#26 |
Re: Overheating question
I believe the guys from U.S. Radiator don't ship to Germany. Bad news. I have to find somebody who is willing to purchase the radiator and is going to send it to me afterwards. The best bet is to send is as personal gift (e.g. for my birthday) because than I probably don't have to pay customs in Germany which is 20% (!) on top of the price plus VAT again 19%. These regulations suck guys!
#27 |
![]() This is it! From Arkansas, bought 3 years ago. |
#28 |
I would go with a two row aluminum. I am currently in Kuwait and I have no faith in four row radiators because they block to much air flow.
I struggled with a 88 mustang for years trying to keep it cool using a 4 core. I swopped the four core for a two core aluminum radiator from a 95 Mustang and could cruise at 120 MPH in in 120 degree heat and sit all day in traffic with the a/c on, and that was with a stroked 351W(408). It was amazing I could watch my temp gauge swing from 175 to 185 and back to 175 while cruising down the road (180 degree thermostat). |
#29 |
ah! I have heard so much different things from aluminum radiators and to be honest not so much good things.
what do you thing guys? For what should I go, copper/brass 4row or aluminum 2row ?? cheers for your advice! Posted via Mobile Device |
#30 |
most of these trucks have run quite efficiently for 40 something years with the same style of motors in them, same size. v8 eng takes a shroud. put the proper fan in the proper relationship to the shroud. the right stock capacity rad with proper coolant and the right pressure cap . why are you having a problem? there has to be a reason. what have you done or haven't done differently???????
ron |
#31 | |
My engine is out of a 1980s C10 and it has been bored with bigger pistons and bigger intake valves. That's probably the reason why the temperature raises always when I get stuck in traffic during the summer months. That's why I am searching a solution for my problem during the last years. Posted via Mobile Device |
#32 |
not trying to be smart here. that is basically the same block that they came out with in 1955. guys have been modifying them ever since. that is not a reason really. is the eng in the stk location for a small block or is it sitting in the forward holes( i have already been through this above). you don't have a shroud.
the orig system was designed to use a 50/50 mix of ethylene glycol and water which will raise the boiling point 18 degrees F and a 7lb pressure rad cap which will also raise the boiling point 3 degrees per lb pressure of the cap for a total of another 21 lbs which would give you a total of 251 degrees F before it will boil. newer vehicles have even smaller cooling capacities(smaller but more efficient rads) and how they have overcome this is to raise the boiling point of the coolant- higher pressure system; that last of which I know(and it may be higher now) was that the went to a system that would take a 15 lb cap( and that is quite a few years ago) and that would raise the boiling point to 275 degrees F. so a bigger rad can mean squat really. it is also that relation ship with airflow ans how efficient that you can make it. v8 engs in these trucks used a shroud and the fan was designed to be in a certain position to make that airflow work. if it is further forward in the shroud it is not going to work as efficient. if you can arrive at that relationship then perhaps you may have to go with an electric fan also to create that movement of air to make you cooling system efficient' remember that bigger is just a figment of your imagination. your girlfriend puts up with you doesn't she? ron |
#33 |
Billy send us some more pics of Rad, fan, and shroud if you have one.... if your still running that alum blade fan chuck it and by a clutch -6 blade fan assembly from summit...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#34 | |
"Just like your engine, a radiator needs air to function. It's a water-to-air heat exchanger, so it requires air to flow past a sufficiently large network of tubes that contain flowing engine coolant. The tubes make contact with thin metal fins to further increase the surface area available for cooling. Of course, more surface area means that more of the coolant's heat can be dissipated. The ideal radiator, then, would be built from highly conductive metal with large diameter tubes and maximum tube-to-fin contact, and it would be able to pass air efficiently with minimal restriction. Copper-brass conducts heat considerably better than aluminum does. Bigger tubes and more fins increase surface area. So why don't we build a five-core copper-brass radiator with huge tubes and a bunch of cooling fins? The limitations are material strength, weight, and airflow." If bigger radiators didn't cool better why do larger engines or air cond, equip vehicles always have larger radiators. Because larger coolant capacity and surface area always cool better. Just because you can keep the pressure up so it won't "boil over" and run over 250 degrees doesn't mean that it should ever get that hot. The coolant temperature in all liquid cooled engines can and should run at the thermostat temp ..no more no less, if it doesn't something ain't right. Thats why there called thermostats. When was the last time you saw a new vehicle run over the "normal" temp ..in any conditions? Probably never...the factory extensively tests their systems in conditions that the average user wouldn't even come close to, otherwise they would have recalls all the time for blown head gaskets. Why do older vehicles often have cooling issues? ...they weren't made that way...someone has probably swapped cooling system components and or engine size-type to something different than the original parts. They also very likely have the wrong combo of cooling components for the application: radiator coolant capacity (and surface area), pump flow, fan, shroud, and likely have poor maintenance. |
#35 |
#36 |
Don't remember sayin anything about your post....so why do you give a sh** there's plenty of other forums you can waste your comments on. You got an issue with my post or do you just not have anything else to do? Maybe he is your boyfriend?
