#26 |
Grandpa in the rustmobile...
Re: Headlights and Relays
I got my relays from advanced auto for a $1.25 (a dollar and 20 something), thats apiece.
Bought the 10guage wire for about $10 and I already have the rest of the stuff
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#27 |
My biggest reason to install relays was to lower the current coursing through my wiring harness. All headlamp current only goes from the battery to the lights now. Since I have a GMC, my high beams are significantly brighter now.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#28 | |
05 QSM GTO - M6, Corsa, King Springs 70 SWB CST - 350/Auto, Foose 18/17 I upset whiners too.... |
#29 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Maybe this diagram will help
And a couple threads from the FAQ section of the electrical forum: http://67-72chevytrucks.com/vboard/s...d.php?t=182351 http://67-72chevytrucks.com/vboard/s...d.php?t=188478
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 08-21-2011 at 11:31 PM. |
#30 |
Another important thing in my opinion to think about when doing headlight relays is the headlight switch you'll be saving.
Back in my shop days I replaced alot of headlight switches. All that lost voltage has to go somewhere. Where it goes is it is turned into heat which eventually destroys your headlight switch. I use 10 gauge wire for everything between the battery and the lights. For the circuit to turn on the relay I use the stock wiring. All you're doing is converting your existing headlight switch into a relay controller. Back in about 1985 when I installed halogen sealed beams in my '71 Monte I thought man! Look at all that light. When you get your relays installed and use those same halogens you'll wonder why people waste their money on Hellas and other aftermarket lights. And roll your own harness. 1. It is cheaper. 2. You'll be forced to understand how the wiring works. Which is nice because then you'll know how to trouble shoot it if something breaks.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#31 |
To roll your own, look at stocker's picture.
Print it out. The green wire from 87 on the high relay and the brown wire from 87 on the low relay are wires you need to make out of 10 or 12 gauge wire. The red wire from the + side of the battery to the 30 on the relays you make WITH A SELF RESETTING CIRCUIT BREAKER protecting it from mishaps. Before you start take your test light or volt meter out and mark the existing wires at the back of the headlights. Turn on your low beams. See which wire has voltage and mark it "Low" with masking tape or similar. Also keep track of which position "Low" is in the plug. Turn on your high beams. Mark that wire high. Note its position in the plug. After wires and plugs are marked I like to take the plug off the headlight and remove the wire from the plug. That way I can reuse the plug. A small, flatblade screwdriver inserted in the connector will allow you to depress the little tang and pop the wire out. The wire you marked "Low" goes to terminal 85 on the low relay. The wire you marked "high" goes to terminal 85 on the high relay. Use Black colored 10 or 12 gauge wire and replace the grounds at the headlight plugs. From NAPA get a couple of the correct connectors, part number 725147. This is the brass colored insert you pop out of the stock wiring plug at the headlight. Use these for 10 or 12 gauge wire you are making from the relay to the headlight. Also for the headlight side of the new ground wires you made. Make sure the wire from the "Low" relay goes to the position you marked "Low". Same for high. Lesson learned: I mounted the relays on the side of the truck that feeds the other side of the headlights. I used the stock wiring and stock connectors to terminal 85 on the relays. I didn't cut a single wire. One day driving down the road my lights started blinking between high and low beam. It turns out the wires that I didn't cut on the other side from the relays were vibrating together which caused voltage to alternate between the high and low relays. A couple pieces of electrical tape fixed that. Long story short, if you do the relays the way I did you preserve the stock wiring for some future concours restoration, you now have a basic understanding of how the relays work, and you got some kick-butt light out of your headlights.
#32 |
@mrein3, I have to take issue with you when you say "you'll wonder why people waste their money on Hellas and other aftermarket lights." I'd have to say that Hella is one of the finest halogen lights in the world, along with Marchal and a couple of others. Hella is still OEM on Porsche, BMW, and Mercedes and many other high cars and trucks. Their driving and fog lights are fitted to the worlds winningist Rally cars. Hella lights are only a "waste" if you live someplace where you can't use them or they are poorly installed! Marchal lights are probably just as good but I don't like French products. My headlights are German made 7" Hella H-4s, and my driving lights are Hella 500s because I believe that they are the best in the world!
#33 | |
20' Daredevil (Ret)
Installing my first Marchals in the early 1970s was a real eye-opener (pun intended). Marchal apparently no longer exists, or at least is not available in the USA. Hellas are commonly available, great quality, and not overly expensive. Cibies are harder to find and costlier, but I prefer their beam pattern to Hellas.
#34 |
![]() Join Date: Mar 2010
I am with you Hatred...It makes my mind numb, but i am subscribed so i can figure this thing out. Great thread.
1969 Chevy K20 Longbed |
#35 | |
![]() Join Date: Mar 2011
The fact that your voltage is low at the lamps means the path's resistance is too high (current is restricted and volts drop - Ohm's Law). This can be wire size, connector integrity, switch contacts and/or grounding. The voltage you read is the sum total of all this. Others have chimed in here with suggestions of how... just thought I would answer the "why".
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 Last edited by DesertCat; 08-23-2011 at 01:05 AM. Reason: spelling |
#36 |
Thanks for everyone's input! I just back from vaction and now have the time to look at some of the threads I was involved in before I left. I have several electrical projects to tackle so this is one of them that I'll put high on the list. I'll let ya'll know how it goes!!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#37 |
So I skipped reading a few posts, and gotta say the relay upgrades kinda suck. Every underhood relay I've installed (factory relays protected from water in the plastic boxes excluded) gets moisture in it, gets rusty, and stops working. Every one. I also picked up that made in China crappy yellow wiring harness with relays from LMC when I did the halogen conversion. I love the conversion. Wasted money on the harness. It wasn't long enough, and it was YELLOW.
But please, if you decide to do any conversion, use LOTS of zipties (and trim them) some split looming, and a little tape here. It kills me to see 14 inches of wire when 2 inches would do, wire nuts and masking tape, wires hanging all over... |
#38 | |
#39 | |
#40 |
Wasn't my idea!! Believe me!! Mama said I had to go!!
#41 |
![]() Join Date: Feb 2011
I bought the headlights and harness from LMC. The lights look good, but they are cheap plastic (I'll probably switch to a glass version later). The harness, made the job easier, but I had to add a few inches of wire to reach the driver's side headlight which is lame. I also had to use some black plastic loom to cover that ugly bright yellow loom.
1969 C/20, 307, 4-speed, rusty with manual steering and brakes! |
#42 | |
#43 |
To add to this discussion:A current thread dreadged up some old threads about headlights and I paid attention to the headlight suggestions on this thread. I am going to add either the Jeep headlights or the Sylvania Silverstars. I don't wanna run the risk of regret by buying some cheap headlights. Working now to lower my truck but when I do this upgrade I'll do one side first and leave the other stock to show the improvements because none of the threads I've found actually showed what improvements were made.
#44 |
Old member
I've had mine in the truck for over a year with no problems. I wired them in myself and made my own connections. The lights are relays aren't the question here. It's the how to do it and why.
You want as much voltage and amps to the light that you can get from the battery and you don't want them dropping out in either one while driving. So you add a straight wire that will carry the load of both the high beams being on from the battery to the relay. Then you use the old wires from the factory head lights to turn the relay on. On a Chevy truck one relay per low/high beam light is enough. Once you have the relays in place the head light switch hardly see any amps and will last forever. You now have less load on the entire electrical system in the truck because of the relays. Your whole wiring system will thank you. As for a GMC they are no differant except they have more connections. 2 relays will be enough.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
