#26 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Completely reworking the hood
If I may make a suggestion. If you do decide to give it a try, see if you can find a not so perfect hood to try it out on. That way if something goes wrong, or it just doesn't work out the way you want, you haven't ruined a good hood.
#27 | |
1961 crewcab
porterbuilts custom hinges would work perfect for this... and there is a chance you could still use the originals, with a weaker spring... also check out this guys pancake hood: http://67-72chevytrucks.com/vboard/s...392728&page=11 it is pretty much done on page 11. if you can find a picture, that body kit that they use to make a 88-96 look like a 64 has the same hood idea that you are proposing....
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#28 |
![]() Join Date: Mar 2005
I agree with suzq044. The look is a little cleaner, and a bit less work. Plus, you can still use the factory latch. I really like the idea of welding the sides of the hood and fender together as one unit. It'll serve a few purposes: One, it'll make the body line look consistent all the way down the side of the truck. Two, it will solve the hassle of inner wheel wells. In stock configuration with a large diameter wheel, the tire hangs way outside the top of the fender and it's nearly impossible to make a inner fender and still have the hood open and close. I like my stuff slammed, but I do not like the look of an engine compartment with no inner fenders. It looks unfinished and makes a mess of the engine by all the water and mud slinging off of the tires.
With this hood mod on a truck with a darker color, you'll have folks scratching their heads trying to figure out what's different. Perfect!!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#29 |
Just here to tinker
![]() Join Date: Jun 2008
Man I am really liking the idea on this one. Can't wait to see what you accomplish!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#30 |
I did another chop on a truck with a few angles to look at. I still don't know what to think.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#31 |
Resident Photoshop Nerd
The side angle doesn't look quite right compared to the front angle.. Like it's a little TOO far off the side ?
I say just line it up with the a-pillar.. or close to it. ![]()
PJ - 1966 C10 Panel -- Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn Last edited by suzq044; 08-25-2011 at 02:57 AM. |
#32 |
The more I look at it the better I like it..
Posted via Mobile Device |
#33 |
[QUOTE=suzq044;4863946]The side angle doesn't look quite right compared to the front angle.. Like it's a little TOO far off the side ?
I say just line it up with the a-pillar.. or close to it. The reason I'm putting the seam there is because at the rear of the hood there is a contour I don't want to cut through and it's going to be even with the top of the bed rail. There's a hood on craigslist right now that I could probably get for $40. Maybe I'll buy it and cut it up.
#34 |
I really like it. It's different for sure, but I think it works. It's just hard when you are used to seeing it "regular".
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#35 |
i like it - wondering how this would make running no hood look too.............
#36 | |
PJ - 1966 C10 Panel -- Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn |
#37 |
1961 crewcab
I did a couple tiny refinements that I think really clean this design up....
1) stopping the seam at the cowl extension. I would weld it up solid, you can actually move the two upper fender bolts (under the cowl extension) to inside the vehicle, I did this on my 61, you can weld a nut to the fender, and then access the bolt from inside the kick panel vent.,I would put the seam between the cowl vent/grate , and the cowl extension right where the wiper transmission is. 2)I took away the seam at the hood corner, by the blinker. then I moved the hood opening up to where the factory seam is across and above the blinkers.
#38 | |
1# Drobmember in Germany
![]() Join Date: Aug 2008
Pat |
#39 |
ok you guys have crazy photoshopability - im lucky to draw a straight line
Jonz - I see where you are going, and it does clean it up but it looks too eurostyle - I like the last one shrunkn66 did with the cowl seem as it keeps an older look. splittin hairs here of course and i still wanna see what it looks like with the hood off ![]() |
#40 |
![]() Join Date: May 2007
not to be devils advocate but I think you will work a long time trying to get the shut lines that small and clean. more likely, from where you have the tape it looks like you will be staring into the gap.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#41 | |
#42 | |
#43 | |
I have seen when an automaker puts the shut line on a slope like that and you can really see it. ![]()
#44 | |
1961 crewcab
I do see what you are saying, where the gap is, is right in a spot where you could look straight in...
#45 |
It's almost going to be exactly like my 03' Tahoe.
#46 |
I can't figure this one out.
#47 |
Hey, Stroker... I borrowed one of your pics to ask a question. I hope you don't mind. I have been looking for these panels and had no luck (Mainly, because I don't know exactly what they are called). Not fenders, not corners - Idunno!! What are these called and where can I get both of them for my truck? Thanks.
Sam Last edited by samuellg1977; 09-02-2011 at 10:37 PM. Reason: Typos |
#48 |
The late 1980's Buick LeSabre had a forward opening hood (I had an 87). The hood was much bigger than the Saab. Might be a more plentiul source for the hood mechanism.
#49 |
I found this awesome mod using the 87 Buick hood parts to make a forward tilt hood.
http://67-72chevytrucks.com/vboard/s...d.php?t=218253 |
#50 | |
60-66 Nut
Those are a part of the fenders. They are spot welded to the rest of the fender. Those parts are not available seperately.
