Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-19-2012, 07:03 PM   #26
C-10 simplex
Re: Anyone running a procharger or super charger?
Originally Posted by CoggedBelt75 View Post
Here's my stuff. Weiand 671 topped with BDS 8-nozzle injector plate controlled by a FAST ecu. 10 lbs boost, no dyno numbers, no track times.
The FAST system can self-tune to this (the bds 8 nozzle)? Also, you'll of course, notice that the 3 butterfly plates are much larger than a carb/tbi/tpi/ plates, therefore allowing much more airflow to pass through; Was this a problem? Did FAST's cpu comphensate for this?
P.S. i'm impressed.
C-10 simplex is offline   Reply With Quote
Old 02-19-2012, 11:36 PM   #27
CoggedBelt75
CoggedBelt75's Avatar
BDS modifies the bug catcher to suit the application. In my case, there is an internal plate blocking the right hole's passage, so it is really just a 2 holer. If memory serves me right, 1240 cfm is what they said is the air intake.
The ecu isn't a "self learning" type like the EZ EFI. It is the old classic grey box where everything is manually setup with a laptop.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
