Old 10-16-2012, 04:02 PM   #26
bossmanivy
bossmanivy's Avatar
Re: Racerx's 72 C20 to C10 Build Thread
I'm pretty much going to do the same build to my 69 c20. I'll be watching and building wiht you. I look forward to your progress.
bossmanivy is offline   Reply With Quote
Old 10-16-2012, 04:07 PM   #27
nuke1
nuke1's Avatar
Sweet truck and startto it so far!! I did the direction you are going in. Gonna be really nice when done. What shade of white do you want to do???
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-16-2012, 05:21 PM   #28
bossmanivy
bossmanivy's Avatar
gonna be sweet
Last edited by bossmanivy; 10-16-2012 at 05:23 PM. Reason: thought my previous post didn't post.
Old 10-17-2012, 10:28 AM   #29
racerx8413
I lied, Ive changed my mind a hundred times over the last few months on color. I'll just wait and see later on :P
racerx8413 is offline   Reply With Quote
Old 10-17-2012, 01:22 PM   #30
nuke1
nuke1's Avatar
lol , sounds like me alot
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 10-18-2012, 11:47 AM   #31
racerx8413
woohoo, just ordered some porterbuilt stuff. Will be a few weeks, but I'm stoked.
Tubular trailing arm crossmember
http://www.porterbuiltfabrication.co...olet-Truck-249
and Trailing arms -
http://www.porterbuiltfabrication.co...iling-Arms-499
Old 10-18-2012, 11:53 AM   #32
nuke1
nuke1's Avatar
lucky guy!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 10-25-2012, 12:16 PM   #33
racerx8413
Maybe a dumb question, but it's driving me up the wall, and I gotta know before I drop this amount of cash.
IS there any difference between the c20 frame and the c10 frame as far as dropping it is concerned. The crossmember?
Anyone have any idea how much the front will drop once the motor is stuck in, on ECE 2.5 drop spindles and 2 inch drop springs? I'm looking to have the front fenders just slightly over the top's of the tires. The tires are 28.7 inches tall, 20 inch boss 338's with 245/45's.
I spoke with Nate a couple of days ago regarding the touring, coilover dropmember. I just want to know what my options are before I blow that much cash. With additional parts (cpp drop spindles, and all the parts for the whole dropmember, about 4k)
Old 10-25-2012, 08:16 PM   #34
bossmanivy
bossmanivy's Avatar
From what I've heard, the frames are the same. C20 frames have different control arms and tie rods and ball joints, but frames are same. So the drop should work like a c10. I believe the only other difference is the c20 have a frame insert in the rear to beef it up. I hope that helps. I'm doing the same thing (c20 to c10) and I got it down to the frame today. Still cleaning it up!
my build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=548037
Old 11-09-2012, 01:11 PM   #35
racerx8413
JUST got off the phone with Porterbuilt, I orderd the touring coilover dropmember and tube arms. Will get the rest of the items (coilovers, steering, cpp spindles) later. Have to hide the expenses from the fiance :P
The plan then is to get the frame chopped for shortbed in the next couple of weeks, and then once all the frame parts arrive, blast and powder coat.
Old 12-04-2012, 01:37 PM   #36
racerx8413
Got the frame chopped and welded, will posts pics of the finished frame once it's all polished up
Ordered the rest of the porterbuilt frame parts, crossmembers, lower shock mount bar, upper shock mount bar, etc.
All that's left on the frame is to have it blasted and powdercoated.
Old 12-05-2012, 10:08 AM   #37
bossmanivy
bossmanivy's Avatar
That looks great! How was it welding the frame back together? I welded mine back, it's square as can be, but I kept feeling like there was a better way. Just curious
my build thread
Old 12-05-2012, 11:47 AM   #38
racerx8413
the welding went well, we measured three times on everything, and ended up with exactly 179 and 3/8 inches overall frame length, if i recall correctly. I'm very happy with it, and we used the frame braces from ECE to weld onto the inside frame.
Old 12-05-2012, 04:31 PM   #39
wgeyer88
The build looks great! It's always good to see fellow Colorado members. I'm doing a similar build and will start a build thread soon! I sent you a PM, had a question on a local shop you used if you don't mind.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 12-06-2012, 08:50 AM   #40
bossmanivy
bossmanivy's Avatar
I would like to see some pics of the braces welded in
my build thread
Old 12-10-2012, 12:11 PM   #41
racerx8413
Got the frame back, will get some pics of the braces as soon as I make some room in the garage
Old 12-10-2012, 12:16 PM   #42
oneoff
oneoff's Avatar
I've got a pristine 1/2 LWB roller that I might have to cut down as well....
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803
Dennis H
1969 Chevy C10, SWB, LS3,6.2L engine
1969 Chevy Chevelle SS,BBC, Convertible
oneoff is offline   Reply With Quote
Old 12-10-2012, 12:27 PM   #43
racerx8413
It's pretty straight forward, make a cut, move the rear cab mount, remove the front bed mount, measure the **** out of it, and weld it back together. the only issue we had, was during the weld of one of the small side cuts, the frame warped a couple millimeters, (that or the c-clamp moved), not a huge deal, we just shaved that section down, and refilled with weld on the back.
The brace plate, we welded the same direction as the frame, some picture's ive seen show the brace welded in facing inward, where it forms a little box, like [] , we welded it along the frame, so, it looks like.. [[. Does that make sense? Wish I had snapped a shot of it before I came into work.
Old 12-10-2012, 12:55 PM   #44
sgaylord
Project collector
sgaylord's Avatar
Good work
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 12-30-2012, 05:46 PM   #45
racerx8413
The UPS Man has been delivering presents for the last few weeks:
Inline Tube Stainless Set w/ e-brake set
Old 12-30-2012, 05:48 PM   #46
racerx8413
And some pics of the frame welds, was tired and in a hurry:
and the notches test fitted
Old 12-30-2012, 05:49 PM   #47
racerx8413
I've still got the PB upper shock mount, pan-hard bar, and all frame crossmembers coming.
I forgot that I need to get a sway bar, I'll keep everything the same and get PB's.
I spent the entire day grinding out rivets, removing the C20 extra plate in the rear of the frame, and fitting the notches. All that's left is to blast and paint. As soon as I get the rest of the PB stuff, I'm sending those items out to get powder coated.
Old 12-31-2012, 04:17 AM   #48
jc70chevy
jc70chevy's Avatar
lookin gud . i think my next truck will be a long bed
jc70chevy is offline   Reply With Quote
Old 12-31-2012, 10:12 AM   #49
sgaylord
Project collector
sgaylord's Avatar
Nice!
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-15-2013, 03:25 PM   #50
racerx8413
more presents - crossmembers, trac bar, upper and lower rear shock mounts, and cat.
