10-10-2011, 07:20 PM | #26 |
Re: Birth of a C10
looks good, you should go with the clear lenses on the hood like i did on mine (getting rear ones too)
10-11-2011, 11:24 AM | #27 |
Grandpa in the rustmobile...
Re: Birth of a C10
looks good you should get some headlight winkers as well!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-12-2011, 05:10 PM | #28 |
Re: Birth of a C10
Thanks for all the complements guys, you guys motivate me and glad to be part of this great group of people and hopefully motivate some of you ! I been wanting to make a floating grill since the 65 truck but never got around to it until so here it goes:
First i went to home depot and bought some long bolts and drawer knobs and a metal bar , i bought a fence tension bar it was smaller wide and half the price of the 1/8 flat stock bar they sell. I already had the bullets(i bought bullets for two different place's and they used different bolt sizes so i suggest buying all the bullets from one place to make it easy getting longer bolts) so parts cost me $16: First i cut out the expanded metal part of the grill i still need to buy a file or a grinding disk for grinder and clean up around the opening where the expanded metal was cut out!(when i took grill off truck i cut the center support from the back side): Next i layed out a pattern i liked and then evenly spaced and marked the bar i measured and cut it came out to 4' in between headlight buckets: Then i drilled the bar accordingly to the marks i made with the diffrent size drill bits and tightened the bolts to bar i used lock-tight on the nuts because i forgot to buy lockwashers (had to use three diffrent size drill bits because of the two diffrent size bolts on bullets and the knob size bolt): Then i mocked up the bullets and held the bar in place in center of grill opening and marked a mounting point on each end and drilled a hole: These always help bed is full of empty Amp cans!: Then i pulled it all apart and painted the bar and bolts black: next step was to pull grill and cut the center support and then i scuffed up and cleaned the backsplash and taped and painted it black: Painted the brackets on the backside of the headlights black: Painted the grill white: Put the bolt bar in and drilled and bolted it in(painted the bolt heads black) and then used black zip ties to hold center of bar to the crossed bar grill support of radiator on the to bars: And here it is installed i am thinking im going to build some spacers and space it out a little farther an i need to clean up where the expanded metal was cut out in grill opening but the general look: you can pull out the bullet grill bar without pulling the the main grill off truck or vise-verse.....Hope you guys like it!!!!
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 10-12-2011 at 05:21 PM. |
10-12-2011, 06:58 PM | #29 |
Rollin' Old Skool
Re: Birth of a C10
looks great...nice work!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
10-12-2011, 07:02 PM | #30 |
Re: Birth of a C10
looks good man, i should do that on my 50
10-15-2011, 04:47 AM | #31 |
Re: Birth of a C10
killer grill, hope your leg is doing well.
10-15-2011, 12:21 PM | #32 |
Re: Birth of a C10
Good job Tim...how`s the leg lately....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
10-15-2011, 03:20 PM | #33 |
Re: Birth of a C10
The heel is doing better the doctor gave me the ok to use a hiking boot so its been about two weeks walking in one....or should i say limping around like a pirate with a peg leg but at least i dont have a huge walking boot and crutches anymore. It feels like everytime you take a step it feels like having a sprained ankle.The last x-ray you could see the ankle joint which the doctor said most the time you dont so thats good news...just taking it day by day and seeing how it goes no word of surgery yet..
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
10-31-2011, 05:18 PM | #34 |
rusty 66
Re: Birth of a C10
[/QUOTE] Nice like the white wall look
1947 chevy fleetmaster http://www.cbforum.net/forum/ 1966 chevy c10 long bed http://67-72chevytrucks.com/vboard/s...d.php?t=439219 1970 chevy impala custom http://www.layitlow.com/forums/index...pic=349867&hl= |
10-31-2011, 06:21 PM | #35 |
Re: Birth of a C10
Great build man! I like your heater controls
10-31-2011, 09:03 PM | #36 |
Jesse
Re: Birth of a C10
Looking clean bro... Gotta luv the Safety Sandals.....I weld, chop & cut in mine also
11-03-2011, 04:39 PM | #37 | |
Re: Birth of a C10
well my birthday was oct-29th and i always ask for car parts or tools for holidays so my girl and some family members got me some wheel accessories: \ i went to the hardware store and picked up some tools to clearence the stock wheel hole to except the bullet push-thur cap: The stacked cut off wheels on a drill arbor worked the best and i suggest using this if your going to do it yourself; and what the wheels look like now,I might get the smaller chrome beauty ring that pops onto the nubs near the lug nuts like a dogdish hubcap would do:
11-03-2011, 05:55 PM | #38 |
Re: Birth of a C10
could you find out were they got the hub bullets? i want some, already have the lugnuts.
