#26 |
house of chevy's
Re: battery cable ?
Ok so i just replaced bothe batterie wires and moved my fuel line from near engine it seemed to help but didnt cure it when u try ans start it it sounds like batt is dieing if u spray start fluid in it it will start right up so i think ir has to do with fuel now the cable onlg get hot when im crankin it for a bit and not starting
1987 m1028 cucv d30 ![]() 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" ![]() |
#27 |
Re: battery cable ?
Not to sound like a broken record, but what gauge wire did you use? I personally don't like to use less than 2 gauge. Some might call that overkill, but it has also taken care of heat buildup in the wire. Not trying to reopen debate about heat soak, or what might cause hot start issues again, just trying to understand what is going into your truck.
#28 |
house of chevy's
Re: battery cable ?
I just used stock replacement ones that seems to be ok now it is a bit easyer now but still does the same i think my next thing is a carb spacer
#29 |
Re: battery cable ?
Edited by staff.
