09-19-2011, 09:06 PM | #26 |
Re: 454 needs more power
I'm not sure of the tire size off hand. It has coil springs, and it's a short bed. Its been lowered a little. I'm not impressed with the "burn-outs." it has a hot rod style, at 45 mph I'm right 3000 rpms. I'm not a fan of that. At 65 mph I'm around 4000 rpms. So it sounds like I'm really on it. But top end might be 80 mph.
Posted via Mobile Device |
09-20-2011, 12:47 AM | #27 | |
60-66 Nut
It sounds to me like you have more of a gearing problem than an engine problem. If you're turning those kind of RPM's, you have some really low gears. Depending on what size tires you have, I'm guessing 4.56-4.88's. I would suggest determining what gears you have before tearing into the engine. Without knowing what cam you have, are you sure you need the 2500 converter? If not, you need to switch to a stock or closer to stock converter, and possibly 3.42 or 3.08 rear gears. Form the way you are talking about your truck being slow, I think this will get you closer to having the truck you want. But then again there are a lot of unknowns about your engine.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-20-2011 at 12:53 AM. |
09-20-2011, 08:36 AM | #28 |
That does make perfect sense. Thank you. Ibought the truck with alot of unknowns, where as I didn't buy it from the person who did work to it. I bought from a lot. But hopefully in the next few months I'll be able to tell you all everything that's in it. The only way to learn is to get in there and turn a wrench.
09-20-2011, 06:30 PM | #29 | |
You don't need more power, you need less gear. It will be able to go faster with less RPM with a higher gear. You are wasting the power you have over revving.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
09-20-2011, 06:35 PM | #30 |
My Carbon Footprint
Sorry but that is a completely inaccurate statement. It is not possible to NOT need more power.
09-20-2011, 07:09 PM | #31 | |
~Rest In Peace~
stick a blower on it and be done LOL
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
09-20-2011, 07:50 PM | #32 | |
You still need the right gear to take advantage of it.
09-20-2011, 08:02 PM | #33 |
My Carbon Footprint
You said you were watching the NHRA not that long ago. You don't even really need the right gear if you have the right clutch! I realize we are getting carried away too.
09-20-2011, 08:05 PM | #34 |
What gearing would be recomended? I'm not sure what's in it exactly but I do know they are welded. Would 3.73 be a good one or is that still to low.
09-20-2011, 11:45 PM | #35 | |
60-66 Nut
This \/ \/ \/
But like I said, that depends on the size of the tires also. Quote:
09-21-2011, 06:56 AM | #36 |
Ok thank you, I guess I over looked that on accident. Well I'll be home tonight, so I can start tearing into it first thing in the morning. I will post my results later this week, thanks to everyone for your help!
09-21-2011, 07:29 PM | #37 | |
Get rid of the welded spider gears no matter what gear ratio you decide to run. That is nothing but a failure looking for a place to happen. Solidly locked axles are no good on the street anyway. They are hard on everything in the driveline, tires, etc. and just plain dangerous in the rain.
09-22-2011, 07:50 AM | #38 | |
Chevy Lover Till The End.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
09-22-2011, 07:55 AM | #39 | |
09-22-2011, 10:24 PM | #40 |
Tall gearing is good. Mine will do 80mph in 2nd :-)
09-22-2011, 11:12 PM | #41 |
Our trucks if used for towing have 4.11 gear w under 400 cid and 3.73 if over 401 cid. If your not twing much 3.42-3.73 with a 454 works good. And non lockup stall converters generally don't work as good in trucks as they do in cars because of the weight factor. Closer to stock will give you better performance in that area IMO
