10-10-2011, 03:12 PM | #26 | |
Custom Builder
Re: 1966 K15 BBW Cab Floor Repairs
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
10-10-2011, 03:37 PM | #27 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
10-10-2011, 07:23 PM | #28 |
Custom Builder
That is a nice trick! We were trying to puddle the TIG welds a little so when we blend them it will leave an impression. I will keep you posted on your method if we need to use it. Thanks!
10-11-2011, 08:09 PM | #29 |
Custom Builder
Got a little more done on the Cab today.
The rockers are now fully welded in top and bottom. We blended the spot welds in the door opening.
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 Last edited by LeftCoast32; 10-11-2011 at 08:15 PM. |
10-12-2011, 12:58 AM | #30 |
60-66 Nut
Very nice work
I don't know if it is just the pic, but is there a bit of a gap where the rocker meets the cab corner? I put rockers on a '67 a couple years ago, and aside from the same need to split the upper ends, the lower part of the rocker was 1/8"+ too short.
10-12-2011, 09:17 AM | #31 | |
Custom Builder
10-12-2011, 11:20 AM | #32 | |
But Found Her 25yrs Later!
Like you, I will use the cab corner to align the rocker, and then do the cab corner once the rocker is all set. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-12-2011, 09:09 PM | #33 |
Custom Builder
We were able to get a few more hours on the Cab today.
Cab Corner is all welded and blended. We had a patch that was needed in the B-Pillar (Sail Panel). It is all welded in and blended. We patched the Gas Filler Hole in the cab. We took the cab off the stand so we could work on a few dents on the roof. We will be rolling it on its back to dress up all the welds on the bottom of the cab tomorrow. Everything is looking great at this point.
