Old 10-22-2011, 08:09 AM   #26
coulter
coulter's Avatar
Re: Corina Patina 65 low rider
looking really good so far man!! thats gonna be a cool looking truck
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 11-07-2011, 06:02 PM   #27
Dustin07
Stirrer of the Pot
sub'd, I want to see how you go with those bags
Dustin07 is offline   Reply With Quote
Old 11-08-2011, 09:49 AM   #28
kieth
kieth's Avatar
Business got in the way of working on Corina, we are moving the rear axle back 1-1.5" (whole crossmember) then we have to finish the front end and see where we end up on height. then we will install the rear bags. Since we are not going for a prostreet look (with super wide tires) I think the bags will be behind the rear axle at the trailing arm..........or possibly on top of the rear axle but still outside the frame.....we will see next week. Kieth
kieth is offline   Reply With Quote
Old 11-08-2011, 09:50 AM   #29
kieth
kieth's Avatar
Originally Posted by propanemudtruck View Post
Hey there, nice rod... I used the same idea on my bike.
Oh now I see it is a hard tail...........ouch that is tough on the back.....Kieth
Old 11-18-2011, 11:39 AM   #30
kieth
kieth's Avatar
Have not updated in a while, Corina is progressing slowly, here are a few pictures,
Installed the 5 x 5 rear axles, put the cragars on so we could make sure the airbags and other suspension components would clear.
Installed 2 x 2 spacer blocks for the rear end
removed the front trailing arm brackets, made spacers to move them back 1.5: and turned them upside down.
getting ready to install them with new bushings...will update later....Kieth
Old 11-18-2011, 01:03 PM   #31
Dustin07
Stirrer of the Pot
hey Kieth, who's bridge kit did you go with, PB? I'm torn between welded and bolt on... I like the simplicity of the bolt on, and the savings of weld on. I've done two other welded notches. just not in the mood lol.
Old 11-18-2011, 02:36 PM   #32
McMurphy
McMurphy's Avatar
Nice build so far, going to keep an eye on this one too!
Thanks and good luck on your rig.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 11-19-2011, 01:00 PM   #33
kieth
kieth's Avatar
Quality air ride (suicide doors) it was $135.00 could not beat the price, but be careful, it does not come with any instructions and you can easily get confused when assembling it. we had to un tack twice before final welding. (you have to assemble it upside down so if you do not watch it you will put it together backwards) I would suggest tacking it together before tacking to the truck.
Since we do not have a hearty enough welder we took it took a shop down the street and had them make the pretty welds, cut the frame , etc. cost $125.00 for them to complete it. We just got the donor truck for the front end, power steering, disc brakes, etc so now we take that apart, cup the lower contol arms, rebuild the donor front end , install the front air bags, then we can see how low she is going to go. After that we can finalize the rear suspension.
This is a budget build here is a brief summary of costs to date...
Truck $ 1500.00
Bridge 150.00
welding 125.00
donor
front
end
p/s
vac
boost
mstr
ps
pump 200.00 truck itself
rblt
parts $300.00 we used the donor for the cores
air
bags 230.00 front includes brackets
2.5
spndls $330.00 & rear bags
wheels 36.00 4 cragars---used ($ 9.00 each)
tires 400.00
axle
mods 240.00 front and rear 5 lug drilling and lugs
air
comp 200.00
air
tank 20.00 used aluminum
valve
control 30.00 box electrical
ubolts
2x2
spacers 60.00
air
control
valves 4 160.00 Sub total to date 3971.00
blazer fuel tank 150.00 4121.00
does not include any value of our labor.......Kieth
Old 11-19-2011, 07:46 PM   #34
Dustin07
Stirrer of the Pot
sweet, I'll be watching this build closely I bought my '61 for $2200, new torque ($150), and robbed my '62 of the sbc (paid $1500, but sold seats already for $250, and I already have air compressors, switch, rear bags on the '62 i'll rob). so i'm in to the '61 for $3600 ish so far. I like your idea on the weld on. My mig is strong enough, but I'll ask my wife's cousin to do the welding once its tacked in, he's a certified welder that will save me over $300 from the bolt in notch I was looking at! thats almost enough for the tubular rear trailing arms...hmm......lol (or that bed cover!)
