04-14-2003, 11:17 PM | #26 |
I think the battery was under the seat in the 1953 GMC pickup that my dad had when I was a kid. Don't think that would be a great place for one but also think it could be done if you really wanted to. Some sort of box with a seal and vents should be possible. Motorcycles have the battery tucked up under the seat with a vent hose down under to drain any fumes or excess fluid.
On the frame under the truck would be out of the way but I hope you never need a jumpstart.
1968 Chevy - 292 with a powerglide |
04-15-2003, 09:20 AM | #27 |
Spank 'em if you got 'em!
That's another issue, the jumpstart. If your going to the trouble to relocate your battery, why not run terminal leads up under the hood for easy access?
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
04-15-2003, 01:32 PM | #28 |
Here's where I put my battery terminals.
04-15-2003, 03:13 PM | #29 |
383 Stroker,
Is that for real? Is it the front or the back? How exactly to you keep from grounding onto the bumper when hooking up the +.
04-15-2003, 03:56 PM | #30 |
Long Knight, yeah it's real. The battery is in the back by the fuel cell and the remote terminals are in the back near the tag. Ive had it that way for 9 years without any problems. Here's another picture.
04-15-2003, 04:09 PM | #31 |
That's a great idea! Just thinking of how much of a pain it is sometimes to pull nose to nose with someone for a jump. Now I have another good idea to add to my list. I still want to know if you have any scares hooking up that hot?
04-15-2003, 04:15 PM | #32 |
It is close, so you do have to be careful. All I ever hook to it is a battery charger, so it's not a big deal to me.
04-15-2003, 05:37 PM | #33 |
yeller
Here is the one I am going to be installing under the bed...
http://www.classicperform.com/produc...ropout-Box.htm -Jeff |
04-15-2003, 07:08 PM | #34 | |
Seņor Member
Kenneth
04-16-2003, 10:12 AM | #35 |
It's a catastrophic success.
I used a plug from a battery powered fork lift.made up a pair of jumper cables with one end for the plug and clamps on the other.
04-16-2003, 11:53 AM | #36 | |
Seņor Member
Something like this...
04-16-2003, 02:17 PM | #37 |
Have a look at what this fellow has done with a Toyota 4Runner.
http://4crawler.cruiserpages.com/4x4...atteries.shtml
04-16-2003, 02:53 PM | #38 |
That's a pretty neat set up...but it seems a little strange to relocate your battery out of your engine compartment just so you can drill some big holes in your floor for some all-thread. But who am I to be a critic, I like my battery under the hood near all the things that use it. LOL!
04-16-2003, 03:19 PM | #39 |
Mine is very close to 1971Stepside's but I hinged the bottom and use bolts on the side straps to hold it up. Still a pain to get it in and out. I use a boat battery box to keep the crap off of it. Its ugly but if someone wants a pic I could put one up.
As far as jump starts Im running a ford style relay on the firewall thats easy to get to. The only thing this battery does is start the truck. The battery in the stock location does every thing else. I had thought about putting it under the pax floorboard and making an access panel under the mat.
The more I learn about women, the more I love my truck. Last edited by 6869704X4; 04-16-2003 at 03:21 PM. |
04-16-2003, 04:36 PM | #40 |
Post Whore
383 Stroker - I am impressed, what a cool way to do the battery!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
04-16-2003, 06:11 PM | #41 |
I like the setup that 383 Stroker is running.
I am going to design a stainless steel battery box and make it myself. Similair to the one Big Block 73 is going to use. I think the grade of stainless I should ude is somthinfg like 308 ? sound right ? Thanks for all the cool Ideas.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-16-2003, 07:40 PM | #42 |
hey 383 stroker...where is your battery on/off switch located?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
04-16-2003, 08:20 PM | #43 |
bigjimzlll, look on the 1st page at the picture of my battery box. The switch is at the top left side of that picture.
04-16-2003, 08:42 PM | #44 |
is that on the side of the frame? Im having a hard time figuring where everything is in relation to the rear of the truck(I know where the jumper poles are..lol)
04-16-2003, 08:53 PM | #45 |
Yeah, it's on the frame. You can see the rearend cover in the picture, maybe that will help you figure out where it's at.
04-16-2003, 08:59 PM | #46 |
This picture is a little brighter. Maybe it will help.
04-16-2003, 09:07 PM | #47 |
yeller
383...
Most NHRA sanctioned tracks require that the on/off switch on battery relocated vehilces be visible...like on the back bumper etc in case of fire or accident...yours seems to be a bit hidden. Have you had any experiences at the track yet...have they said anything? -Jeff |
04-16-2003, 09:13 PM | #48 |
yea..thats what im trying to figure out..im going to relocate the battery, and trying to find a good place for the switch
04-16-2003, 09:37 PM | #49 |
bigblock73, they haven't said anything about it so far. But it might be the tech guy at this track. The track I go to is a NHRA track, but it's 1/8 mile.
04-16-2003, 11:23 PM | #50 |
Seņor Member
Alright, I give up... there is no place under my bed that I can locate a group 24 sized battery
