time of -20f. I plan to camp in my burb as well so I would like to do something that will help insulate. I couldn't care less about noise.
infinite-foamies is offline   Reply With Quote
Old 06-21-2014, 11:47 PM   #40
thelonerife
thelonerife's Avatar
I've used Dynamat before and will use it again. I like the way it quiets down all the road noise. I had a truck with the tank still in the cab and I stuck some on the tank also and it helped with the sloshing noise in the tank. I just put the Dynamat extreme in my GMC and I'm sure it'll be nice when I'm done. I did the floor, back wall, kick panels, behind the kick panel speaker panels and the rear 6x9 panels, door where the panel goes. and the door panels since they are plastic. I ordered 72 Square feet and had 1 2/3 sheet left.
thelonerife is offline   Reply With Quote
Old 06-22-2014, 03:07 AM   #41
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Deadening is great, but I'll toss in my .02
While I agree with covering the whole floor for vibration/sound/heat resistance...thats really the only thing that benefits from complete coverage. I've seen people waste a TON of cash and add a TON of weight by trying to dynamat everything, for pretty much no reason.
On a door panel, 1 or 2 10x10ish squares will add the mass to the door, and help cancel out vibrations from the door or the speakers. Same goes for people who do the whole roof lining, or the whole inside of the firewall.
Dynamat is 1 single tool in the list of things to use when prepping your cab. Peel n stick works great for the price, and due to its thin-ness, you can bend it easily into tight areas. It also works great for floors because unlike dynamat, it doesn't add 1/4 of depth. Nothing sucks more than finding out your carpet looks like a poo-diaper because of all the d-mat under it.
Spray lining like lizard skin offers similar benefits, and more in the way of heat resistance. Its better for complete coverage, and can get into contours the other stuff cant. Using it on the underside of the cab floor will not only help rustprotect your undercarriage, but offer the same benefit as dynamat.
On the firewall, there are thermal barriers that offer better protection over a thin layer of mat, vs building up layers of the stuff.
While SPL/DB cars may be a slightly different story, even they use a variety of materials to deaden the car. A single mat kit can do most of a truck, if you use it correctly.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-08-2014, 10:50 AM   #42
bcontractor
bcontractor's Avatar
What ever u use ..make sure is is flame retardant and poses no health hazards
....I love to use torch down roofing ..but not sure about those issues...
bcontractor is offline   Reply With Quote
Old 09-12-2014, 02:21 PM   #43
Andy4639
Old member
Andy4639's Avatar
Cool Re: Dynamat the Cab......
I basically did the whole floor and rear of cab wall because I removed the gas tank and have my sub box back there. The doors I did 5 pieces in each. 1 piece was 12"x12" in the center then 6"x6" in each corner of the door per my local radio shop guy. I think it made a huge improvement in the sound.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-23-2014, 05:18 PM   #44
Tree-50
Just so y'all know, dynamat and the likes don't really do anything for sound DAMPENING. Those adhesive/foil back products are for mass loading, aka to stop vibrations by adding weight and changing resonance frequency. Do I think it's useless, no, but it's not going to do a whole lot on the floor board outside of insulation just because the seats are going to brace it and stabilize it anyways, not to mention there isn't a whole lot to rattle down there.
If you wanted to actually dampen your vehicle for sound proof, you would need stuff like closed cell foam.
(I know this thread is old)
Tree-50 is offline   Reply With Quote
Old 09-23-2014, 11:57 PM   #45
Andy4639
Old member
Andy4639's Avatar
Wink Re: Dynamat the Cab......
The flloor was covered with roadkill mat along with the bubble wrap from lowes then the carpet that has the jut backing on it.
I'm not doing sound offs with my truck but it sure made it sound better and the doors shut with a thud now.
Some day when I install the electric bucket, heated seats I will go back and put the Mass Loaded Vinyl in it as well.
For now though it's fine.
Old 09-25-2014, 03:57 AM   #46
full foot notch
id like to dynamat my truck, but if I ever have to do any patch panels I know its going to be a ***** to cut and weld without the stuff smoking or catching fire and trying to remove it.
full foot notch is offline   Reply With Quote
Old 11-30-2014, 01:25 PM   #47
schpeen
schpeen's Avatar
i did the inside of the cab inside the doors and also did under the hood. Like night and day! worth every penny and then some
schpeen is offline   Reply With Quote
Old 03-05-2016, 11:45 PM   #48
345HP87SSAC
Humm So many opinions. I may looking into the Lowes stuff too....
345HP87SSAC is offline   Reply With Quote
Old 03-06-2016, 02:13 PM   #49
dwcsr
Hollister Road Co.
dwcsr's Avatar
Another option we use is the deadening strips in various places, not the whole cab or floor, to change the resonance and then use THERMOZITE over top for heat control. we also use a heat resistant product like Thermo-Tec adhesive backed heat barrier on the firewall and underside of the tunnel. It cuts the noise dramatically and also salve a ton over the premium brand name products. The nice thing out Thermozite is its a poly fiber and won't hold moisture to rot a floor panel.
If you have a sub box or high end sound then you may want to cover more area then add the Thermozite.
The object is to keep road noise out, engine noise and heat out, cool in, and dampen or change the frequency of the sheet metal vibration to a point where we can't hear it.
And as stated above it will never be a Lexus but it can be very comfortable.
dwcsr is offline   Reply With Quote