11-03-2011, 06:02 PM | #39 |
Re: Birth of a C10
lug nut king heres a link:http://lugnutking.com/ i think they are 8 bucks each i suggest getting 5 because one you will use to gauge the hole and it gets pretty scratched up since its just aluminum, i got 4 but already have 1 more ordered and waiting for it to come to replace the one i scratched up, the guy is cool he said everybody calls back and orders a 5th one LOL
11-13-2011, 07:44 PM | #40 |
Re: Birth of a C10
Not much of a update just some stuff i picked up and put on....First off i wanted a tach but i forgot the other aftermarket gauges were black and bought a white one and destroyed the packaging before i realized it was wrong ,so I maybe swapping it out later for a black faced gauge, and then i picked up a Re-pop classic accessory flashlight and holder that goes on the column, the column was to big to clamp it around so i modified the flashlight bracket to use the tach to hold it to column, it wasnt a vintage one so i didnt fell bad...
Tach: Accessory flashlight:
11-13-2011, 11:36 PM | #41 |
Re: Birth of a C10
I love the floating grill! wish I could do it to mine but it really doesn't go with the 4 wheeler look. Dig the tach too. I've got the same one installed in the guage cluster in black. Looks stock enough for me. Your truck's coming along great. You've made alot of progress for sure and it's good to hear you're healin up ok. I've got to figure out a way to have two... a 4x4 and a 2wd. Then I could do alot of the custom stuff I see you guys doin to the right truck. No more custom envy!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
11-15-2011, 08:01 PM | #42 |
Re: Birth of a C10
Well i picked put some blue dots and decided to try and install them on my old lens, ive drilled lens before but it is always risky chipping or cracking them,i know from experience! So i tried a new technique which worked well for me that you guys might like it....
Stock lens: On these lens there is round ridges on the back side the bloue dots need a 15/16 inch hole and the(hard to see) the deepest ridges in the center are 1 inch so lining up the center was easy: I tool i will be using is socket on a extension that measures 15/16": Over at the stove i heated it up: And then line it up right in the center and let it melt into the lens..This part stinks a little!......i had to reheat and melt a couple times to get all the way thur: next was install the blue dot's: Twist the prongs with pliers to hold the glass in and everything to the lens: Presto!!: Installed: Apply power: I couldnt get a good angle with the camera with out it blinding the picture showing the blue dot part but they are quite blue! ill have to get a night time shot! Hoped you guys liked it!!!
11-15-2011, 11:01 PM | #43 |
Rollin' Old Skool
Re: Birth of a C10
cool idea! looks good
11-16-2011, 12:32 AM | #44 |
Re: Birth of a C10
Cool Tim.... mine are in as well, I guess i should change my avatar...!
11-16-2011, 01:33 AM | #45 |
Re: Birth of a C10
Love the background in this shot.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
11-16-2011, 01:41 AM | #46 |
Re: Birth of a C10
Ya have two yardbirds, I feed them all the time so they follow me around the yard like dogs, really domesticated will jump up on your arm if you hold it out straight!
11-17-2011, 01:08 AM | #47 |
Re: Birth of a C10
Whats up Tim man I dig everything you've done with this truck keep up the awsome work those dots are hella cool
11-17-2011, 01:33 AM | #48 |
Re: Birth of a C10
WOW!! Nice work on everything you have done. We appreciate the photos. Keep up the great work.
11-17-2011, 02:03 AM | #49 | |
Re: Birth of a C10
thank you! i like posting the pictures it gives me some where to keep them all in order,and keeps me motivated to work and post more......i see your new to the site!! Welcome and dont be scared to post pics i enjoy seeing what everybody else is doing also!
11-17-2011, 02:48 AM | #50 |
Redneck Hillbilly
Re: Birth of a C10
Nice trick on the blue dots, I'm going to have to try that one when I instal mine. I really like the way your wheels turned out, truck is looking great!
