Old 08-22-2011, 11:19 AM   #26
inovermyhead
Re: coil spring compressing...
I used the one from O'Reilly's and wish I hadn't, scared my powder coated control arms up. I think this one would work well http://www.jegs.com/i/JEGS+Performan...89311/10002/-1
but however, mine is a bare frame so no weight from the engine on it to use the jack method for install. But I used the floor jack method for removal.
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 08-22-2011, 11:31 AM   #27
dropped81
dropped81's Avatar
i have drop coils and the coils are too close together to fit the hooks between!
dropped81 is offline   Reply With Quote
Old 08-22-2011, 11:35 AM   #28
dropped81
dropped81's Avatar
The little block that holds the hooks together wont fit between my coils or through the bottom hole in the control arm and since the angles on the bloc are cut at 90 degrees i cant really maneuver them in any way to make it work.
Old 08-22-2011, 03:38 PM   #29
rwhit57
rwhit57's Avatar
Using the floor jack method can be safe if done right. One thing no one has mentioned is to be sure and block the frame in the rear on the opposite corner, and be sure you have the truck high enough for the lower control arm to rotate all the way down. Also with the bump stop pad still in place it's not as easy to flip the coil out. Take your time, bust the ball joint loose first and ease it down slow and stay to the front of the truck, you don't want to be in front of it if it would get away from you.
rwhit57 is offline   Reply With Quote
Old 08-22-2011, 03:56 PM   #30
Cherub
Cherub's Avatar
I use the jack method all the time and never had a spring shoot out. dont pay for a spring compressor.
Cherub is offline   Reply With Quote
Old 08-22-2011, 04:12 PM   #31
camshaftgsxr
camshaftgsxr's Avatar
this thread makes me lol, 30 replies on how to take a spring out?
camshaftgsxr is offline   Reply With Quote
Old 08-22-2011, 07:38 PM   #32
1LowToy
Quote
30 posts for removing a spring?
Sure am glad were not dealing with gapping ignition points anymore.
1LowToy is offline   Reply With Quote
Old 08-22-2011, 08:59 PM   #33
LONGHAIR
Don't laugh at the newbs, we were all beginners once.
I put my first engine together with nothing but oil on the head bolt threads...The torque specs called for it that way, but w/o some kind of sealer, it leaks coolant like a sieve. It would have been no worse to just pour it directly on the driveway....ask me how I know.
I would much rather answer someone's question regarding caution than how to repair something after a mishap....or hear about stitches.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-22-2011, 10:02 PM   #34
dropped81
dropped81's Avatar
No need to be rude about it bro i'm new to this and have to learn some how safety first man i would rather do it once and do it right than have to re do it or worse get hurt...if you dont have good helpful input than don;t say anything at all im 19 years old and im teaching myself its my daily driver so i have to have it back up and running for the next morning so i have to do it right the first time i cand afford to do it wrong!
Old 08-24-2011, 03:21 PM   #35
camshaftgsxr
im not being rude guys, but 20 of the 30 posts were the SAME thing, it was funny to see everyone saying the same thing over and over.
Old 08-24-2011, 10:44 PM   #36
dropped81
dropped81's Avatar
Why does it matter to you bro...who cares if its repeated its not you thread
Old 08-25-2011, 09:36 AM   #37
camshaftgsxr
why does it matter to you if i make one observation about the amount of repetitive answers? bro :stompysumoguyusedonlytoconveyanaggressiveattitudeinapost:
its the internet get over it
...bro
