09-11-2011, 10:01 PM | #26 |
Re: 63 suburban newbie build first day
Thanks guys for the kind words...Definite improvement...I got the whole truck minus the front clip finished....I have a little bit left on that driver side rear back quarter under the tail light..Man that was a bi**h by the way...No I went to harbor freight to pick up the uni spoter and nothing..I guess its a specialty item..even though its online..I ended up doing it old school with the a small drill bit...and the slide hammer..I was not worried about making extra holes because those quarters were fix before using the same method but I guess they screwed them up again. I wanted to ask what I should use as a primer to cover all that exposed metal. Keep in mind that I am on a real tight budget. I have used rustoleum in the past diluted and shot with a gun..Comes out looking good ever time, but this time I might want to spray real paint and not the usual satin black which I love. Not sure if they are compatible since its not an automotive primer. Thanks and god bless.
09-12-2011, 12:44 AM | #27 |
60-66 Nut
That quarter panel turned out nice
The correct primer to use over bare steel is an epoxy primer. But typically that is applied immediately after blasting to eliminate any flash/surface rust. Then your body work is done over the epoxy. Then after the body work and filler is complete, you would want to start applying the primer surfacer. But of course that all costs a lot of $$$$$.
09-12-2011, 01:09 AM | #28 |
Thanks cap'n.... I am broke lol. So what do you recommend ? I wonder if that duplicolor auto shop primer will do.
09-12-2011, 06:17 AM | #29 |
65 suburban vortec 5.3 bagged
anything is better than nothing looking great!!
09-12-2011, 07:30 AM | #30 |
Yup. A can of rustoleum is better than bare steel...but if you do real auto paint you'll have to go back to bare metal again.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
09-12-2011, 10:24 AM | #31 |
I got the tubular mounts at the Truck and Car Shop. They run around $130. You live close by them I believe. www.truckandcarshop.com
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-12-2011, 10:50 AM | #32 |
Ok guys I will do some rusto them.....Really did not know that the truck and auto shop had them available...Now that's convenient ...im 2 minutes away from there. koool.....So today I am taclikng the driver side tail light quarter section..I fulled it out yesterday and shaped it as best I could, I also have done to very thin coats of bondo on there..I will post pics of before and after today..Thanks
09-12-2011, 07:25 PM | #33 |
Here are some pics of the driver side rear quarter panel repaired...This panel was a pain in the rear..The dent was very big, deep . I think it can out very good..You guys be the judge. All it needs now is a little of that soft filler that comes in a tube for the small scratches and pin holes. I believe all parts stores carry it.
09-12-2011, 07:30 PM | #34 |
Before and after
09-13-2011, 08:25 PM | #35 |
Hey fellow c10ers here are some pics of the body painted.. I used rustoleum primer for bare metal ..Its for super rusty metal which my truck was not but I am using it because its better at protecting the metal than the other rustoleum primers..I reduced it with acetone about 4 % and shot it with my $30 harbor freight lvlp gun.. I know that automotive paints are superior to rusto but I have had lots of compliments on my satin finishes. Also its never pealed or lost its sheen on me. Maybe when I have money I will paint her with real paint but for now rusto will do. Lol. I chose a hunter green satin color for the body and gloss white for the roof. Interior I am still lost on..Not sure but I like candys with flake alot...sorta like the ones you see on chopped old mercs. I might do something crazy like candy apple green on the dash and maybe on the roof instead of white...Any suggestions on what color to do the roof and interior to blend nice with that hunter satin green
09-13-2011, 08:28 PM | #36 |
I did it again! damm I forgot to load the pics!!!!
09-14-2011, 06:19 AM | #37 |
nice job whats next!?
09-14-2011, 10:44 AM | #38 |
Today I am cleaning up the interior from all the media blast left behind....and,prep and shoot some primer,then probably block the exterior again and maybe even shoot the satin..I will post pics
09-14-2011, 11:21 PM | #39 |
So I primed the interior dash, doors,roof etc.. I got lazy so I will upload some pics tomorrow.. My build seems quite as of late. So whats a good color for the interior and the roof? white? The body is going to be satin hunter green..I was thinking of painting the roof white or some crazy color like candy apple green ..Not sure on what color to do and what paint finish.. Note this is a budget build so I am spraying her with rustoleum paints reduced with acetone and shot with a gun.. Please any ideas of color combos are welcomed
09-17-2011, 05:31 PM | #40 |
Here are some pics of the suburban painted... Rustoleum hunter green satin diluted 15% with acetone and sprayed with a harbor freight gun..whatcha think?
09-17-2011, 11:00 PM | #41 |
I have sprayed rustoleum before , and will probably do it again ,didnt use acetone , and mine took a long time to dry ....
09-17-2011, 11:45 PM | #42 |
09-18-2011, 12:31 AM | #43 |
Hey thats looking pretty good. I dont care for the white but cant think of a color other than white or maybe cream to go with that green looks good though.
09-18-2011, 12:43 AM | #44 |
Thanks for the positive comments. Yeah my quarters were pretty far gone. The worst was the driver side under the tail light..I used a slide hammer that I picked up at pep boys. ( saw them also at auto zone) it was under 20 dollars.. Used that to pull out the dent as far as I could with out being to far out...I also used a body hammer( The one with the pointy end) to hammer down high spots. I wanted little bondo to prevent cracking.. I ended up using about 1/4 thickness of bondo on the worst spots which is not bad I think. By no means am I a body guy. This was my first dent pull. By the time I pulled my passenger quarter I felt real confident at tackling the other side. If I can do it you can to. I will gladly answer any questions.. As far as the paint... I reduced it with acetone 15% give or take . That helps it shoot out smooth and helps with runs. Also It dries to the touch in a little over an hour.. Good luck guys...and go burbans... we need more burban guys!
09-18-2011, 02:22 AM | #45 |
1960 GMC Burb
Man..you are cranking along ! Mine has taken so many left turns over the last 2 years, but has made progress lately. You have done a great job.
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
09-18-2011, 05:46 AM | #46 |
UCA63
looks great
love that green T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
09-18-2011, 08:48 AM | #47 |
Man you dont mess around¡¡ great progress whats next¿
Posted via Mobile Device |
09-18-2011, 12:39 PM | #48 |
Lol guys... Thanks for the comments...Yeah the green is cool looks good in the sun with the green and the gloss white top.Just need some wheels now..Probably 20's and up. Not sure whats next since I have so much S*** to do .Lol. I need to finish the media blast for the front but I need that grill filler piece. Mine is pretty far gone to try and fix. I think I am going to start today by painting the frame and firewall.. Also I need to track down the side glass and install the windshield. I will keep ya posted. Stranger thanks for the M/O you should have your piece mid week.
09-18-2011, 05:21 PM | #49 |
Awesome thanks¡ let me know if you need some side windows.
09-18-2011, 05:26 PM | #50 | |