![]() ![]() When someone going to post b.s. and contradict my post without anything to back it up ....I'll do two clicks on Google and quote from a real pro, not just make sh** up. ![]() |
#37 | |
grow up |
#38 |
hot topic!
#39 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I used a Champion aluminum 3core radiator I got from Reliable Radiator on evilbay. It cool my little 4.85 perfectly. oh, I also have twin 12" elec fans with it too.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#40 |
i also seen those on ebay,nice lookin units!that is what i plan on getting for mine when i'm ready!decent price too!
#41 |
![]() Join Date: Sep 2009
if that guy would read his own article the last line says shroud-fan and all make a differance just like ron said. maybe he needs to go over to the hamb where every one has an attitude
#42 |
![]() Join Date: Feb 2010
wow, we need a flame board! lol
#43 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
Just a few questions. Is the 1980 350 stock? These were still Quadrajet Carb fed engines if I remember correctly. The fuel / air mixture, timing, and spark all affect engine temperature. What rpm range is your engine idling at? When you fire your engine up from a cold start and let it warm up does it start to overheat or is it fine? You didn't mention it so it may not do that. Are you using a automatic transmission? You mentioned about the water pump and that can leave to overheating if its bad or leaking. I think in the later models chevy they had reverse flows on them. You mentioned the blown head gasket. Did you do a leak-down test on her? If you want to go without the electric fan you can use a Clutch Fan. I'm using a clutch fan, old style fan shroud, and 180* thermostat with stock radiator. Never had problems. When you are in traffic and start move again any hesitation? Here are some links with some info that you can look over. Some of it does'nt apply here but not bad info. They missed out on the automatic transmissions/torque converter/Lock up/Stalls and Transmission cooler stuff that can cause over engine heating as well if they are bad or not set right. http://www.offroaders.com/tech/engine-overheating.htm http://www.aa1car.com/library/overheat.htm Also you can check the Engine & Drivetrain side of the Forums http://67-72chevytrucks.com/vboard/f...splay.php?f=24
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#44 | |
Thats what I installed in mine, $239 to the door....happy so far.
#45 |
thats what you run ?........wow, wish I wer smrt lik u !!!! ebay alws has gret qualitie radiaters
#46 | |
#47 |
have you made it to 13 yet?
#48 |
Hey he's back: Mr. "radiator size doesn't mean squat" couldn't find anything to back that up have you ?.....let me know if you do, can't wait to see it, don't get yur panties all up in a bunch....I'd be embarrassed too if I said something so ignorant
#49 | |
Not quite sure what your talking about in this quote above, maybe you could expand on the shroud-fan reference in more detail, and we can get that corrected. I'll check back tomorrow and we'll get this fixed for you... no quick reply, Quote MY POST and show ME the mistakes. Don't want anyone to be confused. Try and watch that attitude, don't want to send you to that hamb deal. |
#50 |
Unsubscribing.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
